Hp 15-dy1731ms not turning on
  • mferna14
    • Jun 2018
    • 1045
    Hi all, I am working on Hp 15-dy1731ms (Board # DA0P5DMB8C0 Rev: C ). Upone diagnostics I found one of the rect' diode (A2 1N) near the battery was burnt, I replaced with another good one. Did not turn on. I reprogram the BIOS chip & now the LED on the DC-in jack BLINKS 3 times when the switch is pressed & then shuts off completely. No shorted rail, all looks good. The battery charging chip used is BQ728H .... The voltages on this chip are below:
    i) VCC Pin 19 19.4 V Ok (Pin 1-2-3 19V)
    ii) ACDET Pin 6 2.0 ( where as this should be 2.6 > )
    iii) REGN/LDO/VVDP 5.9V Pin 16 ( seems to be ok)
    iv) ACOK 0.3 V Pin 5 (OPEN DRAIN OUTPUT) (Assuming pin should be high on BQ24728, about 3.2V)
    V) ACDRV Pin 4 24.2V (Ok)
    vi) ILIM Pin 10 1V
    Does anyone have the Schematic for this model to share or any tips will be greatly appreciated. Thanks
    • 21667
    Re: Hp 15-dy1731ms not turning on
    If you want the schematic you can request it in the schematic requests forum, or add your request to an existing thread - https://www.badcaps.net/forum/showthread.php?t=96880
    • mferna14
      • Jun 2018
      • 1045
      Hope I get the schematics in the existing thread. & if anyone wants to shed their knowledge at this problem I am getting in this Hp model. Thanks
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        ACOK pin uses pull up from 3.3V rail and that rail is usually LDO. Check the resistor connected to pin5 of charging IC. Do you get 3.3V on the other end of resistor?? If so, that indicates presence of 3.3V LDO. Problem seems to be that of ACDET. What is the voltage on AD_ID pin of dcjack??
        • mferna14
          • Jun 2018
          • 1045
          Thanks "mcplslg123" you are always there for help. Pls. check this photo. Similar circuit used on my motherboard. ACOK Pin 5, only get 0.03V & ADETPin 6 2.0V... AD_ID DC-in jack cable, no voltage at all. Hope this photo will help to give me some tips.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Nothing is visible in the pic attached. Did you measured the other end of resistor connected to pin5 of charging IC?? Want to be sure about the status of +3V LDO first. Trace the resistor connected to AD_ID pin of dc jack and measure resistance as well as voltage on both sides of them. Usually 2 resistors are connected to AD_ID pin and they act like voltage divider. Measure voltage on AD_ID pin of SIO also. Which SIO is used here?
            • mferna14
              • Jun 2018
              • 1045
              Thanks "mcplslg123" for all the help. This notebook had extended warranty from hp. So I send it for warranty claim. Super I/O was IT5570E-128 , BY THE WAY is this programmable??? 'cause I checked the other IT chips, the KSI pins are totally different on this IT5570E-128.
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                IT5570E is programmable
                • Sparklingx
                  HP 450 g1 keeps turning on even tho shutdown/sleep
                  by Sparklingx
                  HP 450 g1 keeps turning on even tho I shutdown/sleep . one way to stop the turning on cycle is pressing the power button few seconds thus force powering it off. But then sometimes it does not turn on at all but next day I try again to turn it on and it turns on....
                  09-23-2024, 12:34 AM
                • khelane
                  Satellite PRO A50-A Not turning on after turning off Windows
                  by khelane
                  Hello
                  A device with specifications
                  Toshiba Satellite PRO A50-A is here to replace the hard drive.
                  The hard drive has been replaced and there is no problem, but there is another problem, but the customer does not care to fix the problem.
                  The device enters Windows without any problem and works, even I put pressure on the CPU and graphics, but when I turn off the system through Windows, if I want to turn it on again, the system switches, but it turns off quickly within a second, and this routine continues. It is turning on and off within a second and soon it turns off....
                  04-20-2023, 06:28 AM
                • Rabit
                  VX3276-2K-mhd-2 Random Turning off
                  by Rabit
                  Recently staring turning off more often, brightens set at 50% - monitor back side in PSU area is very warm to touch, also at front left corner getting hot.
                  When changed brightens set at 30% no longer turning off , and no longer I can feel any heat in this areas.
                  This can be signs of bad capacitors causing overheating PSU ?
                  06-17-2024, 09:30 AM
                • shakib200
                  Dell latitude E7240 not turning on if adapter plugged in
                  by shakib200
                  Laptop turns on only on battery but if I plugged the adapter with battery, it is not turning on. After turning on the laptop using only battery (no adapter plug in), then plugging the adapter everything works fine also charging ok. Anyone have any clue what’s wrong?...
                  03-31-2024, 12:55 PM
                • netgearnetgear
                  AIWA 32" TV not turning ON
                  by netgearnetgear
                  Good day everyone,
                  I have a AIWA 32" TV model #
                  AW32B4SM that is turning ON with a blank screen. The backlight is working but there is no image on the screen. I did the standard troubleshooting checks: logic board inspection under microscope, reseating ribbons cables, power rail checks, diodes, mosfet checks, power on and measure voltages on coils, caps, vcc, regulator checks all check good. Then I measured the panel voltage (12v present) and noticed that the VONE (approximately 30v) was missing, the AVDD (15v) was only 5v, vcc 3.3v present, vcc 1.8v present. I know when...
                  10-03-2025, 06:06 PM
