bios dump elitebook 840 g3
    Re: bios dump elitebook 840 g3
    Originally posted by peste View Post
    if it works enter the DMI information
    https://www.youtube.com/watch?v=9T57ktw8n3Y
    hi. Got anything for 6050A2728501-MB-A01
    thanks
      this is a custom tool i made out of garbage and pogo pins for this type of non clippable chips
        Originally posted by r12x2 View Post
        Laptop is turning on, but no video after few seconds the fan is spinning.
        Can someone rebuild the original bios?
        I have same issue with G3.
        Did you find solution ?
          Re: HP EliteBook 850 G3 corrupted extracted image
          hello,
          please help me imstuck with remove admin bios password
          i maked dump with CH341A from hp elitebook 850 g3 with board 6050A2892401-mb-a01 and chip 25Q128FVPQ i uploaded here the file please help im stuck
          because i have erased the chip and i tried diferent bios bin files
          fan full load black screen capslock and numlock flashing
          best regard
            Originally posted by aknas View Post
            hello,
            best regard
            try..
              hello,
              thank you very much for help but didn't worked just flashed bios chip and placed on but laptop doesn't come on led flashing no fan. i used AsProgrammer with ch341a and by verification after flash have a error i add this in txt you can see in attachment
              best regards
                hello,
                best regards
                Try NeoProgrammer - https://www.badcaps.net/forum/showpo...04&postcount=7 NeoProgrammer
                If you still have verification issues the chip is bad .You have desoldered the bios ?
                  hello, i try it now, yes it is desoldered and i try with wires too because of not sure with the ground... the Neoprogrammer have there buttons UNPROTECT what to do with? there are SREG and edit sreg still doesn't work blinking white orange light i think im wrong with the bios because i have first time readed with CH341A Programmer v1.4
                    Hello friends ,, and I have the same problem .. There is a password on the BIOS. I tried the BIOS that friends put up here previously, but none of it worked
                    Motherboard number 6050a2728501-mb-a01
                    I have attached the original BIOS file
                    https://drive.google.com/file/d/11V2...ew?usp=sharing
                      https://www.badcaps.net/forum/showthread.php?t=79956
                        Hello. I buy an Elitebook 840 G3, 650a2892401-mb-a01 and the result is that I can always imagine a black pants and a fast fan ....
                        any solution? .. by sight I have some MX25L12805D chips, I have made a copy of both, I have tried several and I can't get it to work ... can someone help me? Thanks
                          post the bios backup.
                            I have lost the recoveries ... I no longer have any of the 2 ... can it be fixed in some way?
                              try this..
                                try this..
                                You are a genius. You fixed my laptop. I owe you a beer !! I love you!!!
                                  try this..
                                  what is that?
                                    what is that?
                                    enter the DMI information.
                                      has this, thank you very much.
                                        try this..
                                        Thank you peste, I had an 840 g3 which blinks 5 times and then blew very hard and with your file it is resuscitated
                                          Re: HP 840 G3 bios needed
                                          Os this the Right File to Flash Bios of hp elite Book 840 G3 ?
