LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal
    Re: LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal
    Originally posted by Markus1741 View Post
    Try ...
    Maybe its in the EC
    EC: ITE IT8996E-256/DX
      Hey everyone, first of all thank you all for your help. I have a thinkpad p1 gen2 that i tried using someones previous bios file but now I have a black screen and boot loops. By any chance anyone have a stock bios file? (And/or a patched file? As it previously had a supervisor password)
      Thank you!
        Originally posted by el panke View Post
        hi, for some reason i cant get this done, cant make it boot or show something after paching it (works with the original and blocked bios if i put back)
        any1 could do me the favor and pach this image?
        lenovo T440p
        found 1 pachd but its 4mb
        any1 plz?
          Originally posted by ak1_2004 View Post
          attached
          @ak1_2004
          Checksum correction
            Originally posted by onizzbox View Post
            @ak1_2004
            Checksum correction
            Hi
            Dont work
            dont show anythings !
              Hi
              Dont work
              @ak1_2004
              So we don't have any doubts, go back with the original file, see if the laptop is still working. I will redo the patch.
                Hi
                Dont work
                @ak1_2004
                One more important detail, it is normal after the patch for the laptop to turn on and off up to 5 times... It is necessary to wait for this process.
                  Hi
                  Dont work
                  @ak1_2004
                  try
                    Hi! I can't patch bios dump, plz help
                      Lenovo A475
                        Originally posted by pir0 View Post
                        Lenovo A475
                        @pir0
                        Try
                          Hello. I have a problem with password bios in lenovo e595 NM-C061.
                          Can help somebody ?
                            Can help somebody ?
                            @makar303
                            Have you tried auto-patch at the beginning of this thread?
                              @makar303
                              does anyone bother reading the 1st post. does anyone share anything back with the community....
                                @ak1_2004
                                try
                                Not Work !
                                But i use this attached bios and show me on first run application menu !
                                i try patech this with autopacher but dont work bios and can not boot laptop !
                                  Ok, sorry, i will try to do patch.
                                    @pir0
                                    Try
                                    After flash this dump laptop dont bootup, only sound signal and black screen
                                      @pir0
                                      Try
                                      Thanks a lot! Everyrhing is working! I did something stupid - I forgot to install a RAM module
                                        Hi All!
                                        thank you for sharing this patcher stuff. My success story and some usefull experience follow.
                                        I had a locked Edge E145, TL866 II+ Programmer and SOIC8 ICP clip for it. To obtain a BIOS image I have to desolder Flash Memory's Chip VCC pin - just to disconnect Programmer's VCC from the Mainboard. All other pins were left intact.
                                        I read an original image, patched it using the autopatcher and flashed the patched image back to the mainboard. I have restored Memory's VCC and tried to start the laptop. Saw usual boot messages, request to press <F1> for entering Setup and .... black screen after pressing the F1 key. Many attempts with the same result make me a bit disappointed. Thankfully I have found an another way to the password screen - at the some stage of "normal" booting without pressing F1 the message about "Press Enter to break normal startup" was shown (the message was exact or similar to it) - I did it and become an opportunity to enter Setup from an another Menu. The password screen was here! I entered usual password "123", follow all steps as described in the Readme and, finally, a got message about removing TPM certificate!!!
                                        And now I have two identical E145 - a first one with ruined bottom case part and the second one bought for some coins on ebay as a spare parts donor for the first one. ;-) And both are working now so I not need to carry it from one room to another - there is already a laptop in every room. ;-)
                                        Thanks a lot! And Happy New Year!
                                          Thanks and happy new year
