TV Plasma LG 60PN5000 ZSUS 15v missing
  • alfredomfr1
    • Oct 2014
    • 318
    • usa
    All Voltages are OK except ZSUS 15v.
    YSUS board disconnected still 15v missing.
    ZSUS was replaced: 15v missing.
    Any help will be appreciated
  • Biruslapio
    • Nov 2013
    • 552
    • Brasil
    Re: TV Plasma LG 60PN5000 ZSUS 15v missing
    15V is produced by Y-SUS, so follow the traces on that 15V pin and see where it leads.
    Never power up a plasma with loosened or missing screws on any sustain boards.
    • alfredomfr1
      • Oct 2014
      • 318
      • usa
      I will check the Y-SUS
      • alfredomfr1
        • Oct 2014
        • 318
        • usa
        3ohm R251 Open, Replaced.
        Now I have 15v but fluctuating to 16v and 15v and a metallic sound like tin, tin tin. All other voltages fluctuating a little bit but in range.
        • alfredomfr1
          • Oct 2014
          • 318
          • usa
          There is not green light on the control board and the TV red light is blinking
          • Biruslapio
            • Nov 2013
            • 552
            • Brasil
            Further inspection on y-sus is required, test every IGBT and gate drivers for shorts, big resistors (those green ones) cannot be open.
            The inductors on Z and Y buzz when working, but it's at a low frequency.
            • alfredomfr1
              • Oct 2014
              • 318
              • usa
              D603 shorted
              After replace D603 TV works well but instead of measuring 15v it measures 17.8v
              • Biruslapio
                • Nov 2013
                • 552
                • Brasil
                If memory serves correct the 15V on LG plasmas is almost always close to 17V, so 17.8 is a small offset from the norm, no need to worry if nothing is overheating and the picture is fine. Is D603 at Y-SUS?
                • alfredomfr1
                  • Oct 2014
                  • 318
                  • usa
                  Yes, it is. Thanks for your help.
                  • PlasMatt
                    LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
                    by PlasMatt
                    I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
                    09-20-2025, 06:50 PM
                  • Salvatore057
                    plasma TV Lg 42w451 - why is the zsus igbts damaged when the ysus is plugged?
                    by Salvatore057
                    I am trying to fix my plasma TV which is not powering on due to damaged IGBTs. I have changed two igbts and 2 IC drivers on the zsus and also two igbts on the ysus.
                    Now everytime I plugged the ZSUS and the YSUS boards to the power board, the two 30f124 IGBT on the ZSUS are damaged and the TV stays in standby mode. When I plug the ZSUS board alone the TV turns ON but I do not see pictures. When I plug the ZSUS board without the two 30f124 IGBTs and the YSUS board, the TV powers on with a picture.
                    I am lost, should I change the YSUS board? Is the YSUS board damaging...
                    04-29-2018, 01:29 PM
                  • ugamazing
                    820-02020 PPBUS_AON missing
                    by ugamazing
                    Board had no history of liquid; unsure of drop history, but no signs of damage of any kind worth noting.
                    Charger sitting at 5v/0a. PPBUS is at 1.9v-0.9v steady cycle (peaks, drains, loops). Confirmed CHGR_EN_MVR is missing, but DCIN was reaching ISL just fine, so replaced ISL--no change at all. Confirmed pp3v8_aon is also missing--and being unsure *exactly* which signal appears first (or if they are simultaneous), I inspected PMU/U8100 area and found no shorts, but also found PP3V8_AON_MPMU_ISNS_VIN missing (not shorted). Replaced U8100 just in case (have had them fail in weird ways),...
                    02-05-2025, 04:21 PM
                  • jpreza
                    Apple NVIDIA AGP GeForce 6800 GT Dual Link DVI+DVI outputs 603-6338 missing caps!
                    by jpreza
                    I recently acquired this card from a seller who was selling a PowerMac G5 for parts. He mentioned that the video card was probably broken too.
                    Upon closer inspection, I can tell the reason why it won't work: it's missing a bunch of CAPS! (it's also missing an inductor - 1.0uH).
                    It's a nice card as it's one of the few AGP cards that will support 2560 x 1600 resolution on a PowerMac G5 using a 30" Cinema Display.
                    Looking at the card, it appears to be missing the following:
                    1x 1.0uH inductor - orange square
                    2x...
                    11-01-2024, 10:54 PM
                  • gurj1979
                    Asus Zenbook UX431DA / UM431D - Ryzen - missing PWM Fan Signal.
                    by gurj1979
                    Hey guys.
                    Need help with this one.
                    Fan not spinning due to missing PWN Fan signal.
                    Also 5 seconds from powering up it freezes, unless in BIOS.
                    But as soon as Windows starts to load, it will freeze.
                    CPU is COLD / Room temp when it freezes.
                    I've replaced the CPU, same problem.
                    Replaced SIO/KBC IT8987e and reprogrammed - same problem.
                    Replaced fan - same problem.
                    Replaced flex cable from board to daughterboard (which has fan connector on it) - same problem.
                    Checked the Thermal sensors around CPU and Board to the SIO/KBC and...
                    08-19-2024, 05:22 PM
