VIZIO TV (Model:VL370M) Display not working
  • L3git
    • Jan 2022
    • 22
    Hi everyone! First I'd like to say I'm a newbie here on the forums and as well as repairing electronics so please bear with me. Just for clarification the only experience I have is replacing batteries in iPhones and also don't know how to do soldering. So aside from that I'd like to know if it's possible to repair this TV with no experience/ technical knowledge. The TV is a VIZIO VL370M and had for over 10 years. It was working until one day when I turned on the TV all I see is vertical gray lines and they're also moving across the screen. I've attached some pictures showing it. I have no clue what's the issue with it and would like suggestions on what I can do and if it's repairable. Thank you for the feedback and trying to help me out! Much appreciated to you all!
  • lotas
    • Jan 2016
    • 4708
    • Russia
    Re: VIZIO TV (Model:VL370M) Display not working
    This can happen if liquid gets on the panel and leaks onto the cables with decoders.
    • dskall
      • Oct 2016
      • 2905
      • usa
      Do you get a menu?
      • L3git
        • Jan 2022
        • 22
        Hm I see, haven't spilled anything on or in the TV ever since I had it. Also maybe condensation got inside the TV?
        Also I don't see a menu as it's just gray lines moving across the screen
        Thank you both for for the feedback!
        • lotas
          • Jan 2016
          • 4708
          • Russia
          Check the LVDS cable, its connectors on T-CON.
          • dskall
            • Oct 2016
            • 2905
            • usa
            The good news is this doesn't seem to be a bad panel. But a board or connection issue.
            • L3git
              • Jan 2022
              • 22
              Ah okay, don’t know where to find that cable but I’ll see if I can open up the TV and then I’ll take pictures of the inside. Also that’s good to hear that the panel might be still good, I was afraid the panel is bad.
              • L3git
                • Jan 2022
                • 22
                Hi all I'm back and I got some pictures of the circuit boards on the back of the TV. Let me know if you need more pictures
                • L3git
                  • Jan 2022
                  • 22
                  Here's more
                  • dskall
                    • Oct 2016
                    • 2905
                    • usa
                    On first picture. Remove and check, reseat cable between that board and mainboard. Unhook two cables on bottom of picture one at a time and check tv picture. Turn off tv each time before you disconnect cable.
                    • L3git
                      • Jan 2022
                      • 22
                      As per instructions , So I reseated the cable between the board and the main board. After that I unplugged both cables at the bottom. Then I unplugged each bottom cable one at a time and turned on the TV. This is what I got. 1st picture is left cable unplugged and 2nd picture is right cable unplugged.
                      • dskall
                        • Oct 2016
                        • 2905
                        • usa
                        Next I would suggest heating up your mainboard processor. If nothing changes there. It's down to checking voltages. I would start at t-con, first picture. There is VGH,VGL, VCC, VCOM that I see
                        • L3git
                          • Jan 2022
                          • 22
                          Um yeah I don’t have a heat gun and don’t know how to do soldering. Sorry if I didn’t mention that before. I was thinking is it possible to replace one of the boards to fix it?
                          • dskall
                            • Oct 2016
                            • 2905
                            • usa
                            I hope you have a multimeter.
                            • L3git
                              • Jan 2022
                              • 22
                              Yeah I actually have a multimeter
                              • L3git
                                • Jan 2022
                                • 22
                                Hi there! Just let me know how we proceed using the multimeter, thank you!
                                  • 12212
                                  • U.S.
                                  Good video there, just be careful what you touch there's DEADLY voltage on the hot side of the powerboard and the inverter, he's checking the voltages in the first part of the video, He is a good teacher, works at a steady pace that even beginners can grasp, consider subscribing and donating: https://www.youtube.com/watch?v=gRDZ...teY5Gw&index=2
                                  • L3git
                                    • Jan 2022
                                    • 22
                                    Hey everyone, So I have good news I've bought a new tcon board and replaced the broken one and now my TV works again! Yay! for educational purposes I'd like to know why the tcon board is broken. I still took down the voltages of broken and working tcon board in the attached pictures. Also another question is the differences in the tcon boards (top is broken and bottom is working) I've noticed is some of the test points are soldered in the working one as opposed to the broken one, would've me possibly soldering made it work? Just some questions I have as I'd like to get more knowledgeable in this. Thank you for the feedback by the way!
                                      • 12212
                                      • U.S.
                                      maybe check all the test points and see if there's any differences if you havent already.
                                      • dskall
                                        • Oct 2016
                                        • 2905
                                        • usa
                                        Looks like VGH is the problem. Should be 20- 30v.
                                        • jayakumar
                                          dell 5490 la-f401p no display ( in HDMI out working )
                                          by jayakumar
                                          I have dell 5490 la-f401p problem: no display ( in HDMI out working )
                                          changed working bios ,working screen ,cable
                                          Please help me to resolve the issue
                                          i have more then 7 laptop's having the issue
                                          08-06-2024, 10:03 PM
                                          LG Ultra Notebook Specification for Upgrade or Repair
                                          This specification for the LG Ultra Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra boardview and Ultra schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for LG Ultra Notebook is accurate,...
                                          09-06-2024, 07:20 PM
                                        • modtool
                                          Macbook Pro 14 2021 - A2442 - 820-02098-A - Internal display not turning on but MacOS working good
                                          by modtool
                                          Dear collegues,
                                          the owner of this machine brought it to me saying that suddenly one day the display didn't turn on anymore, he tought that all the machine was damaged but it turned out that the MacOS starts good and stays on, and that connecting it to an external display it works without problems.
                                          If you take a look into general settings, you can also see that the internal retina display is recognized as connected by the main board but for an unknown reason it doesn't turn it on.
                                          I've tried to put a bright light towards the screen but I can't see anything, any shadows or apple...
                                          05-08-2024, 05:50 AM
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
                                        • Mark R
                                          Equipment Display Types
                                          by Mark R
                                          Most Displays I have worked with are of course LCD Or Blueish Fluorescent Types. I Have a Marantz PMD800 tuner with sort of a white display. The display area is a sealed rectangular shape in a Glass Case. Looks like some sort L.E.D. display only not your typical section number type. I picked up this Tuner cheap as the display is very Dim. In front of the circuit is a dull red Plastic lens.
                                          The display is very week and hard to see. I've got my DC 5 Volts allover and also a DC 32 Volt that runs some other section. Power supply looks good front to back. Not familiar with this type...
                                          06-07-2024, 07:19 PM
