How do I read this Capacitor or where do I buy this one
  • kiransband
    • May 2023
    • 8
    I am attaching picture of the capacitor that came of from apple motherboard need to order replacement, can anyone suggest how do I order this capacitor or equivalent capacitor?
    Thanks in advance…
    • 31246
    Re: How do I read this Capacitor or where do I buy this one
    180uf 16v PF series.
    now you need to find who makes it.
    • kiransband
      • May 2023
      • 8
      Thank you very much for your response, do you know what is 738 stands for ?
      also somone from this forum suggested this
      hope i can used that as a replacement.
        • 31246
        probably 38th week of 2007 datecode
        • kiransband
          • May 2023
          • 8
          Oh Ok Thank you, please let me know if i can use this as a replacement.
            • 31246
            probably good,
            • MORETTIGIAN
              Capacitor detached from PCB – RTX 2070 Super Founders Edition
              by MORETTIGIAN
              Title:
              Description:
              During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
              I did not notice it detaching, so I am unsure of its original location on the PCB.
              Procedure performed:
              - Removed backplate
              - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
              - Reapplied thermal compound
              - Reassembled card
              Observed behavior after reassembly:
              - GPU powers on and operates normally under...
              09-18-2025, 12:14 PM
            • artvandalai
              Where can I get compatible capacitor for replacement?
              by artvandalai
              Blew the capacitor on my analytical balance scale using the wrong power adapter. I need help finding a replacement compatible capacitor to buy. Will any 100uf 40v capacitor work as a replacement?
              12-28-2024, 10:15 AM
            • r2digital
              klipsch kda-500 amplifier suitable power supply capacitor replacement ?
              by r2digital
              I have a klipsch kda-500 that would turn on and allow me to get into the web management but it was picking up a lot of noise from audio sources so i decided to replace the smd caps on the power supply along with radial one. Some one was in here before me and they basically burned the bottom side of the traces off for the radial cap but i was able to repair it without any real problem. I thought i did a good job sourcing out replacement caps but apparently not and now i can't get the power supply to turn on it just constantly try's to keep turning on. Attached is a picture of the power supply before...
              04-18-2024, 03:50 PM
            • rwkish
              Discontinued Capacitor looking for Replacement
              by rwkish
              Capacitor has been discontinued (EGXF101ELL331MM20S) all of the replacements I have found have are smaller than 0.709" Dia (18.00mm). I would like to use the same size or at least close to the same size Capacitor. 19mm would be too big as they would touch and not be able to through hole mount. Tia...
              08-18-2024, 06:54 PM
            • Hylax
              Replacement capacitor options please?
              by Hylax
              Hi, I'm super new to this capacitor stuff but I've some basic soldering experience with old cellphones PCBs and headphones. I have this APAQ AR5K 820∆μF 3V Dc Capacitor from a motherboard that I'm looking to replace, photos I've attached. But I'm unable to find a 3V one like I've marked in the spec sheet in red (This is the one currently present in the motherboard). But the 6.3V one I can find (marked in blue) is of similar dimensions but different specs as mentioned in the table. Is it okay to replace it with higher voltage cap, slightly higher ESR, slightly lower ripple current, and double...
              08-09-2024, 11:25 PM
