Xbox 1.6 Motherboards and Polymer Capacitors
    • 31285
    Re: Xbox 1.6 Motherboards and Polymer Capacitors
    unless there is a jumper on the board or something, i dont know why you couldnt flash an Aladin
    i will say though, i prefer the 1.0 - 1.5 models for this reason.
    • qwerty99
      • Jun 2022
      • 17
      • ukay
      Recent Aladdins come with a different chip on them, so you can't flash them unless you have an external programmer.
      Pain in the arse because it means it's another piece of equipment that I have to buy.
      I don't usually mind buying tools, but an eeprom programmer is not something I'll ever likely use again once I've done the initial flash.
      I'll probably end up buying one though because the Aladdins can be bought for less than $10. The Open Xenium chips are starting at around 40 to 50 not including shipping.
        • 31285
        wellllll,
        i dont know how your flashing them, but there are several tools
        i used to install Linux, and then from linux i ran a flasher called "raincoat" or something like that.
        it recognised a hell of a lot of chips and could be updated because the chip details were in a text file i think.
        • qwerty99
          • Jun 2022
          • 17
          • ukay
          wellllll,
          I've never had to flash anything with an external programmer, so I don't have a clue about what tools and software I need.
          Any tips on the best programmer to use?
            • 31285
            i'm talking about in the xbox - use xbox-linux
            https://github.com/not404/raincoat
            do you know the chip partnumber?
            https://github.com/not404/raincoat/b...c/flashtypes.h
            • qwerty99
              • Jun 2022
              • 17
              • ukay
              #26
              I think the new Aladdins contain this chip:
              SST49LF002A
              which, supposedly, can't be flashed without an external programmer.
              I think I read it on this thread:
              https://www.reddit.com/r/originalxbo...less_you_have/
              SST49LF002A does appear in the raincoat file. So does this mean that these chips can be flashed while in the Xbox?
                • 31285
                yes, if the id is in the file it can flash it
                • qwerty99
                  • Jun 2022
                  • 17
                  • ukay
                  #28
                  Interesting! I'm going to have to do some reading.
                  • NeMesiS34
                    • Sep 2015
                    • 37
                    Hello all,
                    I've been using an "Xgecu TL866II programmer" for ST M29F080A-90N1 (TSOP40), ST M29F002BT-70NI (TSOP32) and Atmel AT24C02N-27SU (EEPROM) for the Original Xbox. I've also been using it for Atmel ATtiny45-20SU (SOIC8), PIC12C508 (SOIC8), ST SST49LF002A and Cypress S29AL016J70TFI010 (TSOP48) for a variety of modchips. There are newer models "Xgecu T48 & T56" but cost a bit more. There's a list of supported IC's on their website. There are TSOP flashing tools/apps available for the OGXbox, I would highly recommend the one by "Rocky5", this method can only be done on motherboard versions v1.0 to 1.5 and will require 2x 0603 pads to be bridged...
                    I hope this helps, NeMesiS
                      • 31285
                      yes, but he has 1.6 boards
                      how reliable are your tsop adapters?
                      i have hell getting mine to work without pin errors
                      obviously they arent as good as yakamichi but they dont cost $80 either!
                      • NeMesiS34
                        • Sep 2015
                        • 37
                        He could go down the soft-modded road...
                        But depending on he's situation that may not be possible.
                        I haven't had too much issues with my TSOP adapters,
                        I would typically do 100pcs in a single sitting...
                        @stj, After spending most of the day reading through the many
                        CPU capacitor threads, your name came up alot...
                        I'm highly involved in the xbox modding community and
                        would like to talk to you directly if you don't mind...
                        Cheers, Nem
                          • 31285
                          sure - pm me
                          • NeMesiS34
                            • Sep 2015
                            • 37
                            Thanks, will do...
                            Well now that I think of it, I did have pin error issues.
                            It came close to driving me crazy, turned out it was the USB cable.
                            Don't ask me why...
                              • 31285
                              i could try a new cable, but why would it not effect dip and plcc package chips?
                              i prog and dump gals and eproms all the time and NEVER get pin errors - only with tsops.
                              • qwerty99
                                • Jun 2022
                                • 17
                                • ukay
                                #35
                                Thanks as always for the replies!
                                Digikey took so long to deliver the caps (over a month) that when they finally arrived I didn't have the time to fit them.
                                I'll probably do them over Christmas when I get some time off work.
