Decipher part of this please: 4.7U_0805_25V6K
  • cook
    Quiet observer
    • May 2010
    • 100
    From a Dell laptop schematic, they list this SMD capacitor: 4.7U_0805_25V6K
    I understand it all except the 6K at the end. What does that mean?
    4.7U is capacitance
    0805 is size of SMD capacitor
    25V is 25 volts.
    6K ???
  • s675
    • Sep 2015
    • 35
    Re: Decipher part of this please: 4.7U_0805_25V6K
    My ideas so far for the meaning of 6K:
    • Withstand voltage (6kV)
    • "Kemet code" (seen in some documents from Kemet)
    • 6 being unknown and K being 10% tolerance
    • Date code accidentally included
    • Reel quantity accidentally included (probably not, most are 5k, 10k etc)
    • PeteS in CA
      • Aug 2005
      • 3586
      • USA, Unsure of Planet
      There's no way a 0805 has terminals spaced far enough apart to handle 6KV without arcing. The "K" could be 10% tolerance. Or maybe "6K" could designate the tempco (though the terminology would be something like "X7R" or "Y5V" or "Z5U").
      PeteS in CA
      • cook
        Quiet observer
        • May 2010
        • 100
        In case it helps, the motherboard is a Compal LA-7781P - Dell Latitude E6430
        • R_J
          • 9638
          • cook
            Quiet observer
            • May 2010
            • 100
            Doing more searches on my question, I was able to finally find something that may make sense on this. A German site had my same question on it and they speculated that the 6K represented the minimum purchase quantity for the item. But I will continue to search on this and post any relevant findings.
            One other thing.... In the schematic for this board, they have many capacitors with this label... 4.7U_0805_25V6K~D I thought the 'K~D' was very interesting to note!
            • diif
              • Feb 2014
              • 6978
              • England
              I've seen some identified as 7U_0805_25V6-K and have also seen the 6 replaced with a 7.
              I'm with PeteS , K is tolerance and the 6 is the tempco.
              It's not ordering quantity.
              • cook
                Quiet observer
                • May 2010
                • 100
                A found a few charts listing the codes for temperature coefficient (tempco) for capacitors, but I'm not sure I understood what 6 actually stands for. It seemed that some of the coding standards had different meanings for a 6. Would someone have a link to an article or chart that would describe what 6 means in this situation?
                • edugimeno
                  Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
                  by edugimeno
                  Hi There!
                  I'm trying to help my friend who owns a restaurant be just bought.
                  He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
                  It's stuck using, I guess, the 2 sided tape that comes with the strip
                  The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
                  09-05-2024, 09:34 AM
                • G-Sting
                  iPad Pro A1876 SHORT Part Identify Help Needed
                  by G-Sting
                  So My iPad was not charging and booting up . i went to a local technician and he checked with thermal and this Part marked in 1st Photo is Short.
                  So then i went on to boardview and downloaded the schematics and identified this part in 2nd Photo. Now i am confused what exactly is the part called ? where should i get this from ?
                  i contacted my technician and he sent me his BoardVIew screenshot in 3rd Photo. In his Boardview the part is called X2826.... Something
                  SO My main concern is what part should i order what should i search the name for ?
                  on Ipad...
                  05-15-2025, 09:30 AM
                • Yanleb
                  Panasonic part number in service manuals
                  by Yanleb
                  In the Panasonic service manuals, both in the board schematics and in the part listing, the part numbers that are given are Panasonic part numbers instead of the actual part numbers.
                  This is especially annoying for small SMD components like diodes and transistors when you only have 1-3 digits printed on the component body.
                  For an example, look at the attached PDF.
                  Do you have a way to cross reference the Panasonic part number with the actual part number?
                  Thanks....
                  07-03-2023, 08:16 PM
                • FreakyMex
                  Trouble to identify part (Lunii screen) for replacement
                  by FreakyMex
                  Hello guys. I'm a complete noob in electronics. I'd like to repair my child Lunii's (a "story box"), basically an audio player that allows the childs to choose between several options the places, characters, objects of the story, and then play a story according to the choice of the child. There is a screen that display the selected option before each choice. The Lunii fell and the screen is now broken.
                  I'd like to repair it (probably just have to change the part, because the lunii still works perfectly fine) but I can't manage to identify the part/order it online. Do you have any...
                  02-17-2025, 01:16 AM
                • ty34
                  Dell Latitude 5530 part info required (PU4501)
                  by ty34
                  I have a broken Latitude 5530 with a damaged part which is marked PU4501.
                  The laptop wont turn on and i can only assume this part is the reason!
                  Can anybody supply a manufacturers name and part number so i can swap it out, and hopefully get a working laptop?
                  11-04-2025, 03:30 AM
