Apple iPad Pro 9.7" A1673
  • mferna14
    • Jun 2018
    • 1053
    Working on Apple iPad Pro 9.7" A1673.. By mistake plugged in the LCD/Touch connectors when the battery was still screwed in. At once smoke started to come out of one of the caps & burnt a circuit trace... Cannot figure out where this trace goes. In the background all works fine, I can hear the sound & connects to the coumpter too. Anyone having the schematic for this, would greatly appreciate. Thanks in advance
  • dooley69
    • Aug 2022
    Re: Apple iPad Pro 9.7" A1673
    I'm also looking for this one
    • AlexVG
      • Apr 2022
      • 138
      • SPAIN
      Hi, Me too..
      • jkb242
        • Mar 2012
        • 175
        For specific issues like no screen due to connecting LCD while hot, look for YouTube videos specifically addressing coil and diode replacement in the backlight section. I have nothing on this model either and faced with bat to ground bus short. There are several ones out here that might give you a clue where to look as the YouTubers usually have full board views they show in the video or they at least identify the components in the video which is basically what is needed. Best of luck to the searches for this boardview, I would be interested in as well.
        • Stevechurch
          • Feb 2023
          • 24
          • United Kingdom
          Hi All, Was this Schematic ever found? i could also do with it please if it was Kind regards Steve
          • AL._.EX
            • Dec 2022
            • 910
            • Belarus
            Partnumber???
            • Stevechurch
              • Feb 2023
              • 24
              • United Kingdom
              hi, thanks i found the schematic on another post..i didnt read the post well enough, it was my error
              thanks for looking
              • barangabrawr
                • Dec 2018
                • Austria
                thanks for looking
                where exactly?
                • grimacelord
                  Apple iPad Pro 3rd Generation 12.9" (A1876) No Power/Charge When Screen Is Connected
                  by grimacelord
                  Hello.
                  Working on an Apple iPad Pro 3rd Generation 12.9" that has a weird issue. When the display is NOT connected, the iPad will charge and power on normally. I know it's on because I can hear notification sounds and the charging notification sound.
                  If I connect a brand new display to the logic board, the iPad will not turn on at all. When I connect the iPad to an 18W wall charger and a USB-C ammeter, I can see that the iPad is attempting to charge, but constantly "resets" after just a moment or two.
                  For example, when I connect the iPad to...
                  04-15-2022, 11:06 AM
                • AlexVG
                  IPAD A1673 power constantly resetting
                  by AlexVG
                  Hello. I came across with the power supply constantly resetting on IPAD A1673.
                  (I connect it to USB power)
                  PMU U8100 is rising all voltages except PP3V3_S2 . Consequently, the SYS_ALIVE is also absent.
                  I have two identical boards with the same symptoms, and I think this is a common problem.
                  I also have a working board. I've taken all the measurements to compare and haven't seen any abnormalities. There are no signs of a short circuit or water damage.
                  VREF, IREF are also present.
                  I also couldn't find any PP3V3_S2 enable signals.
                  Please help me and suggest...
                  09-24-2025, 05:24 PM
                • a_p3rson
                  Apple Watch Charging Controller Schematics / Boardview - 820-02601
                  by a_p3rson
                  Hi there,
                  I'm looking for anyone who might have information on Apple's embedded Apple Watch charging daughterboard, ID 820-02601. This is currently used by Anker in their Apple Watch charging products, but likely by other Apple partner brands as well.
                  You can see the board referenced in ChargerLab's teardown of the Anker Y1811 3-in-1 MagSafe cube - they discuss the "Apple Watch wireless charging circuit" about 2/3rds down the page. It's not pictured, but the board ID reads 820-02601-A, which sure sounds like Apple.
                  This daughterboard uses an interesting...
                  04-21-2025, 11:41 PM
                • GeirAndersen
                  iPad .pcb file collection
                  by GeirAndersen
                  I tried searching the forum for whether this has been uploaded already, but couldn't find them (as a collection).
                  Here's a dump of a bunch of iPads, I've split into 2 archives to get under file limit
                  IPAD COLLECTION 1
                  +---iPad mini1 820-3400(A1432) 820-3243(A1454?A1455)
                  +---iPad mini2 820-3683(A1489) 820-3684(A1490?A1491)
                  +---iPad mini3 820-00008(A1599) 820-00002(A1600)
                  +---iPad mini4 820-00180(A1538) 820-00177(A1550)
                  +---iPad mini5 820-01591(A2133) 820-01495(A2124?A2125?A2126)
                  +---iPad Pro 12.9-4-820-01797(A2229) 820-01798(A2069?A2232?A2233)...
                  12-09-2024, 09:28 AM
                  Apple iPad 4th Generation 820-3249 Boardview and Schematic
                  Apple iPad 4th Generation 820-3249 Boardview and Schematic...
                  11-01-2024, 02:45 PM
