Duracell Battery Charger - CEF22GBL-3
  • Ritchie_Uk
    Prawnography
    • Mar 2021
    • 185
    • Uk
    Hi there - I am searching for a Duracell CEF22GBL-3 Battery Charger
    Its nothing SPecial, but on this Charger, there are 4 AA Bays and 1 9Volt Bay.
    The 9 Volt has stopped working, but the Rest seems Ok.
    1. Does anybody have a Schematic for this please, as I dont want to throw it away?
    • Jul 2011
    • 6069
    Re: Duracell Battery Charger - CEF22GBL-3
    Post some pictures of the board both sides of it
    • Ritchie_Uk
      Prawnography
      • Mar 2021
      • 185
      • Uk
      Hey Sam_Sam_Sam I will do,
      I have been engrossed in trying to repair this.
      It seems to have a Processor IC.
      This is the Model, well mine is a lot older, but looks almost identical
      https://uk.rs-online.com/web/p/battery-chargers/7698761
      Will Post Pics in a minute
      • Ritchie_Uk
        Prawnography
        • Mar 2021
        • 185
        • Uk
        Here are the Photos
        In Pic 2 D5 and Q1 have been taken off
        The Main Semiconductors are
        Big IC - IC EM78P374NS024J
        Input Area - AS393M
        Input Area - A04409
        I cant seem to find Schematics anywhere for this unit.
          • Jul 2011
          • 6069
          This part number does not come back with anything
          EM78P374NS024J
          Either it is in-house part or some other issue
          • redwire
            • 3912
            EM78P37x is Elan Microelectronics 8-bit OTP MCU, I think 4KB ROM for the 374.
            It's a MCU custom programmed for this application. You'd have to draw the schematic, I've never seen anything published out of china or taiwan for fear of copying.
            There's really no solder on the through-hole pad by R49 to B1N, and bad soldering to big through-hole parts is a common problem to look for.
            How are the electrolytic capacitors? It is powered by a wall wart? Wondering if it has the 9V power it needs.
            • Ritchie_Uk
              Prawnography
              • Mar 2021
              • 185
              • Uk
              Hi Sam and Redwire - Thankyou
              I have gone through every component, and they seem fine/
              The 9V section isnt working.
              The EM7 seems to be here and "Seems" to look similar
              https://datasheetspdf.com/pdf/924729...cs/EM78P374N/1
              Its Cheap and throw away, but I dont want to throw it away, even tho I already have some new chargers I have ordered.
              • Ritchie_Uk
                Prawnography
                • Mar 2021
                • 185
                • Uk
                ps I am running the Charger with my PSU, its 12V and about 1 Amp
                • Ritchie_Uk
                  Prawnography
                  • Mar 2021
                  • 185
                  • Uk
                  What’s useful?
                  • redwire
                    • 3912
                    Just a spammer.
                    Does the charger have a single 9V port? You could follow that back to the PC board and see what mosfets they are using for switches there. I imagine it's easy to connect one backwards and maybe that damages a unit?
                    • Ritchie_Uk
                      Prawnography
                      • Mar 2021
                      • 185
                      • Uk
                      Thankyou Redwire
                      Sorry for the delay in responding, but I have had so many shifts in the last week.
                      I need to focus on the circuitry,, and try and work iut why the 12 Volts befor the diode is Ok, then After the diode, which I am unsure of they type, possibly a Zener is Zero volts.
                      It seems like the main IC is really complicated for what it does, as I have had the charger for at least 10 years.
                      The clue could be that I have had so many problems with the 9 Volt section anyway.
                      It’s incredibly complicated for a small unit.
                      I remember reading the fact that Duracell don’t build there own units, but the exact clone is under another name,
                      I forgot but will search my web history
                      Will keep yiu updated
                      • Ritchie_Uk
                        Prawnography
                        • Mar 2021
                        • 185
                        • Uk
                        ps Redwire it can also Charge AA and AAA and the massive ones no one can ever remember what they are called ��
                        • redwire
                          • 3912
                          Duracell does have a long "guarantee" on these I think 7 years so maybe hit them up for a replacement. Not sure how they are in the UK for consumer protection.
