Yamaha RX-A3010 working, no sound output
  • Rupsenkind
    • Aug 2021
    • 26
    • Nederland
    #61
    Re: Yamaha RX-A3010 working, no sound output
    Did a quick swap of the operation(2), video(3) and digital(2) (so complete frontpanel including boards) as well, issue still there.Research continues..
    • budwich
      • Jul 2015
      • 3097
      so you don't have access to a scope? Further, you tested hdmi, but also check R/L rca input at both pre-out and at output. I guess an "easy swap out" isn't so easy... :-)
      • Rupsenkind
        • Aug 2021
        • 26
        • Nederland
        #63
        I do have a scope but didn't have the time to investigate further.. :-) , hope to do so tomorrow, now I'm working on a DSP-A2070 oldie.. :-) , keep you updated...
        • budwich
          • Jul 2015
          • 3097
          you might consider opening a new thread for your a1030 as opposed to "dirting" up this exist a3010 thread.
          Once you get your scope connected, you should been able to "trace" some signals at key points to determine where things have gone astray.
          • Rupsenkind
            • Aug 2021
            • 26
            • Nederland
            #65
            Hi all, on request I've opened a new thread on this topic: https://www.badcaps.net/forum/showth...75#post1147775
            • paulstevens
              • Jan 2023
              • 13
              Hello all, new user here. As such, I cannot start a new thread until I post in an existing thread, so here goes.
              I have an RX-A3050 with the "no sound" problem and have read this thread with great interest. I have done the factory reset but no change in behavior.
              My bench test is to set tuner to AM and listen for static. I only hear it with "Pure Direct" enabled. However, sometimes the sound disappears even in Pure Direct mode.
              My next steps are to run through the onboard selftest diagnostics and see what they reveal. However I do not have a service manual for the A3050. I am using the service manual generously posted by FrozenHaxor (I think, sp?) but would like to find the manual for A3050 if possible.
              Does anyone have a link to the RX-A3050 service manual they can share?
              After this post, I will start a new thread for the A3050 as appropriate.
              Thank you. The information on this forum is wonderful as are the people. I have enjoyed lurking and hope to contribute as well as benefit from being here.
              • lotas
                • Jan 2016
                • 4936
                • Russia
                #67
                Service Manual AV Receiver YAMAHA RX-A3050
                • Rupsenkind
                  • Aug 2021
                  • 26
                  • Nederland
                  #68
                  Now I do have a RX-A3010 with the known "no sound" issue on the DIGI-2 board. Reflow of the D81YK113DZKB4 chip did not work so I'm looking for a DIGI-2 replacement board. Checked witn Yamaha support and they checked with HQ Japan but no boards available anymore at no warehouse or repair center. Does anyone has a (working) DIGI-2 board (partnumber WY506200) for sale? In parallel I've ordered the chip and will try to replace it but I would rather swap the complete board for a good one. Appreciate any feedback. Cheers.
                  • FrozenHaxor
                    • Jun 2015
                    • 266
                    • Poland
                    #69
                    Don't bother with the chips, there aren't any good ones available. They're either failed reballed ones or just straight up fakes, and pretty much all the available boards if you can find any will have this fault sooner than later.
                    • Rupsenkind
                      • Aug 2021
                      • 26
                      • Nederland
                      #70
                      , ok thanks for the headsup, so unfortunately there's nothing more that I can do then use the receiver for parts.......
                      • jjne
                        Yamaha RX V675 sound issues
                        by jjne
                        I have an old Yamaha RX V675 receiver which is starting to develop issues with the sound, although it doesn't quite match up with what folk normally report with these.
                        From cold, the sound cuts in and out. When this happens the amp is losing sync with the optical input (speaker graphic disappears from the front panel). But this is not resolved by putting the unit into pure direct mode. After a couple of minutes this resolves, although there are occasional clicks from the speakers after that.
                        At first I thought it was either a speaker relay or the DSP, but I don't think...
                        06-24-2025, 07:01 AM
                      • AlexVG
                        YAMAHA CLP-550 without of sound
                        by AlexVG
                        Hi.
                        I have an old YAMAHA CLP-550 without sound. (Some times I can get some kind of noise or distorted sound)
                        I have replaced all green marked elements, but it gave me nothing.
                        The IC12 chip LC9116A-105 (red marked) remains under suspicion yet.
                        But it is custom YAMAHA's chip, and I can't find any information about it.
                        Maybe somebody came across with the same issue?
                        Any information will be very useful. I will be very appreciated.
                        Thank you....
                        06-08-2025, 09:29 AM
                      • ChaosLegionnaire
                        by ChaosLegionnaire
                        09-13-2022, 09:02 AM
                      • hemant_2222
                        Yamaha 2064 No sound but Test audio working
                        by hemant_2222
                        Hello Guys,
                        Greetings!
                        Hope you all are doing well.
                        I am looking for suggestion on Yamaha 2064. The problem with this receiver is that it has no sound however when the test tones are activated it does outputs from all the speakers. It is working in two channel stereo mode but when you select other sound modes, it doesn't. The last time it had a problem, I had replaced the DAC
                        PCM1681DBQR - IC263 and it worked fine.
                        Other issue with it is one of the STK ICs is getting more heated then the other one but that can be looked at later.
                        11-01-2025, 11:20 PM
                      • maleksa
                        Yamaha MOX8 boot freeze and distorted sound
                        by maleksa
                        My Yamaha MOX8 synthesizer recently developed two issues.
                        Firstly, after booting up, it operates as normal. However, after about 5 minutes, the sound starts to get distorted (broken up screeching sound) almost like putting it through a guitar distortion pedal. After a while, the distorted sounds will go away for a while and comes back. At times, the synthesizer will also freeze I need to power off and on again.
                        Secondly, when powering off and on again, there will be times where the synthesizer will freeze during the boot sequence (freezes at the MOX8 Opening Screen),...
                        11-07-2024, 03:28 AM
