Replacing Fake Sanyo's in a SMPS
  • jayjr1105
    • 281
    I have a cheap chinese T12 soldering station that I really like and use a lot. It has (clearly) fake Sanyo WG caps (1000uf 35v) on the secondary side that I'd like to replace with authentic caps. What should I use?
    They are 10mm width but could probably squeeze in 12mm caps and they are super short for a 1000uf 35v cap but I could probably fit 30mm max height.
    It also has an unpopulated spot so I assume 3 good ones can make up for two. I have some KZE 35v 680uf. Even with three would I be okay on capacitance?
    Ryzen 3600x
    16GB Patriot 3600MHz
    MSI B450 Gaming Plus
    MSI Air Boost Vega 56
    Acer 32" 1440P Freesync
    Rosewill Capstone 750W
    Hakko FX-888D Station
    FX-8802 Iron
    MG Chem .8mm 63/37 RA 2.2%
  • redwire
    • 3912
    Re: Replacing Fake Sanyo's in a SMPS
    The enclosure sets a height limit about 27mm. Caps were talked about in this thread and Panasonic FS 10x25mm 1,000uF 35V was suggested. I would put in the "optional" 3rd cap as well.
    I am still running the original (fake?) caps they only see part-time 6A load. The 22uF has to go lol.
    What version PSU is that? I drew schematics of V2.04, V2.05 power supply but they are bigger (no need to fit big IEC) and look like the same circuit.
    • PeteS in CA
      • Aug 2005
      • 3583
      • USA, Unsure of Planet
      If it gets hot inside the enclosure, KZE and other water-based electrolyte caps might not do well. Nichicon PA series caps would be the closest non-aqueous low impedance parts, and PW or UCC LXZ the next closest non-aqueous series.
      PeteS in CA
      • jayjr1105
        • 281
        This is not the normal KSGER T12 unit. It's the one with 3 digit 7 segment display. It was a kit and I think it was $23 total or something super cheap. Unfortunately it didn't have the same wiring as the KSGER handles so the KSGER handle I bought (blue and black one) needed to be rewired and the reed switch was in a different place too. Otherwise I love it.
        Ryzen 3600x
        FX-8802 Iron
          • 31289
          FS is the only cap that is small enough.
            • 31289
            Quicko ??
            • jayjr1105
              • 281
              Originally posted by stj
              Quicko ??
              Whatever this is
              Ryzen 3600x
              FX-8802 Iron
              • redwire
                • 3912
                It should be using the usual extruded aluminium enclosure and I measured max. 27mm height so 25mm high caps will fit fine in there.
                https://www.badcaps.net/forum/showthread.php?p=901736
                It's the enclosure length that seems to come in long (with mains PSU) and short (controller only with DC jack on the back) sizes.
                Did you check if the secondary-side is PE grounded? I see the jumper blob at the GX connector so hopefully that works.
                • jayjr1105
                  • 281
                  Those Panasonic's are impossible to find and don't have a restock data until December. I just used the chubby 680uf 35v KZE's I had. They fit fine with some angled installation.
                  Ryzen 3600x
                  FX-8802 Iron
                    master hoarder
                    • May 2008
                    • 12175
                    • Bulgaria
                    Yeah, that should be fine.
                    I'm pretty sure the fake Sanyo's are nowhere near as good as the KZE's, so those KZE's should be OK.
                    • frannyjunk
                      Vizio M60-C3 Replacing 1000uF 16V with 1000uF 35V capacitors?
                      by frannyjunk
                      Hi, my Vizio M60-C3 does not power on. No lights whatsoever. Upon opening up the TV, the power supply board has 4 bulging capacitors. Each is 1000uF 16V. I have read that one can use capacitors of the same uF and higher voltage rating, but is 1000uF 35V capacitor too high of a voltage rating? My local shop only has these higher voltage capacitors so would rather just buy the 35V variety if it is OK to use them.
                      Any thoughts if OK to use these higher voltage capacitors?
                      11-04-2021, 05:59 PM
                    • dkneyle
                      Onkyo DX-V500 Laser Disc Player - weird SMPS fault
                      by dkneyle
                      This relic from a technology path that came to a dead end (but still has historical interest) was brought in with a dead SMPS, which is based around a MK1210 device. I got it going after a battle. It seems to have a strange design - if it's not getting feedback that the secondary is OK it cause the big FET to go into full conduction and overloads resulting in a blown fuse at best or something worse! I'm using a Dim Bulb Tester (70W/230V) which thankfully has saved the day a number of times whilst repairing.
                      Now, it loads a CD OK. The motor voltage output (which is built onto the SMPS...
                      02-01-2022, 02:08 AM
                    • shamsudeen
                      Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                      by shamsudeen
                      Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                      I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                      i know that in linear power supply the noise will be very low comparing to SMPS supply....
                      07-19-2025, 07:14 AM
                    • MMH3
                      Dell Precision 3450 small form factor - BIOS cannot be opened in FIT - please help clean
                      by MMH3
                      i would appreciate, if someone could help me.
                      DELL: 3450 sff
                      Servicetag: (!) obviously FAKE - ABC2345
                      Mainboard: 0GK35Y - serial /ABC2345/CNFCW0023800L6/
                      Chipset: Intel W580 (Rocket Lake PCH-H)
                      BIOS: 1.34.1
                      ME: 15.0.50.2633
                      mor data can be found the HW-Info-data in the rar-file
                      I have this BIOS from a DELL Precision 3450 SmallFormFactor mainboard i bought refurbished.. from china.
                      The board itself works without any issues.
                      My goal was to clean the ME of this and fully...
                      09-13-2025, 11:54 PM
                    • abhishekkumar1902
                      Huntkey HK340-72FP SMPS shut on load above 2 amps
                      by abhishekkumar1902
                      I have this Huntkey HK340-72FP PC SMPS where I am facing a strange problem where the SMPS shuts down when the load on any of its 12v output rails goes above 2 amps while the rating of each 12v rail is above 10amps capable.
                      I have checked the following:
                      1. All output caps are OK, and all output rails read correct voltages at no load
                      2. All output diodes are OK
                      3. NTC is ok
                      4. Hi voltage cap on input correctly reads 150uF on LCR meter per the spec, also the bridge rectifier is OK
                      5. No short in main switching MOSFET
                      6. All other components...
                      12-18-2022, 09:52 AM