                          Wild guess is whatever modulates the 12V down to 9V, might have croaked. Like a small mosfet. But the charger also has some safety routines in the MCU so it will not initiate charging unless safe (i.e. sees say 6V) and the current is not too high. So your charger circuit might work fine unless you fool it properly with a dead 9V battery, or spoof it.
                          • Ritchie_Uk
                            Prawnography
                            • Mar 2021
                            • 185
                            • Uk
                            Hi Redwire
                            Bless, you this Charger is the Workbench first thing in the morning, as I wont let it beat me.
                            I will keep you updated, as I am off for 2 days now
                            Regards
                            • Ritchie_Uk
                              Prawnography
                              • Mar 2021
                              • 185
                              • Uk
                              Hi Redwire - As promised an update
                              I have made contact with some helpful people who will attempt to source a schematic for me,
                              If they manage, I can pass whatever data and info if you need.
                              Regards
                              • Ritchie_Uk
                                Prawnography
                                • Mar 2021
                                • 185
                                • Uk
                                Hey Redwire - The Unit is Working now as I believe the Diode I removed was intermittantly breaking down.
                                Under normal conditions I found no components Shorted / Open, which was frustrating.
                                The only thing I havnt tested is whether it shuts off when the Battery is Full.
                                The 9 Volt is Charging, but the Charging light stays on.
                                Its amazing how complicated the Logic section is.
                                I still havnt recieved the Schematics yet, but if you need any Schematics, and I have many please just ask, as I have 1000's and 1000's
                                Regards and thanks for your response
                                Stay Safe
                                • Ritchie_Uk
                                  Prawnography
                                  • Mar 2021
                                  • 185
                                  • Uk
                                  ps - If you look at Photo 1 of 4 it was Q1 and the Diode just above it that was breaking down
                                  Sam-Sam-Sam also I really appreciete your help as well
                                  • redwire
                                    • 3912
                                    I bought an Energizer ENC-2A car battery 2A charger/maintainer and played around with it and found out the software was terrible.
                                    It would not start charging unless the battery passed a little test it did. Firmware looked at battery voltage and tried charging for a couple seconds and if it was not satisfied, it went into a fault/lockout condition and you'd have to reboot it to do anything else.
                                    I took it back to the store for a refund because it would not charge gel cells or anything sulfated, and it also had a bunch of software timers where it would charge for a minute then think it's done.
                                    It's not going to burn the house down or wreck the car so why all the bimbo firmware? They must get paid a lot whoever designs these in china.
                                    • Ritchie_Uk
                                      Prawnography
                                      • Mar 2021
                                      • 185
                                      • Uk
                                      Redwire oh really?
                                      Weird that they used software, would an Op Amp or Comparitor have done the trick?
                                      Ansmann and a Dlyful - The Ansman is really over priced and not great if you need advice or support.
                                      The Chinese reverse engineer things, some of the designs I have seen were so bad that we sent people over to oversee them
                                        NVDC charger configuration...
                                        11-05-2024, 03:28 PM
                                        ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
                                        Highly Integrated Narrow VDC Battery Charger for Notebook Computers
                                        The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
                                        for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
                                        Narrow VDC applications where the system power source is
                                        either the battery pack or the regulated output of the charger.
                                        This makes the max voltage to the system equal to the max
                                        battery voltage instead of the max adapter voltage. Operating
                                        at lower system voltage can improve...
                                        11-05-2024, 04:43 PM
                                      • flat-earther
                                        how to prevent a connected charger from draining battery when not charging?
                                        by flat-earther
                                        I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                                        So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                                        but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                                        So the battery is backfeeding the charger and being drained.
                                        How can I prevent...
                                        08-07-2025, 01:04 PM
                                      • Bowline
                                        by Bowline
                                        06-11-2025, 10:13 AM
                                        Bauer tool battery pack charging with a HERCULES charger modification
                                        by sam_sam_sam
                                        The Bauer power tool battery charger just has to many issues with the charger over heating because I several HERCULES Hercules battery chargers that are 3 amp charge and because they have gone on quite a few times over the years before they came out with the fan cooling battery charger I going to modify one so I can charge Bauer battery packs faster than the crape battery charger that they have
                                        Here is how this modification is going to be done I taking a 1.5 amp hour battery enclosure and gutting it removing the battery cells and replacing some Ryobi 1.5 amp hour battery pack that...
                                        05-06-2023, 12:17 PM
