Bn44-00604f
    Bn44-00604f
    HI
    I have a power suply BN44-00604F whit the R9151 and R9152 blow could some one tell me were i can find the service manual for this board so i could see the value of the Resistence ?
    Nuno
    Re: Bn44-00604f
    After translating another site I think they could be 2 ohm each
    h++ps://translate.google.com/translate?hl=en&sl=ar&u=http://www.amwajsat.net/vb/showthread.php%3Fp%3D78196&prev=search
      Re: Bn44-00604f
      Hi
      Thanks a lot i will try and report latter
      Nuno
        Re: Bn44-00604f
        Hi
        i have put the 2 ohm and still no power on the tv i have found that 2 leds are direct so i put the 5 diodo 1n4007 on it and still the same thing .
        the red led blinks 5 times .
        Whit the main board disconect from the power suplly board wen i conect the power cord on the leds panel iluminates for a second or so and goes off so the problem is in the power board
        could some one help me out
        and iff some one as the manual for this board .
          Re: Bn44-00604f
          Can we see the pictures of the whole back side of the TV and the pictures of the boards?
            Re: Bn44-00604f
            HI
            Here it is.
            PS. I just see that i have post on the rong side off the forum if some moderator whants could put on the right side
              Re: Bn44-00604f
              HI
              NO ONE ???
              THANKS
                Re: Bn44-00604f
                That power supply/LED driver board is known for having poor soldering joints on the power transformer legs, so I would at least resolder all the transformer leg.
                BTW, the two 2 Ohms resistors, were they burnt out or what was wrong with them?
                  Re: Bn44-00604f
                  Hi
                  i have already check de soldering and they are all ok .
                  as for the 2 ohm resistors they were blowed becouse they touch in the frame and they blow .
                  i have put 2 new ones and it as the same problem led light blinks 5 times the led bars light for a second wen i plug in the power cable and goes down so there is something in the board but i cant find it
                    Re: Bn44-00604f
                    i have measured the CNL802 that conects the cable to the leds and whit the plug on it or off it give me the same values
                    15_ 1F2 0V
                    11_ 1- 0V
                    9_ 2- 0V
                    5_ 3- 0V
                    3_ 4- 92.6V
                    16_ 1F1 0V
                    12_ 1+ 179.2V
                    10_ 2+ 0V
                    4_ 4+ 0V
                    This was measured whit the main board disconect and ground directo on the PSU
                      Re: Bn44-00604f
                      15_ 1F2 0V
                      11_ 1- 0V
                      9_ 2- 0V
                      5_ 3- 0V
                      3_ 4- 92.6V
                      16_ 1F1 0V
                      12_ 1+ 179.2V
                      10_ 2+ 0V
                      4_ 4+ 0V
                      That feeding Voltage of 179VDC (at 12 1+ pin) to the Anode of the LED strings indicate the load is too light or you have open circuit in the LED string or in the LED Cathode current return path.
                      If you look at the Voltage chart as printed on the board, it shows VLED feeding Voltage of 145V with 240mA max current, that is the output with load, without the load the output will go up too high and will trip the shutdown circuit.
                      Do you get the same 179VDC if the LED connector is not in place?
                        Re: Bn44-00604f
                        Hi
                        yes whit the conector on or off i get the same value
                          Re: Bn44-00604f
                          That means it is not seeing the load, which can be the open circuit in the LED string, or open circuit in the current return path for the LED which is on that power supply board.
                          BTW, for those two 2 Ohms resistors which are connected in parallel to form 1 Ohm resistance, something must have been drawing too much current through them to cause them to burn up.
                          Are you 100% sure that the whole LED string which are consisting of 5 LED strips (9 LEDs per STRIP, 45 LEDs total) and connected in series to form one large LED string are good for sure?
                            Re: Bn44-00604f
                            yes im 100% sure all the led strip are ok apart from the 2 ones that i have put the diods
                            the 2 Ohms resistors like i sayd they burn up becouse the board touch the frame by my fault as i didnt screw the board and wen i lift the panel it slide and touch the frame
                              Re: Bn44-00604f
                              hi
                              Can someone tell me the values of the resistors rm817 and dm803 are located on the underside of the MOSFET
                              Thank you
                                Re: Bn44-00604f
                                Rm817 = 0Ω, DM = 1N4007
                                  Re: Bn44-00604f
                                  Thank you
                                    Re: Bn44-00604f
                                    Ciao
                                    Ho anch'io un problema con la scheda in questione, dopo svariate prove ho trovato il transistor Q9051 in corto solo che non si legge più nulla, mi potreste aiutare.
                                    Grazie
                                      Re: Bn44-00604f
                                      Hi ilija, did you solve this issue as I have the same problem with the LED blinking 5 times. The manual button on the back of the TV works as the time makes some sounds but there is no picture.
                                        Re: Bn44-00604f
                                        i have the voltage that feed led 217 v ( between the two pins that goes to the leds) is that ok ?
