I need la-h325p bios please
    I need la-h325p bios please update
    Re: I need la-h325p bios please
    Post the full laptop model number,and your bios backup.
      Dump bios HP 15-dw1216nia
      Hi Guys, I need bios for laptop hp 15-dw1216nia, motherboard LA-H325P, clear ME
      My backup bios
        Re: Dump bios HP 15-dw1216nia
        My backup bios
        Is there another chip ! if not try read again
          Fpw50 la-h325p rev 1.0 bios
          FPW50 LA-H325P REV 1.0 bios needed. SN#: CND1283W1M . I have attached the old dump
            Re: Fpw50 la-h325p rev 1.0 bios
            HP Notebook - 15-dw1213nia
            Become a Badcaps supporter
            Thanks to all supporters.
              Thank you Senior. its working
                hp notebook - 15-dw1213nia
                thank u for sharing.....^_~
                  Re: Fpw50 la-h325p rev 1.0 dw0083wm
                  bro help me clean bios ..thanks
                    thanks working for me.....hp 15 dw0083wm la-h325p rev 1.0
                      help me
                      hp 15 dw0083wm
                      SN. CND1204RZC
                      Problem: No display/ Capslock blink 5 long and 3 short
                      bios backup
                        Originally posted by vienzen View Post
                        help me
                        hp 15 dw0083wm
                        SN. CND1204RZC
                        bios backup
                        Use the bios at post #6, replace the DMI and Windows key in the dump with the one from your backup using offsets:
                        D 3C7000 - 3C8FFF
                        W 3C5000 - 3C503F
                        Thanks to all supporters.​
                          Hi All need bios Hp FPW50 LA-H325P REV 1.0 i tried post #6 but same issues 5 long beep then 3 short its bios corrupts signal i attach dump bios backup anybody have 100 percent working plz share
                            your bios is corrupted, make several copies, check and compare them with the HxD program and which is similar, send it here again..
                              Read the rules before posting:
                              You MUST:
                              • Read BIOS guides, methods, resources and tools
                              • Try the method at BIOS guides, methods, resources and tools before requesting help
                              • Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
                              • Use search function in case someone already answered your request
                              • Post under a related thread if it exists
                              • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 )
                              • Name your thread with model numbers and request
                              • Provide a BIOS/EC dump if possible
                              • Attach files directly to your post instead of linking to external websites
                              In addition your bios backup is corrupted.
                                thanks for response bios chip also failed to backup it mean chip also bad i changed chip program post #6 but same issue here is my device serial number SN#CND13110DM
                                Model Hp 15-dw100nx i also tried from hp website
                                  [Guide] How to extract ready for programming dump from HP update executable file
                                  https://www.badcaps.net/forum/showthread.php?t=121948
                                  https://www.badcaps.net/forum/showth...54#post1261154
                                    thank you for guided dear
                                      I extract these two bios from hp which one are good i also try but same issue 5 long and 3 short!
                                        Hi! I need my bios fixed, can someone help me? Turns on no display
                                        Hp 250 g8 fpw50 LA-H325P Ver: 1.0
                                        sn: CND1431TLZ
                                        Here is my backup
