VN7-791G-77GZ bios dump
  • dmusic
    • May 2015
    • 14
    • bulgaria
    Please for help,VN7-791G-77GZ bios dump
    (Wistron Poseidon 840M MB)
  • nacer
    • Feb 2016
    • 130
    • alger
    Re: VN7-791G-77GZ bios dump
    you got it
    • demisoc
      • Jun 2019
      • 6
      Which programmer did you use for this? My EZP2010 programmer doesn't detect this chip (25B64BSIG). I tried to program it while it was still on board. I'm wondering if my programmer is not compatible or if it's because I tried programming the chip while it was still soldered to the board.
      • hotcrossedbuns999
        M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
        by hotcrossedbuns999
        My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
        1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
        2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
        3. I could only locate two chips that look like bios chips. Could someone verify this
        01-03-2025, 12:32 PM
      • Habble7
        I need a BIOS dump for the Samsung S49CG934SU monitor
        by Habble7
        The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
        Suspected Cause:
        I suspect the BIOS may have been corrupted during a power interruption while updating the firmware. The official website provides firmware updates, but they can only be installed via USB flash drive.
        Troubleshooting Attempts:
        05-22-2025, 07:28 AM
      • haitham sharabati
        [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
        by haitham sharabati
        Hello engineers 😀,
        I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
        🔧 Device Info:
        - Model: HP 15-da2007ne
        - Product Number: 8XF55EA#ABV
        - Serial Number: CND0338P0D
        - CPU: Intel Celeron N4000
        - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
        💀 Problem:😅
        - Device shows “Administrator Password”...
        08-07-2025, 04:54 AM
      • Citymin
        NT955XED (Samsung Galaxy Book2 Pro - 15.6) BIOS dump file Request
        by Citymin
        My Samsung Galaxy Book 2 Pro 15.6-inch laptop has no display and won't boot.
        The charging red LED lights up, but the charging screen doesn't show any indication.
        When I press the power button, the blue LED cycles on and off three times, then the screen doesn't turn on, and the device won't boot.
        (I've tried removing the battery and resetting the device, but the issue persists.)
        NoteBook Model name : Samsung NT955XED-KK51G(Galaxy book2 pro, i5-1240p, 15.6inch AMOLED)
        PCB model name : Venus2-15-5G(REV1.2), Venus2-15 ADL NPC
        S/N : 5RNK9FFT70...
        08-05-2025, 05:12 AM
      • DynaxSC
        MSI PRO B660M-G DDR4 - real bios dump from board needed (no stock bios)
        by DynaxSC
        Hi, I have an MSI PRO B660M-G DDR4 board with damaged BIOS and i need a bios dump from a real board, along with MAC, UUID and Serial Number info (eg. a BIOS screenshot and pictures from the board stickers).
        I need to reconstruct the bios on my board, based on another bios image form a real board - meaning a bios image containing MAC address, UUID and Serial number. A stock BIOS is not suffiecient, as it is impossible to discover where the MAC, UUID and SerialNumber are stored. Tried with a similar board, but there are too much differences, and the stock BIOS is missing a lot of...
        11-17-2023, 10:56 AM
