Pioneer DDJ-SZ XLR right is distorting
  • DjKrish
    • Oct 2012
    • 354
    • SG
    Re: Pioneer DDJ-SZ XLR right is distorting
    I think you are going to need that oscilloscope as I suggested earlier. For this project, you don't need a real fancy one either. Something basic will do just fine. Other than that, you just stab around in the dark and get frustrated on top of it.
    You know that the unbalanced output jacks work, but not one of the balanced output. The unbalanced ports work of Master Hot. So there must be something either with the Master Cold going on on the bad balanced port or there is something not equal coming out of the DAC. You need to be able to compare that in order to go any further.
    Hi just curious, im planning to get a oscilloscope. How many MHz would you recommend for audio equipment repairing purposes? is 50 enough? 100? 200? Cause mainly i will be using the scope only for audio equipment's only.
    • CapLeaker
      Leaking Member
      • 8339
      I use a 100Mhz scope for everything, but I am not only doing audio.. For audio even a 50Mhz scope is enough. A 200Mhz scope is nice, but to 95% not needed. It really depends on what you want to do and how future projects proof you wanna be.
      • DjKrish
        • Oct 2012
        • 354
        • SG
        Yeah thats what my friend said as well. Since i only use scope for audio purposes, he asked me to get the 50MHz scope, he said thats more than enough for audio repairing. So i might a portable chinese ones. As i dont use scope all the time, so i dont want to really waste a lot of money on something i rarely use. Been reviewing the portable ones, seems good so far. Does the basic job
        • dicky96
          American Audio VLP1500 Distorting on one channel
          by dicky96
          Hi guys I have a VLP1500 amplifier here - one channels works fine and the other channel distorts even at low volume settings
          Protection and Clip LED are off
          There is something wrong with the BIAS voltages around T16 and T18 (in particular) on the bad channel
          I tested all diodes and transistors in this area in circuit with diode mode - both channels seem identical. Same in resistance mode across all the resistors here.
          The output DC voltages on pin1 and pin8 of the 5532D dual op amp at the input of each amplifier module are the same, and the audio...
          07-13-2022, 05:25 AM
        • eccerr0r
          old X58 triple channel board... memtest86 memory speed?
          by eccerr0r
          Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
          Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
          Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
          06-28-2025, 09:06 AM
        • spleenharvester
          Reverse engineering of 18650 4-channel tester
          by spleenharvester
          Hi friends
          I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
          05-04-2025, 02:43 AM
        • mikey5791
          Help on car amplifier only one channel works
          by mikey5791
          Hi all forum members,
          Fyi, i have been working on this old model PCT-4082 (4 channel car amplifier). The owner said only one channel is working.
          My initial finding is this amp originally use Toshiba 2SA1943 and 2SC5200 transistor for its output but after opening the top casing i found it used Toshiba A1941 (pnp)and C5198(npn). I desoldered all the 4 pairs transistors and found 1 piece A1941 open(tested "OL" on all legs) and replaced the 1st pair with 2SA1943 and 2SC5200, thats why you can see in the picture it is the bigger size transistor. The other A1941 and C5198 all...
          08-06-2025, 10:36 PM
        • CDNBrewer
          Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
          by CDNBrewer
          Hello Everyone,
          I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
          Symptoms:
          • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
          • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
          • I swapped the Left and Right surround
          08-05-2025, 09:29 PM
