best cheap/free scores 1.1
This is a sticky topic.
  • mockingbird
    • Dec 2008
    • 5488
    #421
    Re: best cheap/free scores 1.1
    I tried the latest DD-WRT on an Asus RT-N12B. I wasn't impressed. I switched to a very new custom release of TomatoUSB and it worked great.
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      the last router i ran ddwrt on did it well till it died... and a recap didn't save it.
      granted, it was ddwrt lite
      for now I have the Belkin N hooked up, DHCP off, N only. the netgear is doing all the routing since other in the house are using the internet and I can't take the system offline at the moment...
      debating with myself on whether to dd-wrt the linksys or not...
      sigpic
      (Insert witty quote here)
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        i successfully dd-wrt'd the linksys... dd-wrt lite that is.
        edit- so far, so good!
        sigpic
        • ncovert
          • Feb 2011
          • 291
          Re: Your Best Dumpster Finds
          poor thing would have gotten destroyed because that thrift store loves to destroy things so people won't want them
          Jeez, why would that thrift store do something like that?
          Thats stupid!
          • dood
            Deputy dood
            • Mar 2004
            • 2462
            Currently typing on a Dell Studio 1735 that I got for free. Hard drive and memory had been stripped. Had a note on it that the motherboard was bad, but I decided to check it out. Found that it would not detect a known good HD. I suspect that the goofy proprietary sata adaptor is bad.
            So, this laptop is so beastly, it has a spot for a second hard drive (which uses a different kind of goofy SATA adaptor). I moved the drive over to there, and hey presto, a working laptop. I'm going to order a replacement primary adaptor, as well as the real secondary drive mounting kit, so that I have both.
            Not a bad machine for free.... C2D 2.0ghz, Intel 965 graphics... runs Windows 7 just fine. I'll have to pick up some DDR2 to put in it, since I'm borrowing some for now just to test.
            (And yes, I have the drive Scotch-taped into its spot, since Dell saw fit to use two different drive cages, as well as two different connectors...)
            Ludicrous gibs!
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              nice.
              Spec wise, similar to a D830 minus the multiple hdd locations.
              nice.
              looks cool to me.
              sigpic
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                ~Finally~, a laptop with 2x HDDs stock.
                So tell me,,,, Does the BIOS let you put them in RAID 1?
                Mann-Made Global Warming.
                - Dr Seuss
                • dood
                  Deputy dood
                  • Mar 2004
                  • 2462
                  Pretty much the same specs as my d620 that I use at work, as well. You can use a second hard drive with that machine, but only with the special media bay adaptor. The Studio has a slot-load DVD drive, so no media bay.
                  Also, the battery is shot... I dunno if I feel like replacing it right now, though. For the most part, this machine is just going to sit on my desk and be used as a 2nd PC when I'm gaming on my primary.
                  Ludicrous gibs!
                  • dood
                    Deputy dood
                    • Mar 2004
                    • 2462
                    Sadly, no. I've seen Dell laptops with RAID capability, but this one doesn't have it.
                    I also got an HP DV9000 for free that has two hard drive bays, but that one doesn't POST. I think it's got a dead nVidia chipset...
                    Ludicrous gibs!
                    • PCBONEZ
                      Grumpy Old Fart
                      • Aug 2005
                      • 10661
                      I'd love to know the model numbers of any laptops with BIOS supported RAID.
                      Looked for that for a while [years ago] but gave up and haven't thought about it since.
                      I have several old Gateway 1GHz P3 laptops that support up to 3 drives with bay swap adapters but none with system based RAID.
                      - Dr Seuss
                      • mockingbird
                        • Dec 2008
                        • 5488
                        #431
                        965 is ICH8M which allows AHCI capability, but not RAID. ICH7R does both.
                        • dood
                          Deputy dood
                          • Mar 2004
                          • 2462
                          I know there's some Sony Vaios that support RAID. I'm not sure if it's 0, or 1, though. I could set up this Dell with software RAID if I wanted to, but I'm not going to...
