peavey xr1212
  • tonytiger
    • Jan 2010
    • 163
    • canada
    peavey xr1212
    hi guy's im looking for a service manual for this peavey xr1212 mixer....
    i have 2 parts that are burn and would like to replace them but cannot see info on them.....location is q3 and q4
    so basicly,when client brought me this mixer,he have already took out these 2 parts....and what he told me is that the mixer have power but no light or disply,ect...but that the powerboard come very hot and start smelling like burning.....
    so i kind of need these parts to make further test.any help would be very nice.thank you
  • petehall347
    • Jan 2015
    • 4445
    • United Kingdom
    Re: peavey xr1212
    have you got the schematic ? if not email peavey for it
    • tonytiger
      • Jan 2010
      • 163
      • canada
      Re: peavey xr1212
      i tryed,but never got a reply.....will try again
      • madan1
        • Nov 2016
        • 726
        • Bulgaria
        Re: peavey xr1212
        Well from picture 9 -gb19nc60kd
        • R_J
          • 9607
          Re: peavey xr1212
          If these two fets are blown, I suspect the driver ic is also blown, check the resistors connected to the gate and follow them back to the drive circuit. I suspect there are more issues, hopefully Peavey will provide the schematics
          • tonytiger
            • Jan 2010
            • 163
            • canada
            Re: peavey xr1212
            thanks for the info,i will do as you told me to check.and yes peavey send me all schematics for this units,i let you know my progress.
            • R_J
              • 9607
              Re: peavey xr1212
              Can you upload the schematics?
                Re: peavey xr1212
                Originally posted by r_j
                can you upload the schematics?
                +1
                • petehall347
                  • Jan 2015
                  • 4445
                  • United Kingdom
                  Re: peavey xr1212
                  +2
                  • tonytiger
                    • Jan 2010
                    • 163
                    • canada
                    Re: peavey xr1212
                    hi guy's sorry for late info but like you asked here are the peavey shematic that peavey send me.
                    • petehall347
                      • Jan 2015
                      • 4445
                      • United Kingdom
                      Re: peavey xr1212
                      https://www.mouser.co.uk/ProductDeta...AzAAUcdTHQmQ==
                      • Kingjman
                        • Sep 2020
                        Re: peavey xr1212
                        Thanks for posting these schematics!
                        Hoping to repair the speaker outs on my xr 1220.
                        • jo75
                          • Aug 2021
                          • England
                          Re: peavey xr1212
                          Hi, hope the pic will be useful for you, I had same problem blown mosfet, the part number is 26NM60N. the SMD diod marking is 14G.
                          • jo75
                            • Aug 2021
                            • England
                            Re: peavey xr1212
                            attached pictures
                            • check12
                              • Nov 2012
                              • 103
                              Re: peavey xr1212
                              Interesting ... that mixer uses the same amplifier board as the Peavey IPR1600 power amp ...
                              The original 2x components were IGBT's but several other fets can be used to replace.
                              Be a good idea to remove the amplifier side power fets and check them or you may blow the new PSU fets again on 1st power up.
                              • clearchris
                                • Dec 2013
                                • 687
                                Re: peavey xr1212
                                Peavey is a great company when it comes to providing schematics, etc. They will also sell parts if they have them, and they have had some parts to some very old amps I have repaired.
                                • welldigger99
                                  • Mar 2023
                                  • 9
                                  • United Kingdom
                                  Re: peavey xr1212
                                  Hi Guys,
                                  Apologies for picking up on this fairly old thread.
                                  I have several Peavey XR1212's in my possession, and have built up a reasonable degree of expertise in diagnosing, localising and repairing the main power boards.
                                  Being SMD they are not easy to work on, and require a fair bit of dexterity with a soldering iron/heat gun! Not sure whaat solder was originall used, but it has a VERY high melting point!
                                  Interestingly, I have had issues identical to those described here, with regard to Q3 and Q4 giving up in spectacular fashion. They do appear to be a point of weakness on this board.
                                  I am about to replace these, so will post back in due course.
                                  If anyone has any additional detail, please post it.
                                  • welldigger99
                                    • Mar 2023
                                    • 9
                                    • United Kingdom
                                    Re: peavey xr1212
                                    The same main board is used in the XR8600D (not XR8600) as far as I can tell.
                                    • Bektronics
                                      Schematic Digital Audio mixer RCF type M18
                                      by Bektronics
                                      Hello dear audio friends.
                                      I am feverishly looking for the full electronic schematic (not a block diagram) of the RCF type M18 digital audio mixer.
                                      The device does not make a WIFI connection with my Apple tablet and yet I have already installed the recent app on it.
                                      I suspect that there is a problem in the mixer itself with the WIFI card and of course I would like to see this on an extensive schedule before opening the device.
                                      Thanks in advance if anyone can help me with this schematic.
                                      Of course, all information about this digital mixer and possibly references...
                                      07-24-2023, 06:40 AM
                                    • Longon
                                      Behringer Pro Mixer DJX-750
                                      by Longon
                                      Hi all....I have been using my Behringer mixer quite comfortably for a number of years now and generally it's been trouble free apart from a replacement crossfader. Recently input three channel fader began to bleed a little and causing the mixer to light up like a Christmas tree! I realise the unit is ageing now and although I'd put some hours on it over the years it's not been abused. Following the issue I planned on replacing the faders and ordered the necessary parts. In the meantime whilst awaiting the replacements I continued to use the mixer up until the channel fader started to give feedback...
                                      08-11-2025, 02:17 PM
                                    • Mark D
                                      Samsung UN65JU67ODFXZA Version TD01 Schematic and Parts List
                                      by Mark D
                                      The TV is a Samsung UN65JU67ODFXZA Version TD01. I replaced the power source board and the TV is now working, but I decided to try and troubleshoot the old board to fix at the component level. Trying to get a schematic and a parts list has proven to be an issue. Trying on my own, I can't tell you how many times my Norton security has flagged sites as "malicious". I ordered a service manual from ServiceManuals.net, paid $16.99 and got 66 pages of everything BUT schematics and component parts list! Can anyone steer me in the right direction? Some of the surface mounted component parts...
                                      10-29-2024, 03:15 PM
                                    • Thermaltake
                                      Yahama mixer PSU difference
                                      by Thermaltake
                                      I am planning to buy myself a new mixer. Yamaha MG12U or XU(not sure) and I always like to take a look inside of mixer to check how it looks, if caps are low quality and other stuff.
                                      I manage to find some teardown video on youtube but video name is saying MG12XU, but when you look at video on mixer it's MG12U.
                                      And when I google those two models they have different PSUs one have cheap low quality caps, and other is way better with quality ones Nichicon. So I am confused now from what model exactly is that better PSU??
                                      I google a little and found that there is this part number...
                                      09-17-2024, 11:52 AM
                                    • Thermaltake
                                      Power button on Behringer Xenyx 1204USB mixer dead ?
                                      by Thermaltake
                                      Hi, I got Behringer Xenyx 1204USB mixer, and in the morning mixer was working fine, but when I came home from bike ride I turn it On but nothing happend. Phantom switch is working because red light is On, but other switch no respond.
                                      I brought mixer to my friend today who is electronic expert and he will tell me if it's the button or something on power supply that died. But I am 90% sure that it's power button. My question is, is it possible to put some better quality switches on that mixer than the ones mixer came with, I found them very cheap and low quality.
                                      08-16-2022, 03:22 AM
