LG TV 49LW5700 does not power no Standby Voltage(PSU EAX62865401)
  • mohsinrizwan
    • Aug 2020
    • 25
    • Pakistan
    I have LG 49LW5700 which is not turning on, when I checked there was no standby (3.5V) can anyone guide how I can trace which component is faulty.
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: LG TV 49LW5700 does not power no Standby Voltage(PSU EAX62865401)
    Need good pictures.
    • mohsinrizwan
      • Aug 2020
      • 25
      • Pakistan
      Front and back side pics attached
      • mohsinrizwan
        • Aug 2020
        • 25
        • Pakistan
        FYI, I only need this PSU to turn on Backlights, I am using third party main board as original LG mainboard always go bad after 4-5 months. I only need this PSU to turn on backlights and supply 12V to third part main board.
        • dskall
          • Oct 2016
          • 2905
          • usa
          If you have no voltage, check for voltage at one of the 3 main caps. If voltage then check ic501 for vcc voltage, datasheet.
          • R_J
            • 9578
            Check if F501 is ok or open.
            • mohsinrizwan
              • Aug 2020
              • 25
              • Pakistan
              F501 is OK
              • mohsinrizwan
                • Aug 2020
                • 25
                • Pakistan
                Main 3 Caps has no voltage, IC501 not seeing any VCC voltage.
                but 2 Caps near IC501 has 280V
                • dskall
                  • Oct 2016
                  • 2905
                  • usa
                  Not sure. Ic501 may be driver for backlights. I'm no expert. I would need to see datasheets for driver IC's.
                  • mohsinrizwan
                    • Aug 2020
                    • 25
                    • Pakistan
                    IC501 data sheet
                    https://www.alldatasheet.com/datashe...EN/A6059H.html
                    • mohsinrizwan
                      • Aug 2020
                      • 25
                      • Pakistan
                      my bad, VCC on IC501 is 9V which should not exceed 3-5V
                      • lotas
                        • Jan 2016
                        • 4706
                        • Russia
                        Power Supply LG LGP4247-11SLPB
                        EAX62865401/8 EAY62169801
                        • dskall
                          • Oct 2016
                          • 2905
                          • usa
                          So thanks to LOTAS, vcc should be 16v.
                          • mohsinrizwan
                            • Aug 2020
                            • 25
                            • Pakistan
                            I am not pro but know basic things, I can give supply to local tech but in my City we don't have nay good tech who understand things
                            • lotas
                              • Jan 2016
                              • 4706
                              • Russia
                              Check these diodes for a short circuit.
                              • mohsinrizwan
                                • Aug 2020
                                • 25
                                • Pakistan
                                both are good, not short.
                                Also I am not getting 220V and on stand by bridge should generate 66V which its isn't
                                • lotas
                                  • Jan 2016
                                  • 4706
                                  • Russia
                                  You will not have power on the diode bridge until the relay turns on (transition to operating mode), now power is supplied through these diodes D501-D504 (standby mode).
                                  • R_J
                                    • 9578
                                    With ic501 vcc at 9v, this suggests the startup cell internally is working. I suspect C508 and C507 could be bad, I would first replace C508 and see if the vcc comes up.
                                    I would also check the voltage on pin4 FB/OLP
                                    • mohsinrizwan
                                      • Aug 2020
                                      • 25
                                      • Pakistan
                                      Replaced both caps but no luck still 9V on VCC
                                      • mohsinrizwan
                                        • Aug 2020
                                        • 25
                                        • Pakistan
                                        any possibility I bypass standby and give 3.5V externally?
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                        • SkishyIshy
                                          Sony Bravia XBR-65x900f: No Power, No Standby-light - however 3.3v STBY is present
                                          by SkishyIshy
                                          Hey All,
                                          I have a Sony 65x900f that I purchased cheap because of a no-power issue.
                                          I assumed that because there is no standby light visible, it would be an easy fix - however upon opening up of the unit I can confirm that the 3v3 standby voltage is making it's way from the power supply to the main board. I'm a little confused as to why there is no standby light.
                                          I am firstly wondering if anyone has this model of TV, or has worked on one and can give me some insight. I have tried to find a service manual for this model, to no avail - and would really appreciate...
                                          03-17-2021, 11:44 AM
                                        • AleMonti
                                          LG 55EG910V - no power and no standby light
                                          by AleMonti
                                          I'm trying to troubleshoot and repair this old LG OLED curved TV, model 55EG910V.
                                          I did some basic troubleshooting and reviewed most related posts here, but I wasn't able to isolate the issue.
                                          The TV shut itself off during playback and never came back to life - the standby light remains off. My dad claims that it has happened a few times in the past but the issue resolved itself after some time. Not this one.
                                          After checking the basics I did the following:
                                          • I measured all voltages and as expected the only active supply is the 3.5V standby. It
                                          11-04-2024, 05:02 PM
                                        • noinimod
                                          Sony 55X900E no standby light, no power. Replaced mainboard already
                                          by noinimod
                                          No standby red light, nothing
                                          This Sony has a separate AC->DC power adapter supplying 19.5V to the TV power board (JK3)
                                          Disconnected JK3 power board from main board, checked voltages on all the pin outs
                                          At a few pins I can see the power supply providing 19.5V to the main board
                                          Based on the service manual triage.. it seems to be pointing towards the power board (JK3) being the most possible culprit
                                          LED light turns on when I disconnect LED driver board ribbon from mainboard (so i thought it is the mainboard,...
                                          12-22-2021, 12:58 AM
