DELL latitude 7390 bios dump
    Re: DELL latitude 7390 bios dump
    Originally posted by Pivan View Post
    Tried everything and not works Probably only solution is change motherboard.
    Or I will wait for new bios update if come and try again.
    Post this problem to dell forum. I see some BIOS update they've fixed that problem. I also got this problem with Precision 5530 and solved it by replaced the TPM IC on motherboard.
      dell latitude 7390 i5 gen8th daz20 la-f312p rev 1.0 clear ME and tested 100% working
      Enjoy!
        I have problem with installing some software on latitude 7390. It shows that defender blocked it due company rules. Is it computerance or something? Somebody can help with that?
          Problem solved with fresh Win 10 install,
            I have a model 7290. Symptom - no start - 2x5 flashes - alleged memory problem. I programmed the bios from this thread and interestingly the laptop works .. except for the LAN card - in the device manager the wrong code 10. Problem with ME?
              i thinl it's clean me issue , so post your bios dump and ask to clean me
                Posted in a separate thread so as not to clutter
                https://www.badcaps.net/forum/showthread.php?t=113642
                  hi all, i am trying, to update bios on this dell latitude 7390 i7 DAZ20 LA-F311P REV 1.0 (a00), all i wanted to do is update to the latest version and laptop will not update, anyone can clean me this bios please, i have tried many bios from this thread here and they give me dell 7290, i am including here my bios, hoping for a solution
                  many thanks
                    many thanks
                    my issue got resolved after spending hours i decided to do f12 diagnostics, it found error with ram even though laptop would boot but would not even install windows or update bios from usb
                      Dell latitude 7390 need clean bios file can u help me
                        What you mean by "need clean bios file"? Because your file is already "Configured" or (Clean).
                        all donations are welcome,
                          Originally posted by hardware1 View Post
                          what you mean by "need clean bios file"? Because your file is already "configured" or (clean).
                          thans for replay yes i clean me but not bios region can u updata bios region
                            Upload your Original BIOS (before cleaning the ME region) and write your Device Service Tag.
                              upload your original bios (before cleaning the me region) and write your device service tag.
                              here is service tag 6r0d4q2
                                Here's your New BIOS, try it and let me know.
                                  THANKS BIOS WORKING U R GRADE
                                    Bios for Dell 7390 DAZ20 LA-F311P Rev.2
                                    i have a Dell 7390 with corupted bios. I have atached my bin image.
                                    Someone have original bin image for this model?
                                    Thanks in advance.
                                      Good to know, You're Welcome.
                                        Re: Bios for Dell 7390 DAZ20 LA-F311P Rev.2
                                        Thanks in advance.
                                        Here's your New BIOS, it's the Working BIOS in Post #35 with your DMI and Windows Key.
                                          please Clean ME for may bios 7390, slow to open thanks
