Panasonic TX-L32E5E doesnt turn on.
  • romisek1990
    • Jun 2022
    • 11
    • Česka Republika
    I'm coming to you for advice. On my desk I have this TV that does not turn on. When the TV is plugged into the network and the POWER ON button is pressed, only the red LED is lit.
    I checked all the voltage on the P-BOARD:
    6V - stynd by
    16V
    40v backlight
    I found out that I can't get a voltage of 12V on the T-CON. Power supply 16V to the circuit IC4101 goes, I just do not know if this circuit controls the processor IC8000. Do you happen to know anyone ?
    Thanks for help.
  • romisek1990
    • Jun 2022
    • 11
    • Česka Republika
    Re: Panasonic TX-L32E5E doesnt turn on.
    On pin 14 of IC4101 is 5V so it is OK ( no fault ), but I dont have PANEL_VCC_ON and BL_ON why :-( :-( :-(
    • dskall
      • Oct 2016
      • 2905
      • usa
      Some good pictures of boards and connectors would help.
      • romisek1990
        • Jun 2022
        • 11
        • Česka Republika
        A- bord is TNPH0992
        P-bord is TNPA5596
        pictures I will supply
        • romisek1990
          • Jun 2022
          • 11
          • Česka Republika
          Some pictures
          • R_J
            • 9579
            Does the power led flash a code?
            • dskall
              • Oct 2016
              • 2905
              • usa
              Is your processor chip intact?
              • romisek1990
                • Jun 2022
                • 11
                • Česka Republika
                No only light
                • romisek1990
                  • Jun 2022
                  • 11
                  • Česka Republika
                  procesor is visually fine
                  • dskall
                    • Oct 2016
                    • 2905
                    • usa
                    Does your led come on in standby? Does it blink when you operate remote?
                    • dskall
                      • Oct 2016
                      • 2905
                      • usa
                      Do you have data sheet for IC4101. Looks like processor enables it. Maybe heat up processor and try and turn tv on.
                      • romisek1990
                        • Jun 2022
                        • 11
                        • Česka Republika
                        Yes, LED light and blinking on using remote. Firmware problem ? TV doesnt boot system?
                        • romisek1990
                          • Jun 2022
                          • 11
                          • Česka Republika
                          Is it problem change memory?
                          • romisek1990
                            • Jun 2022
                            • 11
                            • Česka Republika
                            Hello, I find that on TV is bad ROM memory. Is a problem to exchnage it ?
                            • lotas
                              • Jan 2016
                              • 4708
                              • Russia
                              Do you have a programmer that can read and write Nand MT29F4G08ABADA?
                              • romisek1990
                                • Jun 2022
                                • 11
                                • Česka Republika
                                Unfortunately not. When I get someone, how do I know that the memory content is OK?
                                • pajdek
                                  Lenovo Y700-17ISK turn on and off
                                  by pajdek
                                  Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                  09-20-2023, 02:49 AM
                                • platinumsteel
                                  Panasonic SA-BT203 Power Switch Clicking Won't Turn On Issue
                                  by platinumsteel
                                  Hi guys I have a Panasonic blue-ray disc player Surround Sound that is giving me a lot of headache trying to repair. When i press the Power button it gives a Click Click sound but doesn't turn on.I checked Power Supply Board for swollen or bad ESR caps with my ESR Meter and all i found was some swollen caps on the Audio Board i changed with new caps but still the same. Checked the whole board for shorts and there isn't any.I used to have like 3.3v on the Power Switch Button but now i have 20v ... Is that normal? isn't it supposed to be 3.3v on the Power Switch? I am hoping you guys might be able...
                                  02-02-2023, 08:13 AM
                                • Trol
                                  Panasonic TX-55EZ950E wont turn on
                                  by Trol
                                  Hope you can help me
                                  3 weeks ago my Panasonic suddenly blinked red in the power led. So I tried to turn it off and on with the remote, no luck. I then turned it off via the power outlet. After that I tried to turn it on again, but nothing happened. No lights and no picture or sound.
                                  Now I have tried different solutions, taking the power for 1 hour - taking the power for one Day - changing power outlet - holding the buttons on the TV down for several seconds, and even minutes. And nothing seems to help, the only thing that happens is that there is a sound, like a relay...
                                  03-13-2021, 07:45 AM
                                • RdeveLabs
                                  MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                  by RdeveLabs
                                  To all the members here...
                                  Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                  So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                  05-05-2025, 04:59 AM
                                • robante15
                                  Acer Aspire 4520 won't turn on after reboot
                                  by robante15
                                  Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
                                  It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
                                  The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
                                  If I remove the...
                                  04-06-2024, 06:50 PM