                                Will post back if I'm successful.
                                  • 31285
                                  yea, that was kind of predictable using a u.s. supplier.
                                  ali-express takes 2weeks or less with "ali saver shipping" option,
                                  RS,Farnell etc take 5days or less.
                                  • qwerty99
                                    • Jun 2022
                                    • 17
                                    • ukay
                                    #37
                                    Hello stj and everyone else!
                                    Finally had the time to do some work on one of the Xboxes I accumulated over the year.
                                    Replaced the CPU and PSU caps with the polymers I listed previously, and they work a treat. Also removed the clock cap and replaced it with a normal 16v 470uf electrolytic.
                                    The 20-year-old caps were actually all in decent condition. All showed correct capacitance and the esr was very low - pretty much the same as the new replacement polymers.
                                    Decided to fit an XboxHD+ as well, because the good HDMi adaptors are either out of stock or even more expensive than this board.
                                    Thanks again stj and everyone else who helped me with this. Couldn't have done it without you!
                                    • OriginalDaggers
                                      XBox 360 All Polymer Capacitors
                                      by OriginalDaggers
                                      As the title says, Xbox 360 Polymer Capacitors, replacing all on a Kronos 1 revision board.
                                      I went over a thread here (Xbox 360 with blown caps) and gather some extremely useful knowledge!
                                      If I have things right, I can replace them TO
                                      x9 : 1500uF 16V 10x20mm
                                      TO: 470uF Nichicon FPCAP R7
                                      x2 : 820uF 6.3V 8x12mm
                                      TO: 2.5V 820uF Nichicon FPCAP R5
                                      On this revision, there are other 820uF polymer capacitors for GPU/CPU - I'll be replacing those anyway with the above FPCAP R5
                                      What's a good replacement for the smaller...
                                      This can be anything from game consoles to arcade games to anything else that doesn't really fit into any of the above categories. When starting a new thread, please put the make AND model of your device in the thread title. Also be VERY descriptive of your issue, that way you'll get the best answer possible!
                                      02-20-2024, 12:49 PM
                                    • TMTGTR
                                      An Xbox One PSU Odyssey
                                      by TMTGTR
                                      Firstly I am not a tech. You guys may see mistakes or oversights in my methods so don't be bashful and feel free to post corrections/opinions.
                                      =>Background:
                                      I bought my son a used Xbox One original model: A12-220N1A Rev: 02 with original PSU & 2 controllers 7 years ago. I “modded” the unit placing a 4.5” 12V exhaust fan with a 9v wall wart adapter on top of the vent/fan of the unit. And plugged the Xbox PSU into a Tripplite LTR-600 voltage regulator. Also connected to the Tripplite are a 275w computer tower, an Xbox 360 PSU and a Westinghouse 52” LED TV. ...
                                      06-17-2022, 05:40 PM
                                    • amelbye
                                      degradation of solid state capacitors in motherboards?
                                      by amelbye
                                      Hi, I have a question regarding a motherboard with SS capacitors that I'm having trouble with. Every now and again it would give overclock failed at boot even when not overclocking.
                                      Recently more often, and the last few weeks at every single boot. It seems like the typical capacitors needing to warm up, then everything is fine.
                                      Weird thing is the capacitors are all solid state. Do SS capacitors degrade the same way as normal caps? Is it worth trying to recap the board?
                                      I have already replaced the PSU.
                                      The board is a gigabyte x79 ud3....
                                      11-06-2022, 10:35 AM
                                      HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green EliteDesk 800 i5-7500 Specification for Upgrade or Repair
                                      This specification for the HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green boardview and EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
                                      09-12-2024, 02:00 PM
                                    • grimacelord
                                      Xbox One S - 12V Rail Short - Q9F1 Keeps Blowing
                                      by grimacelord
                                      Have an Xbox One S here that has a short on the 12V power rail. There is no power, beep, or partial fan spin when connecting power cable.
                                      After diagnosing with thermal camera, Q9F1 MOSFET (NTTFS4C50N) is getting hot. When I remove this MOSFET, the short on the 12V rail disappears.
                                      I first replaced Q9F1 with one from a donor board and then partially reassembled the Xbox to test. When I plugged the power cord in, I got a partial fan spin and I thought I had fixed it, but unfortunately, the Xbox still did not power on. So I then disassembled the Xbox...
                                      10-24-2024, 12:31 PM
