My NEC LZ750 started up with a black screen, and occasionally entered the system normally. After writing bios files dumped by others, it started up normally, but lost the activation information. Is there any kind person who can help me recompose the original BIOS information? Maybe need to synthesize the original ME into BIOS file dumped by others.please!
NEC LZ750 .please help! recompose the original BIOS ME region
Re: NEC LZ750 .please help! recompose the original BIOS ME region
TryAttached Filesif you find these attachements useful please consider making a small donation to the site
by mkdjDear all,
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
Channel: BIOS Requests ONLY!
by Lexsmash85Edit: apologies, I only need help with the DMI info.. I thought the ME region would need attention in order to recover from bricked state but maybe I misunderstood.
Im a novice to this experience but in short, I performed a backlash from the latest and final bios firmware BHCN45WW to BHCN26WW hoping that would solve an issue with keyboard functionality failing after an update. Ended up hanging during flash process and then system would no longer POST on reboot.
USB recovery process didn't seem to take. So today I successfully managed to get the BIOS dump from my machine...-
by KentsfieldHi,
I got a Lenovo Thinkcentre M75n (MT-M 11G5 PF3XG5V3) with a semi-bricked bios.
Short recap: I want to add an external GPU via the M.2 slot (Oculink). It does work but has some problems with the onboard GPU of the Ryzen 3 3300U. So I used Smokeless_UMAF to disable it. Since then I don't get any video via the external GPU nor the iGPU and Can't access the BIOS, but the PC does boot to the OS.
I desoldered the flash IC MX25U12872F and dumped the flash.
I also downloaded the newest BIOS and have it as a .bin file (I loosely compared the contents...-
08-04-2025, 07:46 AM -
by Vesko356First of all thanks to all of our members who have posted previously all methods posted here.
Operating system and OS version.If...-
Product Name: Razer Blade 15 (2022)
Product ID: RZ09-0421
Motherboard: CH580
BIOS Versions I work with: 2.02 & 2.06
Bios File Size: 32,768 KB
Dear Forum Readers!
I'm looking for a BIOS modder or anyone with experience who would give me suggestions about my razer blade's BIOS settings.
I can view and edit the content of the BIOS .bin file with AMIBCP BIOS editor.
The BIOS files I'm working with are from badcaps.net and those are CLEAN BIOS files (anyone can find it with the search string: RZ09-0421).
!!! MY RAZER BLADE...-
11-24-2025, 05:52 PM -
- Loading...
