RCUnlocker
    Re: RCUnlocker
    By locating the correct chip on your motherboard
      Re: RCUnlocker
      HP ProBook 440 G7
      error
      dump bios
        Re: RCUnlocker
        Originally posted by pmaster View Post
        HP ProBook 440 G7
        error
        dump bios
        has no extension. Put at the end .bin aka bios2.bin
        and it will work
          Re: RCUnlocker
          and it will work
          thank you!
            Re: RCUnlocker
            How to use rc unlocker.
              Re: RCUnlocker
              Originally posted by RethoricalCheese View Post
              This is a multitool and unlocker for several series of laptops. Works on Windows. No python etc installing needed, all included in package. Everything is tested by myself but since every laptop is not made equally, there might be edge cases. Always VERIFY your file after reading!!!
              Unlocking
              HP - ProBook, EliteBook, ZBook (including 32MB models)
              Chromebooks from all various manufacturers
              Apple - everything older than T2
              More to come...
              Information display (helps to verify file integrity)
              HP - ProBook, EliteBook, ZBook (up to 16MB models for now)
              Custom logo removal
              Usage: Drag and drop .bin file to .exe file.
              In case there are problems with unlocking your laptop, write a short description of the issue, upload original file and if possible, _unlocked.bin file aswell. Just crying for help is useless. Keep the topic as clean as possible.
              You may ask for feature requests, I'll see what I can do.
                Re: RCUnlocker
                Hello to all friends and experts here,
                I'm very scared and my fingers are shaking because I'm about to use the RCUnlocker tool that user RhethoricalCheese posted on this website
                for my laptop: HP ProBook 430 G5 2VP86EA
                Because I forgot the BIOS administrator password.
                I disconnected the main battery and also the small cmos battery from the motherboard.
                I use the Test Clip Cable with the XGECU T48 TL866-3G programmer.
                The motherboard model is: DA0X8BMB6F0 rev F
                The BIOS chip model is: Giga Device 25B127DSIG
                I want to ask you a few questions before I start the process and ask for as much information as possible that can help me with the symptoms later:
                1. Is the RCUnlocker tool that I downloaded from this website safe to use and does it not cause a back door in the BIN file to penetrate the computer remotely?
                2. What will change and what information will disappear in the computer hardware after writing the BIN file on the bios chip?
                and more importantly, how do I correct and restore the original information?
                for example:
                clean ME/TXE region, UUID, ISV Id, System Board ID, SKU Number, Product number, DMI info, CT number, VNRAM, EC firmware
                I really tried to read for weeks about these concepts and I didn't understand anything.
                That's why I'm asking for your answers and knowledge.
                3. If there is a any problem with my laptop after writing the BIN file on the bios chip,
                Can I upload the original password-locked BIN file to this website and help me cancel the password but keep all the original information of the computer as it came from the store and the manufacturer?
                Thanks.
                  Re: RCUnlocker
                  1. You already have a backdoor in your bios. It's called computrace You can always compare before and after files with hex editor to see what has changed. (hint: something got deleted, not added)
                  2. Your password will disappear. Nothing needs restoring.
                  3. Yes. The most important thing you must do is to make a PROPER backup. Be sure that it's read AND VERIFIED before continuing. If anything goes wrong, you can always resort to your backup file.
                    Re: RCUnlocker
                    @RethoricalCheese :
                    Please sir , Acer Chromebook CB514-1W has 32M DUMP, does RC_UNLOCKER process this kind of file?
                      Re: RCUnlocker
                      Originally posted by dimah77 View Post
                      @RethoricalCheese :
                      No because back then common HP EC roms and chromebooks were under 32MB and I tried to avoid people who are unable to read instructions, modifying the wrong chip.
                        Re: RCUnlocker
                        then how to unlock enrollment for previous attached file ?
                          Re: RCUnlocker
                          when im trying to drag and drop bios file 8mb in rc unlocker it not response i have pythone latest version 11.xx any friend face this issue
                            Re: RCUnlocker
                            thanks for sharing
                              Re: RCUnlocker
                              Hi there,
                              Please help unlock this bios password for my Elitebook 840 G6
                              Thank you.
                                Re: RCUnlocker
                                Originally posted by kingkong8 View Post
                                Hi there,
                                Thank you.
                                Originally posted by piernov View Post
                                You MUST NOT:
                                Hijack threads unrelated to your request
                                Post a request in multiple threads
                                Post a request multiple times
                                Post in foreign (non-English) languages
                                Share private contact information
                                In addition, Peste has already told you what to do to solve the problem.
                                Become a Badcaps supporter
                                Thanks to all supporters.
                                  Re: RCUnlocker
                                  Could you please help me unlocking an HP 830 G8 bios ?
                                  Here are the dumps, thank you very much.
                                    Re: RCUnlocker
                                      Re: RCUnlocker
                                      Originally posted by Vesko356 View Post
                                      Thank you very much for your help.
                                      Can you please tell me how did you bypass the 16MB limit ?
                                      Indeed, I would like to do it myself for another one :
                                        Re: RCUnlocker
                                        I can't tell you because I do the unlock without using the tool.
                                        >>>>> Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, see the donate button at the bottom of the page, or click on this link to donate via PayPal. Every donation made will go towards server fees and maintenance costs. <<<<<
                                          Re: RCUnlocker
                                          Hi All I got this error message.
                                          The application was unable to start correctly (0x00007b).
                                          Did I make any mistake?
