Filtering Capacitors Around Flyback Transformers In CRT Monitors
  • Hitto
    • Apr 2019
    • 95
    • Italy
    I have a question about the filtering capacitors to be used around the flyback transformer in CRT Monitors.
    I mean the 10-22-33uF capacitors which filter ~160V voltages going to the flyback trafo.
    1) Do they have to be low E.S.R.?
    The original capacitors are usually general purpose, but I suspect this was for cost cutting more than a requirement.
    2) Is geometry and picture stability improved in case of increased capacitance?
    I've seen schematics on similar models of some old Sony monitors: identical flyback transformer but capacity increased from 33uF to 47uF in a more costy version.
  • R_J
    • 9606
    Re: Filtering Capacitors Around Flyback Transformers In CRT Monitors
    I have usually replaced these with a good quality 105° capacitor, You don't need low esr. Any good panasonic brand will outlast the tv. There is not that much difference between the 33µf and 47µf caps. as they are usually +/- 20% tolerance, If they are just for filtering the screen supply voltage it won't make any real difference.
      • 31247
      the frequency is not high enough to need low esr.
      good caps like panasonic NHG will make a difference compared to junk like "forever" and other shit on ebay though.
      • Hitto
        • Apr 2019
        • 95
        • Italy
        Yes, they are for this exact purpose.
        Do you guys know the specifications of 105° Samsung ST capacitors? They measure normal E.S.R. (1.10Ω) but I'm struggling to find a datasheet to find out their maximum applicable current.
        I'm currently planning to upgrade the capacitance of each supply line by X1,4 and upgrade a little the horizontal width capacitor. Geometry is currently a bit defective and messing with the trimmers is a no-no.
          • 31247
          watch out for a non-polarised cap - if you find one you can replace it with polypropylene
          • Hitto
            • Apr 2019
            • 95
            • Italy
            The original capacitor in the horizontal width, from what I read, handles a lot of current (even 10A).
            Is one polypropylene okay for such current or do you suggest me paralleling a pair of them just to avoid a worst case scenario?
              • 31247
              you can get high current ones - download some datasheets.
