Cap Datasheet Depot
This is a sticky topic.
    • 21968
    Re: Cap Datasheet Depot
    Samxon catalogs https://www.manyue.com/product1.asp?BrandID=1
    • Uranium-235
      Comrade Glimmer
      • Aug 2007
      • 5045
      • US
      #82
      Sorry about the lack of updates but with some reloads, I need to get SCP re-installed and reset the password
      • Uranium-235
        Comrade Glimmer
        • Aug 2007
        • 5045
        • US
        #83
        Does anyone want to take over this? I don't often get datasheets and don't actively look for them anymore.
        Must be a regular I know
        • psyco744
          • Mar 2022
          • 5
          • turkey
          #84
          Thank u very much,great job.
          • blzblz
            • Mar 2023
            • 5
            • Bangladesh
            #85
            • AleXis6
              • Feb 2021
              • 69
              • Belarus
              #86
              It seems Samwha Capacitors missed
              • andrewsawesomr
                • Jun 2022
                • 101
                • United States of America
                #87
                Samwha datasheets (website archive): http://web.archive.org/web/202303310....aspx?f_num=39
                • electomech-fixer
                  First post -Intel NUC 10i5 -BXNUC10i5FNH not powering on -IC burnt- request for IC details/datasheet
                  by electomech-fixer
                  I came across this very active forum with knowledgeable folks on electronic circuits and components, while google searching for the details of my burnt IC marked 7603 in Intel NUC board. I joined this forum today and this is my first post here.
                  I recently got an Intel NUC 10i5 and had installed Linux Mint and was using it for about a month when it died suddenly and did not power up after that.(Power Adaptor is ok). When I opened the NUC , there was a burnt IC marked 7603 (and ILCB in second line). I am unable to find the details/datasheet of this IC. I will be grateful if...
                  09-15-2025, 01:42 AM
                • SoulFreeze
                  Help finding datasheet for component marked G34662
                  by SoulFreeze
                  Hi, pulled this component, (I'm assuming it's a MosFET) from an LED COB video light. Im trying to find the datasheet so I can find an equivalent replacement but no luck. Any assistance with the datasheet would be appreciated.
                  Failing that, a way to pick a suitable replacement component? If it's indeed a switching fet, I'm assuming I might need to measure the switching clock frequency and find a component that meets the power capacity?
                  Its a pair of them driving a 130w Light. Takes in 19volts. I can borrow a scope to measure the switching freq....
                  05-01-2025, 03:56 AM
                • Rainbow_Chameleon
                  Searching Datasheet for AM113 IC by O2MICRO
                  by Rainbow_Chameleon
                  I got a dead HD6950 on Ebay to try my luck and repair it. There were a few broken off capacitors that I already replaced.
                  Measuring the PCI-E lanes I got somewhat weird measurements, the gpu might or might not be dead.
                  If I plug the GPU in, the core heats up and I also get VCore but on two inductors that measure 16 and 60 Ohms respectively (Memory and PEX I guess) there is no voltage.
                  On one of the two buck-controllers (APW7165) the enable pin is pulled to GND and the other controller I just cannot find a datasheet for.
                  So if anyone has a datasheet or at least...
                  01-23-2025, 12:03 PM
                  Surface Mount Fuses Fundamentals Datasheet
                  TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                  TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                  10-07-2024, 06:07 AM
                • evgental
                  HP prodesk 400/600 G6 mini schematic/datasheet
                  by evgental
                  Hey everyone,
                  I'm looking for a schematic or datasheet for this mini PC. I want to see if I can add another NVMe slot, since my motherboard only has one. If anyone has it, please share. And if you have a motherboard with two NVMe slots, can you send some high-quality pics so I can figure out how to reverse-engineer it and give it a try?
                  Thanks a lot!
                  08-04-2025, 04:58 PM
