Corsair CX400 with bad OST RLX capacitors
  • rsuga
    • Nov 2021
    • 4
    • Brazil
    A bit off-topic but I just wanted to share my experience with this power supply. I've owned it for almost 10 years now with moderate usage (daily, but no OC). Had to replace the fan and the OST RLX series caps (the blue ones), which failed on me twice (one cap was bloated, the other one was bad but didn't show visual signs).
    I read somewhere in the forum that these blue OSTs were crap, and I can confirm I had two failures. Of course I've been using them for a long time, but still...
    I replaced the first one with Nippon Chemicon KY series (the only good ones I could find, general purpose but still rather low-ESR), and the second one with a new RLS series I had around (I hope it won't fail at least in a couple of years). Probably not the best recap but it's been working well.
    This PS also sports additional OSTs RLSes in the outputs which I preemptively replaced with Rubycon MCZs.
    Moderator note: split this discussion off from the original thread here: https://www.badcaps.net/forum/showthread.php?t=49596
    Also note this thread might also be relevant: https://www.badcaps.net/forum/showthread.php?t=68294
  • PeteS in CA
    • Aug 2005
    • 3581
    • USA, Unsure of Planet
    Re: Corsair CX400W 5vsb goes into safety loop
    Actually, NCC KY series are low impedance, high ripple current parts, probably a good choice. As for the Rubycon MCZ, that might be "too good", and it might not be great in a P/S. If I recall correctly, it's an ultra-low impedance part, and that could affect the stability of the control loop. Also, the water-based electrolytes in ultra-low impedance parts don't do well in hot environments, which the output sides of P/Ss tend to be (hot rectifiers, hot output inductors, and an output harness that impedes airflow).
    PeteS in CA
    • Behemot
      • 4845
      • CZ
      I have a feeling that those ostors are ultra-low ESR, Seasonics puts few of them in their OEM units for some reason.
      • rsuga
        • Nov 2021
        • 4
        • Brazil
        Many thanks for the feedback, I was not aware of these potential issues w/ ultra-low ESR caps in SMPS, and it does make a lot of sense. These RLXs are indeed ultra-low ESRs.
        I'll look into removing the MCZs in the upcoming months then. I'll see if I can find KZEs or KZHs around, would those be better replacements? Thanks again.
          • Jul 2011
          • 6070
          KZE are available but not in all UF values I will use KZE or KY or the automotive type of LXZ and LXY and had no issues using any of these series in switching power supply
          • Behemot
            • 4845
            • CZ
            yo ignoring me post for what reason?
            • rsuga
              • Nov 2021
              • 4
              • Brazil
              In my previous post I replied I confirmed the RLXs were ultra-low esrs, I just didn't quote you as I replying to a previous message.
              Appreciate your and Sam's input on this. Thanks again.
              • Behemot
                • 4845
                • CZ
                so why exactly yo want to replace anything when its working there in milions of units for over a decade now, FROM THE FAB? if those MCZs don't already have 12 years of use on them, I see no reason to replace anything
                • rsuga
                  • Nov 2021
                  • 4
                  • Brazil
                  If you check my original post above, you'll see the original ones are not MCZs but stock OST RLSes w/ 10+ years which I replaced preemtively (w/ the MCZs) together with the two failed OST RLX caps (the blue ones).
                  What PeteS in CA conveyed makes a lot of sense (ultra low ESRs where we had low ESRs, water-based electrolytes), so that's why I mentioned I was considering replacing the MCZs again sometime in the future.
                  Tx.
                  • dragon3x
                    After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
                    by dragon3x
                    Hi, I have some 32 bits computer motherboards that need repair, as they fail to
                    power on.
                    Here are some examples :
                    (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
                    switching supply area).
                    (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
                    than 6.3 V.)
                    1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
                    I replaced capacitors with aluminum-polymer.
                    3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
                    03-21-2025, 02:46 PM
                  • slybunda
                    AA and AAA battery charger capacitors?
                    by slybunda
                    hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
                    it has inside:
                    2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
                    2 x 470uf 16v LZ105c branded as G.Luxon
                    not heard of these brands are they any good?
                    iv attached photos of the charger and the board inside for an idea on the type of...
                    12-24-2023, 04:41 AM
                    by sam_sam_sam
                    After all of...
                    07-13-2024, 08:14 PM
                  • Cama
                    Solar Inverter - SMH-II - 2 missing capacitors
                    by Cama
                    I need help to find the value of 2 missing capacitors ( C102 and C117) on my Easun SMH-II mainboard (solar hybrid inverter). I circled it in red on the close-up picture. The 2 old capacitors are completely missing, so I have no reference. Does anyone have this board and can tell me the value or make an educated guess based on the location ?
                    My model is : EASUN SMH-II 7 KW
                    Mother Board : P/N 18947-002401250250
                    Maybe the EASUN SMH-II 4.2 KW have the same capacitors
                    Thank you...
                    09-12-2025, 02:50 AM
                  • Ady2017
                    Are there any datasheets available for Elna RJG capacitors?
                    by Ady2017
                    I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
                    05-25-2025, 02:19 PM
