Lg 60PZ550 no picture
  • x2006nzl
    • Apr 2013
    • 11
    • canada
    Hello I acquired a lg 60PZ550 no picture, but the backlight powers on , just no image, I read this can be the mainboard?
    • 12323
    • U.S.
    Re: Lg 60PZ550 no picture
    could be a number of things, do you have a multimeter for testing?
      • 12323
      • U.S.
      need pictures too, straight on clear pictures of each board and one of the whole back as to see how everything is connected.
        • 12323
        • U.S.
        or you can do some guessing, my first guess would be maybe a tcon issue but it's just a guess without testing.
        • vinceroger69
          • Mar 2012
          • 6714
          Mainboard maybe as a plasma no tcon?
          I would run the test patterns if you can
          service manual https://www.manualslib.com/manual/12...g-60pz550.html
          • Biruslapio
            • Nov 2013
            • 552
            • Brasil
            Do the auto_gen test by removing the LVDS cable and shorting two pads on the logic board, the tv should start by showing test patterns, if the image is good and stable the fault lies on the main board, possibly BGA issues on the main chip under the heatsink, famous on all PX and PZ plasmas.
            Following the standard on LG plasmas, I think it's those two pads since the service manual nor the board itself shows where they should be.
              • 12323
              • U.S.
              yep, my bad, didn't register the P for plasma.
              • Ierwin
                by Ierwin
                05-13-2025, 03:31 PM
              • stylishconsultant
                un60j620dafxza - Samsung No Display Problem
                by stylishconsultant
                Hi All,
                Need help.
                I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
                So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
                problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
                might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
                09-04-2024, 03:26 AM
              • sergio_av
                Acer Aspire E5-571G-52NH powers on, no picture. PCH_ENVDD goes off and on.
                by sergio_av
                Hi, I'm unexperienced with troubleshooting and I'm not sure how to proceed with this laptop.
                Motherboard is A5WAH LA-B991P I think, i5-5200U and nvidia 820m.
                When I received the laptop, CMOS battery had 0V. I took it out and all the testing has been done without a CMOS battery and without the main battery plugged in, I haven't been able to see physical damage, burnt or missing components with a quick visual inspection, and no shorts were found.
                Laptop charges the battery, powers on when ON button is pressed when powered from charger and when powered from the battery, but...
                01-01-2025, 05:27 PM
              • jaifraic
                Toshiba 49U6763DA (Mainboard: Vestel 17MB120) Powers on, backlight ok, no picture
                by jaifraic
                I have a Toshiba 49U6763DA TV that shows no picture. It turns on, the backlight works, but nothing else. I don't have a remote at the moment to check if this is working.
                I have opened the unit, every plug is connected, nothing seems to get hot and all caps look ok. I checked the small caps on the tcon board and the two boards that sit between the tcon and the panel (I don't know what they are called). None of the caps are shorted. The tcon board gets 12V (actually 12.5V) and the fuses are fine.
                So I'm thinking that the motherboard is defective...
                06-15-2021, 09:27 AM
              • KYBOSH
                Trying to Save - LG 60PH6700 60-inch plasma HDTV - Powers ON but no picture
                by KYBOSH
                Saved this beast from the landfill this weekend.
                Manfactured July 2013 in Mexico.
                I love working on plasma TVs.
                Its been a while but I was lucky enough to find 2 this week.
                The TV powers on and stays on but no picture. Havent checked for sound yet.
                No bulging caps although the insides are pretty dusty and the boards are discolored from many years of high heat.
                Will start troubleshooting tonight.
                10-17-2024, 01:17 PM
