Post IDs of obscure polymer caps
  • mockingbird
    • Dec 2008
    • 5484
    The polymer section at http://capacitor.web.fc2.com/solidcapacitor.html is getting a bit long in the tooth now, so it would be good for members to post IDs for polymers they come across if they have the opportunity:
    I'll start:
    The brand is "Polycap", their website is http://www.polycap.cn.
    Series in a nutshell:
    RL - Ultra Low ESR
    RG - Low ESR
    RS - Higher voltage Low ESR
    RN - Miniaturized for tighter fits
    RF - Low ESR and 5000 hours
    Please feel free to contribute and grow this thread if you have ID'd previously unknown polymer caps. Thanks.
  • mockingbird
    • Dec 2008
    • 5484
    Re: Post IDs of obscure polymer caps
    Next we have "JB" Brand CS series caps. They are generic Chinese SMD electrolytic caps and not polymers, and they're found in Uniden phones (Good phones otherwise, they just need their caps swapped, unlike VTech which is garbage).
    There is one lone cap in the cordless phone itself, and one or two in the corded base unit. The rest of the base unit electrolytics are all radial through-hole.
    • mockingbird
      • Dec 2008
      • 5484
      Up next is the Gemcon PM series polymer capacitor, with a 5000 hour endurance rating:
      The capacitor looks ok on the inside, I would rate this brand as adequate.
        by momaka
        03-12-2025, 03:42 PM
      • Perry Babin
        How do organic polymer caps compare to liquid electrolytic for reliability
        by Perry Babin
        I have a situation where a power supply is commonly abused and the 12v supply caps take a beating. They don't commonly fail but they run hot. I was thinking about going from a liquid electrolytic (Panasonic FC and Nichicon HE) to an organic polymer. The values have been 330uF. I typically use a higher-than-needed voltage to get a lower ESR. The supply is operated from 12v.
        If not organic polymer, what would be the caps that could take the most abuse?
        08-18-2025, 04:04 PM
      • eryjus
        by eryjus
        05-10-2023, 11:21 AM
      • Paxman_Swede
        by Paxman_Swede
        Hello!
        01-14-2025, 09:51 AM
      • captain150
        by captain150
        03-16-2025, 07:34 PM
