I have an Epson L1300 printing 1 blank page with each job. It always prints a blank page first then prints the print job normally. It is doing this everytime something is printed. It is shared over a small network (installed on 1 pc via usb cable). It is doing this on all the computers.
by hasel17So I am trying to repair broken thunderbolt FW on X1 Yoga Gen 2. The EEPROM chip is WINBOND 25Q80DVNIG. I already do a back-up and erase. But when I try to wrote new FW, it was successfull, but when I tried to read it, it still blank. when I try to do a blank check, it gave me instant error in address 0. I already tried two CH341A, already did the 3.3v fix mod, using AsProgrammer, NeoProgrammer, Colibri, and CH341A 1.29. But the problem still occurred. What I did wrong here? Can anyone help me? Thanks in advance. Here is the log in Colibri :
...Code:Checking for blank... (Press
by shamsudeenEpson M3170 Monochrome inkjet printer adjustment program tool.
Hi, i want to reset a epson reset program tool needed to reset the EPSON M3170 PRINTER's Maintenance box,
anyone having it, please share
Thank you -
Found an Funai 32FL553P/10 TV on sale for cheap listed as broken, so I decided to give a shot at reparing this.
State I got it in:
Squealing from the PSU
After logo I get a blank screen
After 10 seconds of having a blank display w/ backlight the TV dies
Give it 7-10ish seconds again and it starts to bootloop.
What I did so far:
Replaced all the caps on the PSU (apart from primaries, they were fine and none at hand)
Checked all voltage rails:
5VSB - 4.8V
AMP+13V - 14.4V
13V - 12.98V (in manual 12V)... -
I've got a Hanns.G Hi221 Monitor that works for a moment and then the display goes off but the power LED indicator remains on. If you power it off and back on again it does the same thing, it comes on and then the display goes blank. From a cold start it takes 10 seconds or so before the display goes blank but if you turn it off and then back on again after it already being on it goes blank a lot quicker so I'm assuming something is getting hot which is causing the display to go off.
I've uploaded a video of it happening on YouTube:
I've taken the monitor...-
by ChrissygizmoHi all, I’ve got a problem I hope someone can help me fixi.
I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...01-11-2025, 03:18 PM - Loading...
