TCL 50S425 Roku TV Boot Loop
  • grimacelord
    • Jan 2017
    • 383
    Hello again. This time it's a TCL 50S425 Roku TV that is stuck in a boot loop.
    The TV will power on, display the TCL logo for a few moments, and then the TV restarts in an endless loop. It sounds to me like corrupt firmware.
    So far, I have:
    1. Disconnected the power cable and pressed and held the power button down for 30 seconds and tried powering on again - No change.
    2. Pressed and held the RESET button for up to 60 seconds. - No change.
    3. Tried disconnecting power cable in the middle of one of it's loops, as suggested by dozens of Reddit and TCL support threads. - No change.
    So here is where I have tried to create a USB to manually update the firmware via the USB port.
    I went to https://tvupdate.roku.com/index?p=select and began to follow the prompts. I choose TCL as the brand and enter 50S425 as the model and enter the SN found on a sticker on the back of the TV.
    After submitting my information about the TV, I get an error message saying that it's an invalid model number. "Roku Model Number is 4 numbers and a letter" and then proceeds to tell me to use the remote to go to Settings ---> About ---> and find the "Roku Model Number". This is my problem. The TV doesn't boot. I CAN'T get into settings to get that model number. All I have to go on is what is printed on the stickers on the back of the TV or the mainboard itself.
    Attached are a couple of photos of what is actually printed on the back of the TV. I was hoping someone could help me figure out the "four letters and 1 number" of the "Roku model number" they want so I can download the firmware and try manually updating via USB to see if this fixes my issue.
    I was even going to go as far as dump the firmware from the mainboard and read it in a hex editor to see if I could get this model number they want (or even manually flash the firmware directly using a programmer if USB doesn't work), but it looks like it's stored on a NAND flash chip and I don't have the proper programmer to read it.
    So anyway, can someone help me figure out what model number they want? It's going to be embarrassing if it's super easy to determine and is right in front of me all along.
  • gavric
    • Jun 2011
    • 65
    Re: TCL 50S425 Roku TV Boot Loop
    So far, I have:
    I had tv like this, it was hisense, about same as tlc. It was acting like it could not go past TV brand logo. It turned out it was bad capacitor on the screen buffer board that was heating up in like 2-3 seconds and causing the short. I found it by taking tv apart and then going and looking at these buffer boards that are attached to the screen. Actual small surface mount capacitor would get so hot that it would melt solder and all this in 2-3 seconds and then solder would cool and all over boot process every 5 or so seconds. I simply removed this little capacitor and tv worked, there was like 5-6 capacitors all connected parallels and i guess one of them went bad.
    Open the tv and disconnect tcon board from main board and if tv stays on you are having same issue. You will know if tv is on by You can hear clicks if you try to turn volume up or press menu buttons on remote.
    • NolesFan
      Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
      by NolesFan
      Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
      10-24-2024, 06:36 PM
    • Takeatry
      Yet another Samsung QLED Boot Loop
      by Takeatry
      Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
      10-04-2024, 02:57 PM
    • blaster_
      Samsung UE49MU6105K - boot loop, horizontal lines
      by blaster_
      Less than a year out of warranty, samsung UE49MU6105K craps out, they've got this designed obsolescence down to an exact science of self destruct when out of warranty...
      Screen started to show horizontal lines and ghosted image at the bottom, then turned off by itself. Did software update, to no avail of the line problem, and got a boot loop after some minutes of watching TV. This boot loop will turn on the backlights for some seconds the sound comes on, the image will turn dark very fast and then it reboots again. Pressing power button will not put it on standby. Disconnecting...
      06-22-2022, 05:19 PM
    • torchzack
      Samsung 55" TV - Boot loop but sometimes works fine - UE55MU6470U
      by torchzack
      Hi Team - just joined to see if anyone can offer some expertise in diagnosing an issue with a TV.
      I've done a few hours googling and youtubing but just seeing if anyone has any insight here. I got a 55" Samsung UE55MU6470U which seems to boot loop and then after 10 mins will boot, work for a few minutes, then turn off and repeat.
      Whilst it's on into the normal Samsung menu/boot screen it looks perfect - so I can't see there being any screen issues. I've seen lots of videos with taping across clock lines to diagnose which particular one may be an issue but i don't...
      08-28-2023, 07:42 AM
    • Daniel Larsson
      Firmware file for LG SK10Y Soundbar stuck in Please wait loop needed
      by Daniel Larsson
      My LG Soundbar, SK10Y, has somehow ended up in an endless "PLEASE WAIT" loop and I am now starting to suspect that the firmware is causing this, and I can't manage to connect via the app to push a new firmware in as it never really starts.
      I can trick it to start via HDMI ARC and it actually starts up, flashes OPTICAL and then goes to ARC where the sound (including sub) is perfect, but the white led indicator keeps blinking and after 20 seconds it says "GOOD BYE" and shuts down.
      During these seconds the function button is not working...
      08-13-2025, 10:29 AM
