ATX PSU Tester Analyzer modification / upgrade
  • dicky96
    Sun Seeker
    • Mar 2017
    • 1825
    • Spain
    Hi guys
    I have one of these ATX PSU Analyzers/Analysers Tester
    https://www.aliexpress.com/item/3280...73275478%22%7D
    The analyzer is very good for testing ATX power supplies - if they work! But it's pretty useless for testing them if they faulty. Which kinda defeats the object.
    The problem is caused by the fact the Analyser is powered from the 12V on the 20/24pin ATX connector. So for example if you have 5V Standby and nothing else, the analyser is dead, it does not power on. Even worse you can have all voltages present apart from 12V and the analyser still will not power on - leading you to believe you have a dead PSU.
    I recently wasted over two hours trying to fix a 'dead' PSU where I just could not find anything wrong, only to realise in the end it was working, apart from an open circuit track on the 12V output
    So I decided to modify the Analyser so that it will power up and work if any voltage is coming out of the ATX PSU, whether it is 5VSB, 3.3V, 5V OR 12V
    In fact it will now work with just 2.5V on any one voltage rail
    The modification cost just €0.70 in parts and fits inside the existing housing.
    If you have one of these analysers and would like to make it actually useful, then here is how I did it
    https://www.youtube.com/watch?v=yw747J-9F1s
    Follow me on YouTube
    Learn Electronics Repair
    • 31316
    Re: ATX PSU Tester Analyzer modification / upgrade
    interesting,
    i have one of those and thought it was using the 5v standby rail - gonna have to look in it now.
    i may also fit a switch on the control line to switch the main psu on and off.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8716
      would make sense if it were using 5VSB, because ATX PSUs won't work at all if 5VSB is dead as it's needed for !PSON ... silly to run it off of 12V...
        • Jul 2011
        • 6070
        Originally posted by dicky96
        Hi guys
        Thanks for posting this information this will help me a lot
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8716
          If you have one stuck using 12V I'd suggest trying to just make it work of 5VSB. Probably a lot simpler than any other solution? Unfortunately I don't have such unit to see what the "simplest" "fix" would be...
            • Jul 2011
            • 6070
            What about powering it with an external 5 volt power supply
            I have a couple of them I will try doing this and let you how well it works doing it this way
              • 31316
              why?
              if the 5v standby is missing then everything is dead and you have nothing to meter anyway.
                • Jul 2011
                • 6070
                Originally posted by stj
                why?
                All I am asking for now would it work if powered separately for now
                Would there be any issues to be concerned about doing it this way
                  • 31316
                  well - i'll open one and take pictures for you.
                  i'm personally more interested if i can find room inside for a rocker switch.
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8716
                    If you power it separately, the major drawback is that you'd need another outlet or a battery ...
                    Can't think of any reason not to power off of 5VSB other than if your meter draws more than 100mA - because ATX1.0 did not specify much current for 5VSB.
                    Hopefully bad cap ripple on 5VSB doesn't blow the tester...
                    • dicky96
                      Sun Seeker
                      • Mar 2017
                      • 1825
                      • Spain
                      The way I modified it was all internal and only cost €0.76 in parts
                      So now it will power up as long as any voltage rail has at least 2.5V. That could be further reduced to about 2.15V if using Schottky diodes
                      I also considered the fact that if it would work from 5VSB then that would be good enough as it is not possible to have any other rails if 5VSB is missing...... or is it?
                      I can conceivably see a case where this would not be true - and I mention this in the video
                      Most ATX PSU I looked at have two windings, or taps, on the 5V STB transformer. The second winding/tap is typically 12V-24V with it's own rectifier diode and capacitor, and is used to power the PWM IC and associated transistor circuit that drives the base of the output transistors via a transformer
                      So if there was a fault where there was an open pcb circuit track or similar between the 5VSB transformer and the purple ATX wire, it is likely that the 12V-24V internal rail would still be there.
                      And seeing as this anaylser starts the ATX by physically connecting the green wire to ground, and needs no voltage on 5VSB to do that - it is at least possible you could have an ATX PSU that has no 5VSB but still powers up with all other voltages present when connected to the analyser.
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8716
                        I really don't know why they used 12V to power initially, seems that you should be able to use 5VSB for nearly no additional cost, granted it will require it to be at least 3 or 4 volts for it to power whatever chips the tester uses. As said multiple times, ATX PSUs that don't have 5VSB working cannot turn on because that's what powers the !PSON - for both isolation and for keeping voltages within reasonable limits. Note that in the normal case, motherboards need 5VSB to power their switching circuitry, can't assert !PSON without any power.
                        It depends on the PSU design whether it uses two taps... isolation can happen with transformers or optoisolators.
                        • PeteS in CA
                          • Aug 2005
                          • 3586
                          • USA, Unsure of Planet
                          If it will work from 5VSB, you could always have diode-isolated "battery back-up":
                          PeteS in CA
                            • 31316
                            not that brand though - no DuraLeak.
