Sony Hcd-Fxg9k No Power
  • DjKrish
    • Oct 2012
    • 354
    • SG
    Hi folks, i have a sony home theater here thats with no power issue for a very long time, probably due to lightning strike. I have sorted out primary and fuse no longer blows out. This unit has 2 STR IC, one is STRF6168 and STRV153. Both has been replaced, electrolytic caps has been replaced, a few smd diodes replaced and resistors replaced. The problem now is, on VCC of STRV153, voltage are fluctuating between 12v to 15v up and down. Theres no voltages at all on any of the output pins. I have checked all the smd components, all seems to be reading accurately. But i know there IS something thats preventing the STRF6168 to start up. VCC on STRF6168 is 2v. Any kind souls that has repaired this unit before care to shed some light?
  • DjKrish
    • Oct 2012
    • 354
    • SG
    Re: Sony Hcd-Fxg9k No Power
    Is Sony schematic diagram parts stated in service manual is accurate? Just wondering. I noticed a diode on the board and the diode stated on the service manual is not same even though parts location number is same
    • DjKrish
      • Oct 2012
      • 354
      • SG
      Anyone? Im going bonkers with this power supply When i remove the zener diode D924 which is 24v, voltage no longer fluctuating. Its stable at 13v. Am i missing something here?
      Or i have changed the wrong zener diodes on D923 (10V), D924 (24V), D925 (5.1V) and D926 (10V)?? I followed the voltage rating according to service manual. I also noticed certain components thats on the service manual doesnt exist on the board, so i assume this board being used on several models. So i suspect the ZD could be wrong. Even after removing that diode, theres no signs of any voltages on the output.
      • DjKrish
        • Oct 2012
        • 354
        • SG
        Nobody?
        • R_J
          • 9633
          Which voltage is now stable? the output 13.3 on the secondary? or the voltage on Q921?
          Why did you replace the zener diodes? where they shorted? or did you just guess they were bad?
          Have you checked the caps such as C922, C924
          Do you have any of the 4 secondary voltages on T902?
          If IC921 was bad, is R927 1Ω ok?
          • DjKrish
            • Oct 2012
            • 354
            • SG
            Primary side, all components tested, all good. Only standby section failing. Yes the diodes failed, so i replaced them according to service manual but i made a mistake, i forgot to see the number on the original diodes to make sure its same.
            • DjKrish
              • Oct 2012
              • 354
              • SG
              IC901, C908, Q901, IC921, C924, Q921, PC902, PC901, PC903 has been replaced, still no luck. Theres no whatsoever voltages on secondary side of the transformer. I replaced those diodes because they were bad. STRV153 was exploded, and R925 was open. voltage on Q921 seems stable at 13v upon removing D924.
              • PopsCaps
                Sony Bravia KDL-40V2500 that will not power on
                by PopsCaps
                I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
                I do not hear any sound and I cannot see any backlight.
                I have tried disconnecting every cable on each board one at a time to see if anything changes.
                The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
                My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
                03-25-2025, 11:23 AM
              • noinimod
                Sony 55X900E no standby light, no power. Replaced mainboard already
                by noinimod
                No standby red light, nothing
                This Sony has a separate AC->DC power adapter supplying 19.5V to the TV power board (JK3)
                Disconnected JK3 power board from main board, checked voltages on all the pin outs
                At a few pins I can see the power supply providing 19.5V to the main board
                Based on the service manual triage.. it seems to be pointing towards the power board (JK3) being the most possible culprit
                LED light turns on when I disconnect LED driver board ribbon from mainboard (so i thought it is the mainboard,...
                12-22-2021, 12:58 AM
              • bcstedt
                LG 42LB5D, 42LB5DF-UL, 2008-01, Power On Issue, Replaced PS Caps
                by bcstedt
                LG 42LB5D (42LB5DF-UL) from 2008-01, unit is in good shape and no obvious heat damage or cracked solder on the boards.
                Problem:
                On first power-up the power LED flashes green about 18x and then stays solid. No backlight or image is present. Click power button, wait 10s for a click and the LED turns red. Wait 1-2s and hit power again and maybe it'll power up fully after 6 green flashes. If it doesn't light up on the sixth flash then the cycle repeats.
                It seems that if the mainboard power is left on for a few minutes (solid green power, no backlight, no image)...
                01-18-2024, 01:03 PM
                by sam_sam_sam
                03-31-2024, 02:12 PM
                Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                by sam_sam_sam
                I was working on this CNC machine today found no keyboard functioning no control relay powering on
                The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                Found shorted diodes on main controller relays there are 3 of them that...
                01-07-2023, 05:43 PM
