Have anyone repaired here a pioneer DDJ-SZ before? I have a unit with the problem of right channel XLR is distorting. But left channel is fine. And best part? The RCA both L and R channels are perfectly fine. I have replaced all possible opamps in that audio out board and all the voltage measures accurately. Sorry i dont have a oscilloscope to measure the input nor the output signal. I have attached the service manual here. Any kind souls can show me a lead? Thank you.
					Pioneer DDJ-SZ XLR right is distorting
Re: Pioneer DDJ-SZ XLR right is distorting
Good news is that you have an identical channel you can compare the broken one to. Bad news is, you don’t have a oscilloscope, as it would make this problem easy. I think you really need to explain better what’s happening.
Does your problem channel have a unbalance, where one side is louder in volume than the other? Is it distorted all the time? At what level does it distort?
Maybe show in the schematic what you have replaced already. See, the XLR jack is balanced audio. So you have 3 pins. GND, a hot side and a cold side. Maybe one is shorted to ground, or the ground is missing, or something is open in one of the sides. Can you post a link to the full service manual? -
Hi this is the link to the service manual.Good news is that you have an identical channel you can compare the broken one to. Bad news is, you don’t have a oscilloscope, as it would make this problem easy. I think you really need to explain better what’s happening.
As for your questions, all my levels are at 12pm. When i try the sound on RCA at same levels, sound is good. But when i try the same on XLR, its distorting. I have replaced the 3 OPAMPS and also all the output signal capacitors. Still no luck. If i go to 1PM, it distorts even worse. Only the right channel is distorting while the left channel XLR is fine.
If i lower the fader, the sound is stable, but if i put the fader to maximum, it distorts. The signal LED is below RED so nothing is clipping.
All voltages are accurate -15v and +15. Master L and R signal comes from mainboard to audio out board. On audio out board, the signals are processed and amplified by 3 opamps thats NJM45850. Output to RCA is fine but failing to XLR R. So this problem is not from mainboard as RCA signal are fine. This problem is solely on the audio out board.Last edited by DjKrish; 05-23-2022, 02:06 AM.Comment
Did you try to change the XLR cables around from L to R and R to L, to rule out a cable problem? I still don't know if the broken channel is lower in volume than the working one right before it distorts. With an oscilloscope it would be absolutely no problem to find this. All you can do is to make some resistance checks and see if something is out of line comparing it to the same point of the opposite channel. I wonder if the problem is one of these Protection Zener Diodes on the end like D711 and D712? Swap em around and see if the problem moves to the other channel. Check out the protection fuse P702 what it does.Comment
Yes i swapped various cables, all same. Left is good, right is distorting if put full fader volume. The ports are fine with multi meter check. Checked the zener diodes on diode mode, both are perfectly fine and identical on L and R. The protection fuse is for overload protection. Both are working fine and tested fine.Did you try to change the XLR cables around from L to R and R to L, to rule out a cable problem? I still don't know if the broken channel is lower in volume than the working one right before it distorts. With an oscilloscope it would be absolutely no problem to find this. All you can do is to make some resistance checks and see if something is out of line comparing it to the same point of the opposite channel. I wonder if the problem is one of these Protection Zener Diodes on the end like D711 and D712? Swap em around and see if the problem moves to the other channel. Check out the protection fuse P702 what it does.Comment
Haha thats not discoloration. Certain caps of those comes in white color and certain comes in yellow color. I already replaced, swapped, no changes. BTW, they read fine as well with a capacitance meter.Last edited by DjKrish; 05-23-2022, 10:06 PM.Comment
Well, I think you are going to need that oscilloscope. The unbalanced comes from the master hot, so that’s working. That leaves the master cold. Not much else you can do besides compare or get that oscilloscope.Comment
any other possibilities ?Comment
Btw. These caps I pointed out should be the same than the other side. So not sure why the discolouration, unless they are bad or got changed.
Other possibilities? I think not, be abuse the bad channel is actually working with a little extra feature of distortion. You have to be able to see or hear where the distortion is coming from.
I guess you replaced already IC702? So yeah... need to see or hear whats going into this IC and coming out.Last edited by CapLeaker; 05-24-2022, 04:24 AM.Comment
Its not discoloration. These caps comes in 2 colors White and Yellow, probably different suppliers thus the different colors but same value. I took out the caps from a DJM same value. BTW, i tested all those caps using a capacitance meter. All near value and correct. No damage.Btw. These caps I pointed out should be the same than the other side. So not sure why the discolouration, unless they are bad or got changed.
Any way to test whats going in and out of that IC via a digital multimeter?Comment
ok will do that and report backComment
Not a Tech, can't help much.
If memory serves, I had a similar symptom on a cassette deck with RCA jacks. one channel was distorting intermittently. I retouched the solder points on the jacks' connection to the main board. Problem went away.
Good luck!Comment
Going to try that soon. Ive swapped almost everything with no luck. Going to pop out the smd transistor and check.Comment
Wish it was that simple haha. All jack legs are solid. This is more deeper issue.Comment
I think you are going to need that oscilloscope as I suggested earlier. For this project, you don't need a real fancy one either. Something basic will do just fine. Other than that, you just stab around in the dark and get frustrated on top of it.
You know that the unbalanced output jacks work, but not one of the balanced output. The unbalanced ports work of Master Hot. So there must be something either with the Master Cold going on on the bad balanced port or there is something not equal coming out of the DAC. You need to be able to compare that in order to go any further.Last edited by CapLeaker; 06-07-2022, 04:42 AM.Comment
			by dicky96Hi guys I have a VLP1500 amplifier here - one channels works fine and the other channel distorts even at low volume settings
Protection and Clip LED are off
There is something wrong with the BIAS voltages around T16 and T18 (in particular) on the bad channel
I tested all diodes and transistors in this area in circuit with diode mode - both channels seem identical. Same in resistance mode across all the resistors here.
The output DC voltages on pin1 and pin8 of the 5532D dual op amp at the input of each amplifier module are the same, and the audio...-
			by eccerr0rAnyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...-
			Hi friends
I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board... -
			by mikey5791Hi all forum members,
Fyi, i have been working on this old model PCT-4082 (4 channel car amplifier). The owner said only one channel is working.
My initial finding is this amp originally use Toshiba 2SA1943 and 2SC5200 transistor for its output but after opening the top casing i found it used Toshiba A1941 (pnp)and C5198(npn). I desoldered all the 4 pairs transistors and found 1 piece A1941 open(tested "OL" on all legs) and replaced the 1st pair with 2SA1943 and 2SC5200, thats why you can see in the picture it is the bigger size transistor. The other A1941 and C5198 all...-
			by CDNBrewerHello Everyone,
I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
Symptoms:- Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
 - Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
 - I swapped the Left and Right surround
 - Loading...
