What is this part? (OG XBox Delta PSU)
  • Frampton
    • May 2022
    • 6
    I'm in the process of restoring an original XBox. It's a 1.6 unit with a Delta "D" power supply. I removed the unit and was inspecting for damage when I noticed something that looked...melty at the very back of the unit. Assuming that melty = bad, I desoldered the part with the intent of replacing this tiny, screw capped thing. I have no idea how to describe what this is though. I think it's used to make very small voltage adjustments? I'm 100% guessing though. Any help would be appreciated, pictures attached.
    Also don't mind the crud, I already have a kit to replace the caps and clean the rest of the unit up.
  • CapLeaker
    Leaking Member
    • 8352
    Re: What is this part? (OG XBox Delta PSU)
    It’s a variable resistor.
    • R_J
      • 9624
      That may just be glue to seal the controls position
      • Frampton
        • May 2022
        • 6
        I see, thank you!
        I guess my follow on question is what kind should I be replacing it with. I googled variable resistor 501 (like what's on the board) and found some very very similar looking parts. On Amazon, for instance, I found this. Will any variable resistor in "501 Trimpot" configuration work?
        Last question is the replacement process, I assume by its variable nature that the resistor would need to be dialed in, I just have no clue how to do that. Anyone have any pointers?
        • R_J
          • 9624
          VR501 is the pot location, not it's value, check it with a meter or look for numbers printed on the pot. Are you sure it is bad, as I doubt it is burnt.
          I see other pictures that have the same sealant on that pot
          • Frampton
            • May 2022
            • 6
            I have not tested it, I'll give that a shot. I made the assumption it was bad based on the corrosion present. It is not the only thing in this poor xbox that is rusted, I assume the previous owner liked to spray it with sea water to keep it cool. The motherboard tray was especially bad... In any case I'll make it point to test the variable resistor with my multimeter.
            The back of the pot says "c 102 1" where 102 is a number all on its own. Some quick googling suggests this is a 1K Ohm part?
            • R_J
              • 9624
              Yes 102 would be a 1k pot, I suspect once you check it you will find it to be ok, Check between the two leads on the one side, then check between the single lead and each of the other leads, that will give you the position of the wiper. ie if the wiper was in the middle, checking it it that way would be 500Ω between the wiper pin and each of the others.
              • Frampton
                • May 2022
                • 6
                Alright good call on testing the part! Between the two legs closest along the back I got a reading of 1.094 kilo-ohms. Between one leg and the "tripod" leg it measures 711 ohms, the other measures 448 ohms. So part is working as intended then?
                Also thanks so much for walking me through this!
                • CapLeaker
                  Leaking Member
                  • 8352
                  Yes, it’s working just fine.
                  • ccimoe
                    Xbox X part ID
                    by ccimoe
                    Hi, Any one that might have an idea for an xBox Series X Part That I can not figure out the correct part number for. iI blew apart on the board. Nothing on the board to go by as well. The closet I can figure out is it may be a U40/41 Regulator. Looks like this is a 2024 ver Xbox, See pics below. Thanks for any help you may have to offer. Moe
                    07-04-2025, 10:11 AM
                  • Gentian
                    Please help me find 7 pin smd ic 901 part number in Delta DPS-300AB-76 LED Display Power Supply
                    by Gentian
                    I have a 5V 55A led Delta power supply with no output. I found this 7 pin IC 901 damaged as in the photo. All other elements look ok. I checked and every other surrounding componets diodes, resistors and capacitors look ok. I have 2 identical power supplies removed from a led wall which have the same defect with this ic burned but not a working one for reference. I founded by measurements that pin 7 goes to positive hot 450V 220uF electrolytic capacitor primary side. Pin 1, 2, 3, 4 connected together to pcb cooper trace. These four pins goes to negative side of 10uF 50V electrolytic capacitor...
                    09-27-2025, 11:03 PM
                  • edugimeno
                    Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
                    by edugimeno
                    Hi There!
                    I'm trying to help my friend who owns a restaurant be just bought.
                    He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
                    It's stuck using, I guess, the 2 sided tape that comes with the strip
                    The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
                    09-05-2024, 09:34 AM
                  • G-Sting
                    iPad Pro A1876 SHORT Part Identify Help Needed
                    by G-Sting
                    So My iPad was not charging and booting up . i went to a local technician and he checked with thermal and this Part marked in 1st Photo is Short.
                    So then i went on to boardview and downloaded the schematics and identified this part in 2nd Photo. Now i am confused what exactly is the part called ? where should i get this from ?
                    i contacted my technician and he sent me his BoardVIew screenshot in 3rd Photo. In his Boardview the part is called X2826.... Something
                    SO My main concern is what part should i order what should i search the name for ?
                    on Ipad...
                    05-15-2025, 09:30 AM
                  • Junkrepair
                    Calculating ESR from tan delta -- tan delta's dependence on capacitance
                    by Junkrepair
                    I'm finally recapping my Soyo K7VX6 motherboard (aka KT600 Dragon Ultra) and replacing Sacon SZ-series caps. The Sacon SZ datasheet provides a spec for tan delta, but not for ESR, while the candidate replacement caps are specified in terms of ESR.
                    I found this nice little description of the conversion:
                    Calculating capacitor ESR from Tan(delta)
                    https://forum.digikey.com/t/calculat...-from-tan/2633
                    It mentions that a general spec for tan delta has to be adjusted for the specific capacitance before plugging tan delta into the formula...
                    06-12-2023, 02:45 PM
