EUREKA! Yours truly may have just figured out how to unlock an M1! I am doing more stress testing boys but you might just see the first M1 unlocked that is activation locked! I will give more details soon when we get a few more M1's to test this out on! It is a hardware unlock so just be mindful as I trial and error this stuff!
Macbook M1 Unlocked!
Re: M1 Unlocked!
I've got M1-s aswell and not afraid to break them for science
So if you need testingpower, let me know.
Re: M1 Unlocked!
I will say this once I unlock it completely and it works 100% I will create a video for the forum but would like this to stay here for the time being so Apple doesn't patch this. It could POTENTIALLY be patched and this unlock will not work anymore. So it is best to keep it hush hush for now until we can determine what needs to be done. So far so good but I have my doubts on the integrity of the process if Apple does a patch to the M1 chips with some stupid hardware update that locks it back who knows.sigpic
MEOWING IN THE IMPOSSIBLE UNIVERSE!Comment
Re: M1 Unlocked!
Currently M1 no have solution.When M1 possible jailbreak then possible all what we want like Mdm,iClouds.I will say this once I unlock it completely and it works 100% I will create a video for the forum but would like this to stay here for the time being so Apple doesn't patch this. It could POTENTIALLY be patched and this unlock will not work anymore. So it is best to keep it hush hush for now until we can determine what needs to be done. So far so good but I have my doubts on the integrity of the process if Apple does a patch to the M1 chips with some stupid hardware update that locks it back who knows.
But now Apple update New Mac os then also not work jailbreak T2 Macbook.Comment
Re: M1 Unlocked!
The M1 does not work like the T2. It is similar in style on how it needs to go on the server to activate first. But you need to consider that these boards do have vulnerabilities.
All software and hardware is crackable. NO MATTER HOW SECURE IT IS, it will always in life be cracked. We just need to find the backdoor solution or the key to the house. That is the reason why we repair and try to mess with our devices we own.sigpic
Re: Macbook M1 Unlocked!
Anxiously waiting for this one. By the way, is anyone willing to share what chip M1 stores serial information like the U4770 in T2?Comment
m1 serial is in the nand (ssd) but change serial has no effect! same as t2 change serial no effect, the only way they change serial is for free use mina bypass
icloud linked on serial, wifi adres and mac adres, when you change this 3 things you can unlock (but the 3 numbers must match and icloud free)
Does mina bypass work for M1? If so, I could alter the serial and go on with bypass. The reason I was asking to know where the serial is stored is because I intend to get past MDM lock.m1 serial is in the nand (ssd) but change serial has no effect! same as t2 change serial no effect, the only way they change serial is for free use mina bypass
icloud linked on serial, wifi adres and mac adres, when you change this 3 things you can unlock (but the 3 numbers must match and icloud free)Last edited by curiositymaster; 12-06-2021, 05:47 AM.Comment
search nand roms ( 2 pieces) read data (not the userdata its encrypt) but the hidden partition, there you can find the serial and a lot of other info, you must desolder onboard read/write no succes yet, buy bga 110 adapter and jtag programmer or nand programmer (jtag is cheaper and also good)Comment
by bouchhi
i whant unlock macbook pro A1932 2019 whit ibridge 9,3 ;
i change efi files find on files mina T2 activator 1,4 and use for activation mina T2 activator 1,3 , but fault ssh?
i use mina T2 ramdisk activator 1,0 and 3,0 . but whon t work ?
have you other programme or method compatible whit this macbook ibridge 9,3 for bypass ?
I need help or information?
Does anyone have the minat2 activator 1.4 software?
Or did they use it for bypass macbook air 2019 a1932 with new ibridge 9.3?
Thank yo...-
Channel: BIOS Requests ONLY!
03-12-2025, 10:14 AM -
by keats11I was hoping someone could point me to a tutorial on MDM unlock. Basically, I picked up a Macbook (A1989) from someone which did not have OS installed. The guy said it started software update and but did not finish. Long story short, the touchbar on this device has some kind of a short, so after unplugging it, I was able to install the OS on it, when I found out that it is also MDM locked by his company. I tried changing the serial number on the ROM by only changing a couple of digits of the original serial number. Now after installing the ROM back, the Macbook appears dead = DFU mode. When I...
by Flasman90I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
- "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
- "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
...08-30-2025, 10:27 AM -
by tobeend1. RESET MACOS WITH IPSW
a. Power off MacBook, press and hold the power button to enter Recovery
b. Open Disk Utility, remove Macintosh HD
c. Reboot, connect to the network to Activate Mac.
d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
e. Release the other keys, but keep holding the Power key for another 10 seconds
f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click... -
by SarcasticOPI am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
- PPBUS_G3H (12.6V-12.8V)
- This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
- PP3V42_G3H (3.42V)
- This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
- PPVRTC_G3H (3.3V)
- This
- Loading...
