Hisense 58R6E3 (Backlights, sounds, no picture)
  • curt2199
    • Oct 2013
    • 54
    I'm working on a Hisense 58” R6E3 $398 Walmart special Roku TV. I picked it up free as the previous owner just said the picture went black so I assumed I'd be doing LED strip repairs. As it turns out the backlight is working fine, the TV responds to remote signals as I can here the typical Roku menu sound effects. My first thought after some typical voltage checks was a bad t-con board so I ordered an eBay damaged set pull for $5. Swapped it out and no change.
    Before I order a replacement main board, I wanted to see if anyone else had seen similar issues with this set? I pulled the bottom bezel and don't see any signs of damage, physical or liquid to the driver boards and ribbon cables. Other than a few scratches on the screen that didn't equate to cracks, the set looks to be in perfect physical condition.
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Hisense 58R6E3 (Backlights, sounds, no picture)
    Have you checked the Tcon fuse and it has the supply voltage present.
    You could try disconnecting one of the ribbon cabbles from the tcon to the panel and then power up to see if you have half a picture. Repeat for each ribbon
    • curt2199
      • Oct 2013
      • 54
      I couldn’t find what normally looks like a fuse to me but I did get 12v, 3.3v, and 1.8v at different spots on the board and the t-con has a green light lit at the 1.8v spot. The only thing that seemed suspect to me is an area marked (with a perimeter line) 15v near the input cable from the main board is only showing 1.1v.
      I did pull ribbon cables from the t-con to the panel driver boards and didn’t see any change.
      I can get a photo of the t-con shortly.
      • neilc6
        • Nov 2015
        • 1550
        Connect one side at a time between the tcon and panel. This will determine if there is a problem in the panel.
        • curt2199
          • Oct 2013
          • 54
          Done. Disconnected both and connected one at a time. No change.
          • Tv Terminator
            • Apr 2022
            • 12
            I have the same problem but with the same model and 65 inch version. Ribbon cables to driver boards were disconnected one by one to see if I could get half an image and there was no change. Does anyone have an idea on what could be done next.
            • dskall
              • Oct 2016
              • 2905
              • usa
              I would say mainboard problem.
                • 12328
                • U.S.
                post some focused pictures of each board and one of the whole back as to see how everything is connected.
                • itronic
                  • Sep 2015
                  • 82
                  • usa
                  I have same tv with same problem. Hisense 58R6E3 (Backlights, sounds, no picture)
                  What was issue. I replace main board and tcon board. Still same problem. Anyone have test guide on the Tcon board.
                  https://www.shopjimmy.com/insignia-v...-1502914734448
                  • alfatv
                    • Sep 2020
                    • 353
                    Do this step first
                    • itronic
                      • Sep 2015
                      • 82
                      • usa
                      Looking at the back of tv.
                      unhook left ribbon and tv show half white screen other half black.
                      unhook right ribbon and tv show whole black screen.
                      testing tcon test points now to. Showing the issue is lcd panel on left side
                      • itronic
                        • Sep 2015
                        • 82
                        • usa
                        Below is images of Test points results. Image A is Standby with no ribbon cable plugged in. Image B is with RH side ribbon plug in and LH Side Unhooked.
                        Voltages is the same on Image B if in standby or Turn on. Also you have the Gm voltages on Image B
                        IF RH side is hook up and left unhooked. The screen is white on the RHside and LHside is black looking from the back side.
                        IF both cable is hooked up. The screen is black on both sides.
                        Same is the LHside ribbon is hooked up and RHside is unhooked. both is black.
                        • itronic
                          • Sep 2015
                          • 82
                          • usa
                          Did this step and my result are posted above. Anything else i can do or is panel down.
                            • 12328
                            • U.S.
                            can try the "tape cut-off" method, there's a crapload of how to videos on youtube if needed.
                            • jamesband42
                              • Oct 2022
                              Anyone know the pins for CLK 1-8? They don't appear to be labeled on this T-CON. Would love to try blocking the CLK lines to the RH panel before I trash this TV.
                                • 12328
                                • U.S.
                                https://www.youtube.com/watch?v=pfrRhw7-ZII
                                • itronic
                                  • Sep 2015
                                  • 82
                                  • usa
                                  Thanks for the input. Ill check this out and repost later.
                                  • itronic
                                    • Sep 2015
                                    • 82
                                    • usa
                                    This tape trick will not work with a grounded panel. After testing, The right side of panel works fines. The left side reads grounded. So still testing. Going to induce voltages to fine short.
                                    Any one have another way?
                                    Thanks in advance
                                    • Jayxlouis
                                      • Dec 2022
                                      I am having the same exact problem basically identical to yours, tv and all. I have replaced the t con board and it's still not fixed. when undoing the ribbon cable it shows 1/2 black 1/2 white while the left ribbon cable show completely black screen. have you found a solution yet?
                                        • 12328
                                        • U.S.
                                        Thanks in advance
                                        have not heard of this before, where did you get this info from?
                                        • DXseekerMO
                                          TCL 55US57 backlights, no picture.
                                          by DXseekerMO
                                          So here we go with another screen short TCL. For this exercise left and right will be reference looking at the screen.
                                          The person I got this TV from said the color was bad in a vertical fashion about 1/4 of the way over the left side of the screen. Shortly after the symptoms below started.
                                          Power Supply, main and T-CON board are working.
                                          Symptoms: The TV has backlights but no picture with both FFC's attached to the T-CON and does not respond to the remote or buttons, and the TV appears to continuously re-boot.
                                          Unhook FFC from left side...
                                          09-18-2021, 03:56 PM
                                        • adamp91gvm
                                          hisense 55e76gqtuk seems to be downloading picture from top to bottom with lines
                                          by adamp91gvm
                                          as above shows coloured lines then slowly goes down and repairs the picture on start up if been on for a while then turned off its fine anyone had this...
                                          09-10-2025, 12:13 PM
                                        • sordids999
                                          SAMSUNG UE43AU7020K BACKLIGHTS BUT NO PICTURE
                                          by sordids999
                                          Hi
                                          Really stuck on this TV
                                          I'm thinking it's a bad screen ?
                                          Voltages all seems good
                                          Tcon 12v ok
                                          Remove one tcon cable at a time no half image on the screen just backlight and no picture
                                          even tried the tape trick still no luck
                                          Thanks...
                                          05-12-2025, 10:36 AM
                                        • stinger
                                          Samsung UN70TU6980FXZA no sound no picture but does have backlights
                                          by stinger
                                          When I turn tv on, the backlights come on but there is no sound or picture. I have read that these tv's have problems with the panels going bad but the "no sound" has me questioning if the main board is bad. Is there a way to troubleshoot the main board to determine if that is the problem?
                                          04-17-2024, 03:06 PM
                                        • petersor
                                          Hisense 58R6E3 Backlight/No Picture Repaired
                                          by petersor
                                          Quick repair summary for those interested. I had a Hisense 58R6E3 TV that had backlights working but no picture. T-Con had 12V supply but some of the supplies on the board were 0V. Unplugging one of flat cables to the LCD display driver boards brought the supplies back up, so I figured it was a short on the LCD panel driver board. Narrowed the short down to the 15V power supply by checking the coils on the T-Con board to ground with a diode test and confirmed that all the MLCC caps on that rail all showed a short to ground. I injected 5V/1A into the 15V rail on the driver board (T-Con disconnected)...
                                          06-07-2024, 04:16 PM
