RCUnlocker
    Re: RCUnlocker
    Hello all,
    I've try to run RCUnloager on my HP EliteBook 820 G3 but I keep on getting averification error.
    Here the screenshot of the successful RCUnlocker
    Here the NeoProgrammer Verification Error screenshot
    I've also attach the extracted bin file from the WSON8 chip call org.bin as well as the RCUnlocker output org_unlocked.bin
    Any help our guidance on the verrification error would be greatly appreciated.
      Re: RCUnlocker
      I have been trying to use this software ( by dropping the locked bios dump file on it) however I keep getting an error (missing un lockable content). could anyone kindly advise what am i doing wrong?
      Thank you in advance
        Re: RCUnlocker
        Do not open the RCUnlocker, just Drag and drop .bin file to .exe file.
        It will create a new file in the same directory as your bin file. It will be named [BinFileName]_unlocked.bin
          Re: RCUnlocker
          Your verification has nothing to do with the unlocker. It's just that ch341a can be quite unreliable. Check your connections.
          Missing unlockable content means the program didn't find any keywords it was looking for. That suggests you are trying to unlock something which either is not supported or you just have a faulty read.
          So maybe help us and give some more information. Like what are you trying to unlock and what is your file like.
            Re: RCUnlocker
            I believe you were replying to my post. I'm not knowledgeable in this area, so I'm not sure if you were able to see that their was some missing unlockable content.
            I'm not trying anything fancy.
            1. I'm reading the BIN from the WSON8 chip
            2. Saving it to HDD
            3. Unlocking it using your program.
            4. Loading the new BIN_unprotected
            5. Cliking the verify, and that is when it fails
            Maybe I'm missing a configuration in the NeoProgrammer?
            If anyone could try it out to see if your able to unprotect and verify without verification error that would be really appreciated.
            org.zip
            thanks for your help and support
              Re: RCUnlocker
              Might be a stupid question but... Have you tried programming instead of just verifying?
                Re: RCUnlocker
                Same error as it is trying to verify before programming the chip
                  Re: RCUnlocker
                  Thank you for your reply, this is what im trying to do im dragging the file and doping it on the exe file but instead im getting this mesg missing unlckable content. Is this software compatible with windows 10?
                    Re: RCUnlocker
                    Korreia, please describes what steps you take. It should be read, verify, patch, erase, write, verify.
                    adil12, as I said, you either have a faulty read or you are trying to unlock something which is not supported. So please do help me help you. What are you trying to unlock? Upload your file. Did you verify your readout?
                      Re: RCUnlocker
                      Tank you Sir, that worked, I was not erasing.
                        Re: RCUnlocker
                        Do what it says. Read the 16MB chip and use that instead of 32MB chip...
                        hi Sir
                        Would this work with your tool ??
                        copy the last 16MB Hex code ( 1000000h lenght ) from the 32MB file and paste it in a new empty hex file in any hex editor and save it, then use the RCUnlocker to unlock the saved file (16MB), then in the original 32MB dump paste/write the last 16MB with the generated file,
                        would like to try it but i have no case for now on which i can test that.
                        will appreciate it a lot if you can test that, thank you very much in advance, if no time for that just ignore my request will test that whenever got a case with 32MB and 16MB ones .
                          Re: RCUnlocker
                          Hahahaha. The issue is that you need to modify 16MB chip. Yes, there is a way to do it using the 32MB chip but not like this. Why don't you just patch the 16MB chip? Too difficult to unscrew the motherboard?
                            Re: RCUnlocker
                            Not difficult at all, i always got all the boards out of the cases before dealing with them, it's just i have no case to test that at the moment, there's a way of doing it on both chips in fact, it's just an idea that crossed my mind and i will test it for sure whenever got a case with 16/32MB chips;
                            Thank you for answering
                            have a good day/night, bye
                              Re: RCUnlocker
                              Try this instead.
                              not work for me
                                Re: RCUnlocker
                                Your tool works on the older generation of Probooks but i can't get it working on g8 as both ec and spi roms are 32mb, i might need some help from someone more skilled than me. If anyone could give me some advice or give me a hand, i would really appreciate !
                                I'm attaching the dumps from my computer in case you want to have a look at it !
                                Thank you !
                                  Re: RCUnlocker
                                  ALRAHI, you did not follow instructions.
                                  Asachan, thanks for the files. I've never seen a G8 so I'll take a look at the files soon. S
                                    Re: RCUnlocker
                                    Hello RethoricalCheese and thank you ! If you need any more informations let me know ! I try to unlock it by myself too, i'll let you know if i find out .
                                    I'm also looking for an unlocked g8 spi and ec dump to compare them but no chance so far !
                                      Re: RCUnlocker
                                      [QUOTE=RethoricalCheese;1089066]ALRAHI, you did not follow instructions. this error is coming please help
                                        Re: RCUnlocker
                                        Can somebody help me, why I'm getting "VCRUNTIME140.dll was not found" error?
                                          Re: RCUnlocker
                                          Looks like your Visual C++ had problems.
