Panasonic CF-54 Bios Password
    Re: Panasonic CF-54 Bios Password
    The contents of the file are garbage!
    You did not correctly think the BIOS was a programmer ...
      Hi.!
      Sorry I didn't understand U.
      I used CH341A programmer with same name of software v1.34
      I will try to reupload it again.
      BIOS IS mx25l12873f ??
      Thanks for advice!
        Originally posted by ibmlisek View Post
        Hi.!
        Thanks for advice!
        Try again , the dump you post is garbage
          Last try
          Now I use NeoProgrammer
          Dump below
          Thanks guys for your patience
            Last try
            Dump below
            Try this
              how to remove the bios password of panasonic CF-54 plz hellp
                Originally posted by sayed hashim View Post
                how to remove the bios password of panasonic cf-54 plz hellp
                post your bios backup here
                  Originally posted by medinfo View Post
                  Problem fixed
                  con u help me I have one cf-54 with bios password and i dont know how to remove it
                    con u help me i have one cf-54 with bios password and i dont know how to remove it
                    you have to read bios file with the help of programmer
                    from bios chip and send that file here some one will help you
                      Hi!
                      Could someone please remove the bios password from my bios dump or supply me with the password ?
                        Originally posted by deepblue74528 View Post
                        hi!
                        try
                          I am a poor bastard who had taken this Toughbook apart CF-54.
                          CF-54C9106CM
                          6ATSA3705
                          if i get it back together it will be a miracle..
                          any help would be appreciated.
                          I used neoprogrammer...
                            @jimdgroup
                            Keep looking for the bios chip, the dump file should be at least 16MB, none of the files you uploaded in ZIP file is near that size.
                            Upload better pictures of the motherboard and someone here may be able to locate it, try to take a full picture of motherboard and then one picture of each quadrant.
                            Have sent you a private message with a picture showing a possible location of bios chip, check and verify if it is.
                              I found it....
                              Here is the file...
                                Try:
                                  Worked Perfect
                                  Thank you very much..
                                    Hi i have panasonic cf-54 bios password, can someone remove it?
                                      backup bios and post that bin file here some one will help you out
                                        ok, is this what is needed?
                                          Try:
                                          Become a Badcaps supporter
                                          Thanks to all supporters.​
