Zotac 1660 ti Shorted
  • alekk89
    • Nov 2015
    • 32
    • United Kingdom
    I just got that 1660 that someone shorted by touching a metal plate to the back of the card.
    I found that U15 (ALNB 9614) has a hole in it. Any idea what that is so I can buy a replacement?
    Also, all these caps in the photo measure 0.2ohm which I suppose is short, as this is what my multimeter measures ground to ground as well. Measurement taken after taking off the burned IC.
    PN 9288-3n527-201z8
    board id 23a-DN527-101AF
    • 21439
    Re: Zotac 1660 ti Shorted
    You can just about see the AO logo at the top left corner,its an Alpha Omega OZ2261NQI
    Datasheet - https://cdn.badcaps-static.com/pdfs/...db75a86549.pdf
    0.2ohms is short,maybe a shorted cap somewhere
    • alekk89
      • Nov 2015
      • 32
      • United Kingdom
      Thank you for that!
      All 3 marked locations are shorted, should I assume that's short to the vcore?
      Can I inject 1 volt in on any of the 3?
      Update:
      Injecting 1v gives 6a and warm GPU
      • reessi
        Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
        by reessi
        Hello:
        I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
        I started on the ACER:
        Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
        All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
        I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
        10-29-2024, 11:31 AM
        NVIDIA GeForce GTX 1660 Schematic & Board View
        The GeForce GTX 1660 is a performance-segment graphics card by NVIDIA, launched on March 14th, 2019. Built on the 12 nm process, and based on the TU116 graphics processor, in its TU116-300-A1 variant, the card supports DirectX 12. This ensures that all modern games will run on GeForce GTX 1660. The TU116 graphics processor is an average sized chip with a die area of 284 mm² and 6,600 million transistors. Unlike the fully unlocked GeForce GTX 1660 Ti, which uses the same GPU but has all 1536 shaders enabled, NVIDIA has disabled some...
        10-02-2024, 07:44 AM
      • Zakyn
        MSI GTX 1660 Super - all rails shorted?
        by Zakyn
        I received a broken MSI GTX 1660S, not detected in the PC. There is no short circuit on 12v and 3.3v. 5V is present. So I moved to 1.8V, and it's missing, so no other voltages will be there. Against ground I am measuring 0.0ohms on 1.8, PEX, VMEM and VCORE. Is it dead core, or Turing GPUs has that low resistances? And its possible that it burned in a way that all rails are shorted? As sanity check I removed GS9216 buck converter and replaced it with new one but still no 1.8V. Can anyone please confirm that I can put this GPU away?
        01-12-2024, 02:55 PM
      • Yanleb
        Panasonic TC-P50S1 shorted TXNSC1EDUU (TNPA4782AB) SC Board
        by Yanleb
        Hi every one. I just want to share the successful repair of my shorted Panasonic TNPA4782AB SC board.
        I don't usually do it but so many parts were shorted that I decided to buy the ShopJimmy repair kit instead of sourcing each components individually. Here is the list of components the kit contained, with a remark indicating if I needed that part or not :
        D608, good
        D618 RF101L4S, good (See warning 1 below)
        D619 RF101L4S, good (See warning 1 below)
        D865 RF101L4S, shorted (See warning 1 below)
        IC464 Inverter HA MC74HC1G14, shorted...
        03-09-2020, 12:00 AM
      • youssou22
        Are these output caps supposed to be shorted on a Zotac 1050 ti
        by youssou22
        HI guys
        Am currently troubleshooting this zotac 1050 ti , I' ve noticed that the output capacitor are shorted none of the mosfet seems to be shorted supposing i tested them correctly am new to gpu mobo repair
        thanx in advance
        03-10-2022, 09:57 AM
