Bosch AL 1830 CV(AL1830CV) blown fuse
  • otoluk
    • Feb 2009
    • 84
    • Latvia
    Another victim of planned obsolescence.
    BOSCH battery charger from year 2018.
    PCB
    1 607 503 091-C
    PCB4040 Rev0.4 CEM-1 1.6T 10Z
    2016-04-19
    Fuse blew with nice sound effects. Seems need to replace fuse and resistor. No schematic is available.
    Not sure what have caused this will try to replace 400v cap, resistor and fuse.
    • 31304
    Re: Bosch AL 1830 CV(AL1830CV) blown fuse
    R1 a MOV looks cracked,
    and check the diodes and whatever is on that heatsink for shorts.
    you have more bad parts - you need to find them.
    • otoluk
      • Feb 2009
      • 84
      • Latvia
      Have to also decode resistor near V5
        • 31304
        0.68ohms?
        • petehall347
          • Jan 2015
          • 4451
          • United Kingdom
          black blue brown gold 60 Ohms 5%
          if that's a gate resistor i think the fet took a hit .. best give it a look at anyway
          • R_J
            • 9633
            I suspect the resistor V5 is what stj said, 0.68 as it appears to be the source resistor, I would suspect the mosfet is shorted, D~S and may have damaged the drive transistor V6
            I suspect R1 is a NTC thermistor as it is in line with the a/c input not across it.
              • 31304
              yes, checked again - inrush limiter.
              and probably a good idea to point out that the primary heatsink is connected to rectified mains!!
              • otoluk
                • Feb 2009
                • 84
                • Latvia
                V5 Mosfet(ST P6NK90Z)is short on all pins.
                Mains cap(C2) is ok but while others are FZE, FZK and GF series this is noname Acon.
                Inrush limiter has same pcb coating which is cracked but part is ok.
                Thanks this was unusual as also it is isolated from V5 by
                plastic gasket. What for as it limits heat transfer?
                • Stuart Coyle
                  • Aug 2021
                  This thread just saved me a load of trouble. Have the same issue, with the FET blown and taking out the source resistor and fuse. The source resistor was so charred I could not read the code on it properly. 0.68 ohms matches the couple of bands I can see. Thanks.
                  • otoluk
                    • Feb 2009
                    • 84
                    • Latvia
                    Did you find a replacement FET or analog?
                    • otoluk
                      • Feb 2009
                      • 84
                      • Latvia
                      Replaced FET, R7 resistor, fuse and it is still short. Blew fuse and R1 thermistor(8S150L).
                      Need to look further.
                      You where right it was not so easy.
                      edit: two of IN4007R(or 1N4007 ?) diodes are shorted. Should I replace them all with UF4007?
                        • 31304
                        the group of 4 rectifying the mains?
                        you can use UF if you want, it costs more though.
                        • otoluk
                          • Feb 2009
                          • 84
                          • Latvia
                          Yes the group of four.
                          • magneh
                            Is this some kind of fuse resistor ?
                            by magneh
                            Hello guys
                            Taking a look at some KNX domotic modules that were toasted due to some kind of electrical failure, I found out 2 weird looking resistors.
                            Seem to me like some kind of fuse resistor?
                            After diggin a bit seems like a fuse wirewound resistor wafer or whatever that is
                            They are very toasted but I think the 5 band colours are RED GOLD BLACK ORANGE ORANGE or the opposite, not sure which is the first band.
                            The red band is larger than the 4 others, but I dont have much experience with these components.
                            Also one of the orange...
                            02-10-2025, 07:54 AM
                          • Babbar
                            by Babbar
                            04-12-2024, 01:12 AM
                          • beetle1303
                            Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
                            by beetle1303
                            I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
                            On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
                            01-13-2025, 08:49 PM
                          • bobby4star
                            BN44-00517C dead - blown cap, resistor and fuse
                            by bobby4star
                            Hi All,
                            I have a UE32ES6540 which is dead, customer reported a pop and a puff of smoke. PSU is BN44-00517C and has blown 221k 1KV cap, next to this a blown resistor RM811. Board mains fuse is blown.
                            Has anyone seen this problem and will changing the cap, resistor and fuse likely fix it? One more ask, can anyone give me a 2nd opinion of this resistor rating of RM811? I think it's 0.24 Ohms but would like a 2nd opinion! See attached pic.
                            Thanks!
                            Bob...
                            11-12-2020, 12:46 AM
                          • jesterace
                            Samsung UE46ES8000 Blown fuse but no other signs of short
                            by jesterace
                            Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                            09-11-2024, 03:14 PM