                              • Jul 2011
                              • 6070
                              The reason I asked the question is if there is an issue with the standby circuit and provide more than 5 volts and you bypass the regulator because of low voltage rating for the meter parameters you might damage the tester
                              But in general I would agree with you that you could power it with the standby power supply output side but how do protect the tester from incorrect voltage from the standby circuit if has an issue
                              I would think that the meter module itself might not draw much current but the tester will put a load on the switching power supply output side of it
                              • eccerr0r
                                Solder Sloth
                                • Nov 2012
                                • 8716
                                As said yes a wayward 5VSB is a concern. Not like you completely remove the regulator, need to redesign it, perhaps with a shunt regulator to protect it. Have a LDO regulator there. Shouldn't be way too hard to protect against a wayward 5VSB.
                                  • Jul 2011
                                  • 6070
                                  Would this regulator work
                                  LP2950ACDT-5.0G
                                  • dicky96
                                    Sun Seeker
                                    • Mar 2017
                                    • 1825
                                    • Spain
                                    Can I just mention guys that my internal mod actually costs less than the 9V battery, Duracell or otherwise
                                    And you can't forget to turn it off
                                      • Jul 2011
                                      • 6070
                                      Or would this work on the 5 standby circuit just in case the voltage has gone to hell and remove the regulator that is on the board now one note I am also going to put a switch on the power ON wire so I can control it coming ON
                                      • eccerr0r
                                        Solder Sloth
                                        • Nov 2012
                                        • 8716
                                        Not sure if the TL431 is able to absorb the surge if 5VSB is considerably overvoltage... but yeah something like this, perhaps with a regular transistor as a shunt current amplifier.
                                          Modification done to a EBC-A40L 5volts Battery Capacity Tester 40A for less noise when charging / discharging cycles
                                          by sam_sam_sam
                                          When I first turned this battery testing machine the fan for the switching power supply was a little bit noisy but once I recapped the switching power supply board it quiet down considerably then I put a temperature controlled fan that does the mosfets control board was really noisy but now that it is cooled with temperature controlled fan that sensor was moved from the fan to the heat sink so now that the fan is controlled this way the fan runs according to the temperature of the heat sink
                                          This switching power supply was really fun to recap the quality of the board was very good...
                                          02-25-2024, 08:55 PM
                                        • Petr0x
                                          Bosch 12V and 18V chargers modification
                                          by Petr0x
                                          Hi, I would like to share with you small modification to your Bosch tool 12V and 18V chargers.
                                          You can use it for almost all Bosch chargers what I have seen, for example part numbers GAL 18V-20, GAL 18V-40, GAL 1880, GAL 18V-160, AL 1820, AL1115CV, AL1130CV.
                                          Bosch (today also other brands using the same system like Wurth, Fein) does not care if you destroy your batteries, because they can sell you new ones. So the marketing is telling you only about speed of the charging, so you will not wait for your batteries to charge too long. Me as a customer want the tools and batteries...
                                          05-24-2024, 01:00 PM
                                        • Teban1306
                                          [REQUEST] ThinkPad T14 Gen 1 (20S1) - Custom Boot Logo Modification
                                          by Teban1306
                                          Hello everyone!
                                          I hope this is the right section for this request. I'm looking for help to modify the boot logo on my ThinkPad T14 Gen 1.
                                          System Information:
                                          • Model: Lenovo ThinkPad T14 Gen 1
                                          • Machine Type: 20S1S4E600 (Intel i7 variant)
                                          • Current BIOS: N2XET42W (1.33) - Latest version
                                          • BIOS File: n2xuj25w.exe (12.98 MB) - Downloaded from Lenovo support
                                          What I'm trying to achieve:
                                          Replace the default "LENOVO" boot logo with a custom image during POST.
                                          🔧 What I've tried:
                                          09-14-2025, 11:49 AM
                                        • howardc64
                                          Don't probe Samsung LED conector with LED tester, connect may not make contact afterwards
                                          by howardc64
                                          Samsung have been using this style LED connector for few years now
                                          Usually good idea to test the LEDs before opening the panel to change them. I do this without the PSU stil connected. With this connector (white one) have to jam the LED tester probes in the very narrow thin slot where the PSU blade style male prong inserts into. I've done this on many Samsungs without problem until today...
                                          The female terminal inside the white connector has fragile fingers that grabs onto the male blades on the PSU's black connector. If the LED tester probe spreads open...
                                          10-12-2025, 08:13 PM
                                        • Lifeisfun
                                          Trying to troubleshoot DDR4 SODIMM slot with slot tester
                                          by Lifeisfun
                                          Hi folks!
                                          I have some kind of memory problem on Lenovo laptop. I was initially able to install windows after several tries since the laptop did freeze in middle of those attempts.
                                          Eventually I discovered that it was related to moving the laptop.
                                          Later on it even stopped booting unless I pressed around the memory slot. (no keyboard LEDs only power button responds)
                                          If I remove the RAM I get the beeps that RAM is missing. Inserting the RAM there is silence and it will not boot most of the time. No picture.
                                          I removed the board got one of those memory slot testers...
                                          06-04-2025, 02:26 PM
