Need software for Intelligent universal programmer lk48
    • 31294
    Re: Need software for Intelligent universal programmer lk48
    the link in post #68 still works.
    • iMac
      • 6
      • Sweden
      #82
      I have download the V12.40 and the offset 03CDD0 is not 55 its c0. I use the Hex editor Neo.
        • 31294
        did you install it first?
        you patch the actual program exe file, not the installer.
        btw, you can also use the latest 12.60 i think
        • iMac
          • 6
          • Sweden
          #84
          Yes, I patch the installed exe file.
          Is the Dataman and Labtool program the same?
            • 31294
            are you using the XP version and not the UXP one?
            the patch is only for the 48XP software.
            • iMac
              • 6
              • Sweden
              #86
              Downloaded from the link in the #68 post.
                • 31294
                yes, but when you install it it creates 2 seperate exe files.
                i'll check it again later - i'll have to setup a damned windows laptop first though.
                not something i normally have here.
                • iMac
                  • 6
                  • Sweden
                  #88
                  It's only one exe file in the labtool-48UXP foler, WLT48UXP.exe for the V12.40.
                  • megaraider
                    • Jul 2015
                    • 307
                    • Portugal
                    #89
                    When you install you get 2 main folders: xyz-48UXP and xyz-48XP;
                    The 1st is for the USB programmer version, and the 2nd for the LPT programmer version;
                    The patch is only valid for the one on 2nd (...48xp.exe) not for the one on 1st (...48uxp.exe)!
                    • iMac
                      • 6
                      • Sweden
                      #90
                      it's only one folder C:\Program Files\Advantech Equipment Corp\Labtool-48UXP
                      Installed on a W10.
                      • megaraider
                        • Jul 2015
                        • 307
                        • Portugal
                        #91
                        it's only one folder C:\...\...\xyz-48UXP
                        Installed on a W10.
                        Install the version on the previous links, XP/Vista/7, only!
                        Use compatibility mode in w10 to install.
                        Please do us all an obvious favor:
                        Edit and remove all obvious strings: Advant3ch 3quipment, labt00l, ...
                        We really do not need the devil's search engine to find us...
                          • 31294
                          lol
                          posting a couple of hexadecimal numbers is not illegal - fuck them.
                          and iMac - use the latest version, not the old 12.40 one.
                          at the time i'm posting this, it's 12.60
                          • comatuning
                            • Jul 2022
                            • 6
                            • italia
                            #93
                            Originally posted by stj
                            lol
                            hi,
                            i have labtool 48 xp and i try to modify software.
                            but my problem is when install it. i have only one folder in my pc and offset on software have another value
                            help me please
                              • 31294
                              so your using LT48UXP_1300_WIN7.exe ??
                              • comatuning
                                • Jul 2022
                                • 6
                                • italia
                                #95
                                i try before 10.50 (for my use is good) and after other version, but whe install it, i have one folder with one exe (uxp)
                                Help me please
                                thanks
                                  • 31294
                                  on 13.00 try changing address 20591f = 55 >>> c3
                                  i cant test it, i dont have the programmer and using windows makes me want to throw the laptop at the wall!
                                  • comatuning
                                    • Jul 2022
                                    • 6
                                    • italia
                                    #97
                                    i dont have doble exe
                                    • comatuning
                                      • Jul 2022
                                      • 6
                                      • italia
                                      #98
                                      look this photo
                                        • 31294
                                        yes, in there is the exe file
                                        • comatuning
                                          • Jul 2022
                                          • 6
                                          • italia
                                          #100
                                          but is presente exe only uxp, not exe for parallel port. i have labtool with only parallel port because usb is dead. on old pc with XP work fine, but old pc is dead
