eureka dsr c60 not cooling moist only
  • bigbily09
    • 68
    • qc
    my refrigerator model eureka dsr c60 is not cooling only moist, but the light is turn on and compressor is sounds too loud this is what i checked
    1.relay - ok continuity
    2.overload - ok continuity
    3.thermostat - ok continuity
    4.evaporator when i touch it is cold
    5.condenser not warm / filter not warm
    6.i hear running like water sounds on evaporator
    do you think it is a compressor problem?? please help
  • redwire
    • 3912
    Re: eureka dsr c60 not cooling moist only
    It's a rare fridge, Eureka ESDR-C60 it's only in the Phillipines.
    I can't find any service manual/wiring or parts etc. to help you.
    If the compressor is noisy, it is likely worn out. Or the system pressure is low, some fridges corrode the tubing and it leaks out. I don't know what the evap noises are about.
      • Jul 2011
      • 6070
      The evaporator nose is usually a sign that it could be low on Freon or restricted because of a clogged filter drier or a restricted cap tube which in either case not usually cost effective to be repaired I am not one to just replace something but I have tried to do this in the past and will not even do this for my own use
      In window air conditioning units sometimes it cost effective depending on weather or not the system is not contaminated with carbon or acid or a combination of the two because of overheating the compressor then it is not cost effective to repair
      In a past life I was air conditioning and refrigeration technician and did this for about 10 years
      This should tell you something this is the reason I did not chime in earlier until someone else commented on this post
      • Ace Perception
        Samsung R530 Bremen motherboard cooling
        by Ace Perception
        I'm wondering if anybody out there has much knowledge of Samsung Bremen motherboards.
        I've got a Samsung R530 which is about 10 years old, over the last 12 months it developed a worsening problem where when asked to do much work it would shut itself down. I had a good idea this was due to overheating which was confirmed by a temperature monitor programme which showed little balls of fire next to the various internal temperature readings. I could also prevent it shutting down if I placed a huge fan running at full speed in front of its air intake!
        So I went in pursuit of...
        07-21-2020, 03:05 PM
      • eccerr0r
        Running water cooling AIO 24/7/365?
        by eccerr0r
        Does anyone here run an AIO or other liquid cooled CPU cooling solution 24/7/365 / on a server? Do you feel comfortable with possible failures? Should I be worried about pump failures? Pump failures causing leaks?
        Having reservations on a second hand cooling system on a PC. So far it's pretty good, keeps things nice and cool but I've never had long term experience with 24/7/365 operation of water cooling, AIO or not. Might have to downgrade to an air cooled system for peace of mind?
        11-25-2025, 03:51 AM
      • Hondaman
        Liquid cooling?
        by Hondaman
        I hope my computer does not randomly reboot while typing this. My main system is the AsRock 970A-G/3.1 motherboard with the AMD 8150 chip. I am experiencing FREQUENT and RANDOM reboots once the system is used for a couple of hours (sometimes it reboots before I even get to the Win7/Linux Mint dual-boot screen). The problem MIGHT be the DRAM controller chip (I recently upgraded to the maximum 64 GB RAM). It also might be the VRM chips. I am using a typical aftermarket CPU cooler, which does NOT blow air DOWN onto the VRM heat sink.
        (After previous generation hardware [Gigabyte] didn't...
        05-08-2025, 09:37 PM
      • unimatrix93
        LG fridge compressor not starting
        by unimatrix93
        Hello everyone, my old but loved LG GR-642 stopped cooling and frosting all together.
        The display shows everything as normal, the focused cooling activated when I open the doors but the compressor wont start.
        First I measured the terminals on the compressor at the back of the fridge. 0 volts.
        Now I disconnected the compressor and measured resistance on its leads: around 8 ohms.
        I dissassembled the main powerboard, couldn't find anything suspicious but I noticed that the comps relay wont send voltage to the pin, while Fan H and fan L is indeed at 230V....
        11-22-2024, 03:27 AM
      • mikey5791
        Help repair Panasonic fridge not cooling
        by mikey5791
        Hi all forum members,
        Few days ago, i might have forgotten to close my home fridge freezer door completely. The next day, the ice cubes and frozen meat almost melted halfway and the freezer doesn't feel cool. I shut it off, wipe dry and let it air dry for one whole day. The next day i switched on the fridge, the compressor run for a second and it shuts off(no vibration and no sound at all) only the internal freezer compartment fan is running but is not cooling even i switched on a full day.
        After shut off, i dismantle the rear water pan holder and reached to the compressor wiring....
        07-16-2025, 02:01 AM
