Need BIOS - Lenovo Yoga 2 Pro 20266 EBKN7
  • acshud
    • Sep 2017
    • 106
    • romania
    Re: Need BIOS - Lenovo Yoga 2 Pro 20266 EBKN7
    Originally posted by hoaca388
    Yoga 2 Pro Laptop (Lenovo)
    thx.i wrote bin.it's ok.have a nice day
    • osman68i
      • May 2015
      • 350
      • The Netherlands
      I need good bios for
      s/n YB06349706
      MTM: 59419078
      I think original bios is corrupt
      • peste
        • Dec 2016
        • 13562
        • ROMANIA
        Re: Lenovo Yoga 2 Pro 20266
        s/n YB06349706
        MTM: 59419078
        bios extracted from Lenovo site update
        DMI 6E0000 - 6E1FFF
        • osman68i
          • May 2015
          • 350
          • The Netherlands
          DMI 6E0000 - 6E1FFF
          thank you
          it works
          • beal
            • Jul 2017
            • 121
            • IR
            Try this virgin bios,cut from the bios update .
            Yoga 2 Pro (20266 / 80AY)
            thanks
            • to5it0
              Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
              by to5it0
              Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
              I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
              This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
              I have opened the laptop and identified the main BIOS chip...
              10-24-2025, 01:35 AM
            • lucaszmn
              by lucaszmn
              Problem:
              Initial Findings:
              • I concluded that the
              08-12-2025, 03:01 PM
            • AYsys
              Lenovo Yoga X1 Gen4 - Faulty Bios or what is going on?
              by AYsys
              Hello dear forum members,
              I own two Lenovo Yoga X1 Gen 4 laptops. One of them had a touchscreen problem, and I tried to fix it by externally flashing the BIOS. Unfortunately, I didn’t save the original BIOS and accidentally flashed it with a faulty one. After that, the device stopped working completely.
              I then had the idea to make a BIOS backup from the other Yoga X1 Gen 4 (same hardware) and flash it onto the non-working device.
              Nothing was flashed here — the BIOS was only backed up.
              I created the backup using a CH341A Black programmer and NeoProgrammer....
              09-13-2025, 11:05 AM
            • Wahaz
              by Wahaz
              10-30-2023, 08:42 PM
            • HotSaladMan
              Lenovo ThinkBook 14S Yoga ITL Bad Flash + Need Bios
              by HotSaladMan
              *##*#*#*#*#*#Cringe Warning Used Clips for Tl866ii Plus Backups#*#*#*#*#*#
              Model : Lenovo ThinkBook 14S Yoga ITL
              S/N : MP28JT19
              MFG Date : 2022/02/09
              Factory ID PRC4
              MO : MPNXB26080FX
              MTM : 20WE001US
              MODULE FCC ID : PD9AX201NG
              IC : 1000M-AX201NG
              BOARD INFO
              FLV34 LA-KO51P
              REV : 1B 2020-08-24
              Bit of Info
              Using Tl866ii Plus, it would scan the chip but wouldn't not detect the
              chip id, so i would always uncheck the id check, so it would bypass the error
              i did in fact make...
              11-07-2024, 07:46 AM
