Laptop power brick audibly noisy
  • jayjr1105
    • 281
    I wired this up with a apple airport cable so it would fit my Pinecil soldering iron and not have a stupid heavy ferrite bead at the end near the plug. The noise changes depending on the load. With a 9w load it's less frequent and with a laptop 50w+ load it's higher pitched. If I press on the transformer with something plastic it also gets a little quieter. Any danger here? Am I actually hearing the switching of the FET? It's like tapping not really squealing like coil whine.
    I realize it's probably a low end little brick but it came apart super easy without any cracking or melting of the case so I decided to use it. I probably have a dozen other 19v 3a bricks I could use instead if this is a hazard.
    Ryzen 3600x
    16GB Patriot 3600MHz
    MSI B450 Gaming Plus
    MSI Air Boost Vega 56
    Acer 32" 1440P Freesync
    Rosewill Capstone 750W
    Hakko FX-888D Station
    FX-8802 Iron
    MG Chem .8mm 63/37 RA 2.2%
    • 31294
    Re: Laptop power brick audibly noisy
    well squeeling is often bad caps early on.
    in this case i would get shot of that bs mylar snubber cap and fit a 2KV ceramic - while it's out you can check the associated resistor
    • jayjr1105
      • 281
      Definitely not cap squealing. It's coming from the transformer it would seem. It's like a soft rapid tapping.
      Ryzen 3600x
      FX-8802 Iron
        master hoarder
        • May 2008
        • 12175
        • Bulgaria
        I think that's normal?
        Reason I say that is because my Aoyue 2900 soldering station does the same thing - sounds like light tapping/clicking, and it is synchronized with the PWM pulsing of the station's tip-diving MOSFET. And likewise, the sound is coming from the transformer on the station... though in my case, it's worth noting that the 2900 / CS2900 uses a classic line-frequency transformer rather than an SMPS.
        In any case, though, I've had that station since ~2012. So if it hasn't failed after 10 years, I suppose it's OK.
        It looks OK.
        Transformer looks big enough and also probably has OK primary-secondary insulation.
        Seems like you've already recapped it with good caps (minus the mains, but that's probably OK for a good while usually.) Therefore, I don't expect you'll see any major failures, if at all.
        As long as the adapter uses some kind of current-mode PWM controller to drive that MOSFET on the primary, it should be decently safe enough to use. But if it's a 2-transistor self-oscillating design, I'd definitely not advise to leave it plugged in unattended.
        • jayjr1105
          • 281
          It looks OK.
          It seems to have quieted down a little but still that light tapping. I've actually used it for the past couple days to power an old 2010 laptop which I use for my USB microscope and no issues. It gets warm but that's with a 40-50w load. How can I tell if it's a 2 transistor self-oscillating design?
          Ryzen 3600x
          FX-8802 Iron
          • PeteS in CA
            • Aug 2005
            • 3586
            • USA, Unsure of Planet
            ... How can I tell if it's a 2 transistor self-oscillating design?
            A quick clue would be if there is no PWM IC and if there is no all-in-one TO-220 switching regulator IC (e.g. Power Integrations' TinySwitch or TopSwitch ICs).
            Backing up a bit, your picture in the OP shows the adapter is a flyback design (no output inductor). On the secondary side you'll probably find a TL430 or TL431, which is connected to an optocoupler. The optocoupler could provide a feedback signal to a PWM or all-in-one, or it could drive the turn-off transistor in a two-transistor design.
            In a flyback topology, the "output transformer" is actually a coupled inductor. The primary winding serves as the inductor, and the stored energy from each "on" cycle is coupled into the secondary circuit.
            PeteS in CA
              master hoarder
              • May 2008
              • 12175
              • Bulgaria
              Just see if there is an SMPS IC on the bottom of the PCB (specifically on the primary side.)
              *EDIT*
              I guess PeteS beat me to it.
              • kaboom
                "Oh, Grouchy!"
                • Jan 2011
                • 2507
                It's one of the cheaper "laptop replacement" power supplies.
                Almost the same board as one I scrounged for parts, bigger transformer, same heatsinks- just wider, and the same lack of input filtering/inrush limiting.
                The small cap for the PWM IC is suspect, no matter what the markings are (can be fake).
                Use a 22-47u 50v 105 degree, such as PW, HE, FC, FR. For the output caps, use the largest value at 25v that physically fit.
                I like FR here, large capacitance for their size & low ESR/hi ripple to handle that flyback supply.
                Looks like the caps are 680u/25v.
                Try for 1000-1500u/25v, again the largest value that fits.
                Also tie the EGC from the AC inlet to the DC side negative.
                Looks like you've got a 3-wire AC inlet with the GND unconnected!
                IIRC, the control IC works like a 384x. It's a 6 or 8 pin SMD part on the back of the PCB.
                I'm pretty sure the 8-pin version does not share the 384x pinout!
                I find the output rectifier to be a weak link in these- change it to a 100v/20A schottkey or SBR part.
                UFs or FRs have higher Vf and the heatsink gets hotter.
                This is a drop in, complete with isolated tab:
                https://www.mouser.com/ProductDetail...OZiNSM5g%3D%3D
                Get one while you can...
                re: the noise. It's likely you're hearing the PWM modulate as the iron pulses the element.
                But change the caps anyway; again, they're known to be questionable in these "replacement power" adapters.
                Is that small cap original? "Looks like" a Panasonic FC- did you change it already?
                The transformer should be OK. I see what appears to be nice layering & teflon tubing on the lead wires.
                "pokemon go... to hell!"
                EOL it...
                All style and no substance.
                guilty,guilty,guilty,guilty!
                guilty of being cheap-made!
                • jayjr1105
                  • 281
                  Okay, front TO-220 shaped device is "First" 16T41 - FIR8N60F and Secondary side is also "First" branded 16M01 - MBRF20100
                  Ryzen 3600x
                  FX-8802 Iron
                  • yaya3gmax
                    Laptop Power Issue – Works on Battery, Fails on Adapter Load
                    by yaya3gmax
                    Dell laptop (E7440, uses the notorious CD3301B power controller + MEC5075 EC + BQ24715 charger IC)
                    Symptoms:
                    • Laptop works normally on a pre-charged battery.
                    • Battery does not charge when adapter is connected.
                    • Without battery:
                      • Laptop powers on from DC adapter, passes CPU/RAM init checks, then cuts DC power abruptly.(seems to shutdown one of the mosfets in the charger path). Then the loop continues indefinitely
                      • Speakers “pop” when power cut occurs indicating harsh sutdown.
                      • If RAM is removed, the system shows RAM missing blink error code indefinitely without cutting DC power
                    08-21-2025, 07:16 AM
                    Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook Specification for Upgrade or Repair
                    This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
                    09-06-2024, 09:30 PM
                    Microsoft Surface Laptop Surface Laptop 2 Notebook 2 Specification for Upgrade or Repair
                    This specification for the Microsoft Surface Laptop Surface Laptop 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 2 boardview and Surface Laptop 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                    09-06-2024, 08:47 AM
                  • RdeveLabs
                    MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                    by RdeveLabs
                    To all the members here...
                    Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                    So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                    05-05-2025, 04:59 AM
                    Microsoft Surface Laptop Surface Laptop 4 Notebook 4 Specification for Upgrade or Repair
                    This specification for the Microsoft Surface Laptop Surface Laptop 4 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 4 boardview and Surface Laptop 4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                    09-07-2024, 06:11 AM
