Dead but clicking Hanns-G HC194D?
    master hoarder
    • May 2008
    • 12176
    • Bulgaria
    Re: Dead but clicking Hanns-G HC194D?
    You might be able to do that but it could cause more damage too.
    Better would be to lift the input leg of the 7812
    Then power it up and see what voltage you have on the input then.
    I agree.
    Just remove the 7812 regulator and see if the PSU can start up.
    To remove the 7812, first unscrew it from the heatsink. Then, using a sharp blade or flat screwdriver, separate it from the heatsink (otherwise it might be a little stuck due to thermal compound.) After this, put a blob of solder over its leads on the bottom and pull it out. Should come out fairly easily.
    Once the 7812 is out, plug in the PSU again. If the 12V rail is still reading low, try putting a load on the 5V rail (like a 12V PC fan or two or perhaps a car 12V incandescent light bulb rated for 1-3 Watts) to see if the 12V rail goes up.
    • Donny2derby
      LGOLED55B7V Clicking and dead screen.
      by Donny2derby
      Picked this up other week and when I originally looked at in the sellers house I got 3/4's of a working screen and some horizontal lines across the 1/4 of it which was dead/black.
      Just tried powering it up at home and now all I'm getting is a clicking and some very faint lines on 1/4 of the screen whilst the entirety of it is dead.
      When using the remote I get two red clicks on the standby. Not sure if this means anything or helps. The same when I use the manual power up.
      Help appreciated. I'm an electrician, I've fixed a few in the past so not a total...
      08-10-2023, 04:23 AM
    • Sisko
      Onkyo-593 No power and now clicking sound
      by Sisko
      Hi all!!
      Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...
      10-03-2025, 02:18 PM
    • double_DD
      How can I be sure that my EC chip is dead?
      by double_DD
      As the title suggests, how can I be sure that my EC chip is really dead?
      I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
      Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
      03-12-2025, 07:47 AM
    • B0r1s
      Samsung UE49KS7000SXXH - fast clicking sound in standby mode
      by B0r1s
      PSU - BN44-00878A
      Symptoms:
      The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
      A weak clicking sound was coming from the transformer.
      Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
      Progress:
      After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
      01-17-2023, 04:58 PM
    • pni
      Lenovo ideapad3 15ada05 touchpad doesn’t work the clicking
      by pni
      Hi, I bought this laptop Lenovo ideapad 3 15ada05. The problem is on the touch pad. Everything works good also the touchpad. But when I click and I hear the sound of the clicking on the touchpad I don’t have nothing…all work but the clicking no…I tried to update bios, reinstalling window 11, update the driver on the Lenovo site. But nothing. The clicking didn’t work, someone can help me thanks
      12-08-2025, 07:21 AM
