Hp 450 g6
    Hp 450 g6
    somebody pls fix my no power bios
    board id: da0x8jmb8e0 rev:E
    thanks
    Re: HP ProBook 450 G6
    thanks
    try..
      no luck ,now power ok but no display , restrating after 8 sec
        https://forum.laboneinside.com/viewtopic.php?t=5906
          Hp 450 g6 need cleaR ME region plzzz
          I need to clear me regionfor this file please
          showing logo after 1 min
          https://www.sendspace.com/file/n1m8hc
            Re: Hp 450 g6 need cleaR ME region plzzz
            post the bios here on the site ..
              Re: Hp 450 g6 need clean plzzz
              Try this given file and report back. Darn Sendspace made me jump thru hoops and loops to download.
                You made a small mistake somewhere,its still "initialised" check it with MEAnalyzer
                  Try
                    I used this one: 12.0.22.1310_CON_LP_C_PRD_EXTR.bin . Is the fact that it is extracted set the error of being already initialized? I know the ones marked RGN are better, but when there is no choice, what do we do? The instructions on the ME guide are unclear to me, I'm not sure what to use.
                    Quote from guide: So we pick the firmware file 9.1.25.1005_1.5MB_PRD_RGN which matches perfectly what we saw at ME Analyzer. If for example the dumped SPI/BIOS image had ME 9.1.37.1002, we would have picked ME 9.1.32.1002 instead because the one we wanted is EXTR and not RGN. Thus, we rename the "9.1.25.1005_1.5MB_PRD_RGN.bin" copy to "ME Region.bin".
                    So can we lower the hotfix number to closest one with RGN? Major, minor and build SKU stay the same.
                      Read section D4. ,maybe you renamed the FW "ME Region.bin" instead of "ME Sub Partition.bin" .If the FW is still "initialised" after building then something has gone wrong.
                      D4. CSME 11 - 15 & CSTXE 3 - 4
                      4. Browse the Repository pack, copy the same (or as similar as possible) CSME/CSTXE RGN firmware of the same SKU and major/minor version (as instructed above) somewhere and then rename it to "ME Region.bin" for CSME 11, "TXE Region.bin" for CSTXE 3, "ME Sub Partition.bin" for CSME 12 or "TXE Sub Partition.bin" for CSTXE 4, depending on what you're working with.
                      I used this one: 12.0.22.1310_CON_LP_C_PRD_EXTR.bin .I know the ones marked RGN are better, but when there is no choice, what do we do?
                      Personally i always use PRD_RGN,(if a bios does have PRD_EXTR FW then use PRD_EXTR) the major version and minor version should be the same especially for older ME FW, 7,8 and 9 etc .When there is no exact matching PRD_RGN FW in the repository you can use the closest older or newer FW.
                        Yep, that's what I did wrong, renamed the bin "ME Region.bin" instead of "ME Sub Partition.bin".
                        Thank you for your critical advise, and the carification, learn something everyday.
                          here is Thanks
                            Originally posted by lapfix View Post
                            Try
                            it,s working
                            Thanks for help
                              Need Bios for HP Probook 450 G6
                              Motherboard code HP Probook 450 G6 DAX8JMB16E0 Rev E
                              Model X8J-6L
                                Re: Need Bios for HP Probook 450 G6
                                Post your original corrupt bios file.
                                Become a Badcaps supporter
                                Thanks to all supporters.
                                    Originally posted by caprigtx View Post
                                    HP ProBook 450 G6 Notebook PC
                                      Thanks For help .
                                        Hp probook 450 g6 dax8jmb16e0
                                        repair pls,no display
