Can i replace XMC qh128ahig with winbond q128fv?
XMC qh128ahig
Tags: None
Re: XMC qh128ahig
check datat sheet w25q128 pin 4is ground xmc pin 4 is vss but both chip same 16mbComment
Re: XMC qh128ahig
whats wrong with the qh128ahig chip,can`t your programmer read it,does your programmer have it in the support list.What model is your programmer,and software.What motherboard,intel or AMDComment
Re: XMC qh128ahig
even svod3 with latest software and firmware cannot read this maybe this chip is brokenComment
Re: XMC qh128ahig
The TL866cs doesn`t support it.I don`t own a SVOD3 but afaik you can add chips manually. Or,choose a different chip from the list and untick check-id ,such as W25Q128JVSIM https://www.winbond.com/hq/support/d...rch=XM25QH128A
The ch341a supports quite a few XMC chips,with NeoProgrammer and ASProgrammer software.
Datasheet attachedAttached Filesif you find these attachements useful please consider making a small donation to the site
Re: XMC qh128ahig
Maybe.Remember the bios can have important DMI information, do everything you can to try and get a good read.Sure you can use another bios chip,and if there is some DMI missing or a windows key ,then you`re just making another problem,and more work for yourself.If the bios chip really is faulty then yeah,you have no choice.Comment
Could someone provide us with the Colibri programming software? or could you show us a video of how to read it with the ch431 programmerComment
by javieromex
Hi, do you know what component this chip refers to? I need to replace it. It appears to be a 3V power supply in LA-M786P Motherboard in HP OMEN, but I don't know which one to replace it with. Thanks.... -
by javieromexHi, do you know what component this chip refers to? I need to replace it. It appears to be a Schottky diode, but I don't know which one to replace it with. Thanks....
by jordanaudio1Trying to learn electronics repair as a hobby. I have no formal training in electronics, circuits, etc. Everything I know, which isn't much, has been learned from watching youtube videos, reading books, forums, etc. This means, sometimes I have a hard time understanding and interpreting what's important when I look at datasheets, and such.
My brother has a TV that I'm working on now. He said he was watching it, he heard a loud pop and it went off. I used my DMM to check the fuse, it was blown. From watching lots of hours of electronics repairs on youtube, I figured that was just a...07-07-2025, 07:38 PM -
I hope someone can help me.
I have an Asus ROG Strix Scar 18 (G814JZ) laptop with a Winbond 25Q16JWNIG chip on the motherboard.
Unfortunately, I flashed the wrong file (BIOS/EC/other region – I'm honestly not sure anymore), and now the laptop is completely dead: no display, no fan spin, no reaction at all.
I have a CH341A programmer and I'm able to read and write to the chip. However, I'm not sure which software is best (AsProgrammer, NeoProgrammer, etc.) or if there's anything specific I should watch out for.
A valid BIOS/EC backup...-
Channel: BIOS Requests ONLY!
by Ady2017I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
Channel: General Capacitor Questions & Issues
- Loading...
