Thread Tools | Display Modes |
#21 | |
City & State: Durban
My Country: South Africa
I'm a: Knowledge Seeker
![]() Quote:
#22 |
City & State: new york
My Country: USA
#23 |
City & State: Lagos
My Country: Nigeria
#24 |
City & State: Lagos
My Country: Nigeria
#25 |
City & State: auckland
My Country: New Zealand
![]() What programmer interface for reading the chip please? Is the a socket for tl866 thanks
#26 |
#27 |
City & State: Chandler, AZ
My Country: United States
Line Voltage: 120VAC 60Hz
![]() Any programmer that can read/write to a 25 Series SPI FLASH should be able to interface with the T2 ROM. The CH341A chipset is utilized by most popular products that were developed specifically for the T2 ROM, but a TL866 should also be able to read/write to it so long as you use a 1.8v adaptor when reading it (or use an adaptor that has the 1.8v conversion logic built in).
#28 |
City & State: rawalpindi
My Country: Pakistan
#29 |
#30 |
#31 |
City & State: montreal
My Country: Canada
![]() Hi there, after using this kind of bypass (flashing the spi flash)
I have two issue: first is that mina/checkm8 give an error, something like "was not able to read from your t2 mac" And if i try to online restore it, i let me put the password for wifi, but after that it does nothing... Any advise? |
#32 |
My Country: Canada
![]() Ok after flashing spi back to stock, machine seems to pass this step witch make be belive that either its the issue with mina/check8 or maybe those sn are now blocked by apple...
#33 |
![]() anyone know the socket for the rom
#34 |
City & State: Ho Chi Minh
My Country: VN
#35 |
![]() I think the T2 unlock data for A1932 is blocked, that Serial number in the T2 unlock bin may be blocked now by Apple because cannot restore in Apple Configurator 2. Can anyone confirm if they have used it recently ?
#36 |
City & State: Lagos
My Country: Nigeria
![]() Maybe something is wrong with the file you're using. Try using your stock bin file with a Mina-fied (if you get what I mean) serial number, it should work.
#37 |
City & State: sydney
My Country: australia
![]() I used T203 for A1932 2018 model on 20/10, it worked well. Then I tried to use it for my A2179 2020 model, it gave error "not found SSH device, check it and try again". I got this error at the last step while the "minaT2activator" started running? anybody else has the same issue? Please share your solutions.
One more question here: Can we modify the serial number in those unlock data bin file, before we auto program the rom chip? Will the changing of the serial number affect the jailbreaking? All helps and discussions are welcome. David |
#38 | |
![]() Quote:
Any answer to this original question? If I modify the serial number in the unlock data bin file, will the iCloud bypass still work? |
#39 |
City & State: Windsor, Ontario
My Country: Canada
Line Voltage: 110VAC
![]() Hi. Also interested to learn if the T203 tool is suitable to remove password off A1932. Looking to purchase a broken A1932 from Ebay but only if we can get the password off the unit. Real focus is to learn on how to remove and replace the very thin LCD retina as compared to replacing the display assembly.
#40 | |
City & State: san diego
![]() Quote:
Thread Tools | |
Display Modes | |