                          Ludicrous gibs!
                          • PCBONEZ
                            Grumpy Old Fart
                            • Aug 2005
                            • 10661
                            When they come up with a software RAID that supports multi-boot I'll be in there...
                            Until then I need a BIOS supported RAID to do what I want.
                            - Dr Seuss
                            • kc8adu
                              • Nov 2003
                              • 8832
                              • U.S.A!
                              #434
                              last week i got a 6 month old #27 deep cycle battery and a new in box 2x4 troffer out of my own dumpster.i forgot to lock it.maybe i should stop?my luck next time it will be junk tires or nuclear waste!
                              the battery just needed to be charged.the troffer had 1 busted bulb.
                              were not dumpstered but still free are 2 55" plasma tv's.
                              y buffer issues.already sold as soon as the boards come in.
                              • Koda
                                • Aug 2011
                                • 317
                                • Macedonia
                                #435
                                Never ever found or got anything for free Only can hope to get a lappy or an LCD TV.
                                Guns don't solve problems. I'll take 12
                                • ratdude747
                                  Black Sheep
                                  • Nov 2008
                                  • 17136
                                  more scores today:
                                  $10- logitech momo wheel. complete unit, in box, with all the goodies. works great. I twas originally $20 but it had sat so long that it was qualfied to be 50% off... it must have been hid behind a dorm fridge or something.
                                  $6- netgear WGR614 v1. if I can, I will linux it up, if not, I'll do something cool with it.
                                  sigpic
                                  • ratdude747
                                    Black Sheep
                                    • Nov 2008
                                    • 17136
                                    not much out there on this router... from the FCC ID of the radio module, it uses an internal mini-PCI B/G card for the wireless part...
                                    https://apps.fcc.gov/oetcf/eas/repor...c_id='P27-LA10'
                                    I guess I will have to open it up and look inside when I get home...
                                    sigpic
                                    • ncovert
                                      • Feb 2011
                                      • 291
                                      Okay, I made some good scores about a week ago. These are from craigslist:
                                      Dell Dimension 4700 (has bad caps, no ram or hard drive, I put in a 120Gb drive) for $20
                                      Compaq Presario SR1710NX(no ram, bad caps, I put a different mobo in temporarily) for $15
                                      Dell Optiplex 170L (no cpu fan or shroud, no ram, 40Gb HD) I put in 1Gb of RAM and a 80Gb SATA Hard drive and a new cpu shroud. Now delighting one of my relatives. for $5
                                      IBM Aptiva 2176-C33 (Pentium 133Mhz, 48Mb RAM, someone upgraded to a 40Gb Hard drive that was dead) for FREE
                                      Gateway FLEXATXSTC Bro Essential 700c (Complete system with 60Gb Maxtor HD) also for FREE
                                      Gateway model "450" (Intel P3 450Mhz, no ram, 20Gb HD) for FREE
                                      A really cool fan controller/USB Card reader for $10
                                      A Western Digital 500Gb hard drive for $25
                                      A Western Digital 320Gb hard drive for $15
                                      2 Maxtor 120Gb hard drives for $5 each
                                      Some custom built computer (Intel Celeron 566Mhz, 128Mb RAM, 15.3Gb HD) for free
                                      That concludes the craigslist finds.
                                      • ratdude747
                                        Black Sheep
                                        • Nov 2008
                                        • 17136
                                        found a brand new (still in retail packaging) targus chillmat for $8 at a thrift store...
                                        sigpic
                                        • Scenic
                                          o.O
                                          • Sep 2007
                                          • 2642
                                          ^ I didn't know Targus was available over there.
                                          Then again.. the only Targus thing I've got is a headphone. A pretty darn good sounding one too, especially for free
                                          It's a Targus AEH01 (or AEH-01)
                                          http://www.targus.com/us/productdetail.aspx?sku=AEH01US
                                          (I'm not using the "Talk-Through" blob thingie..)
                                          The total lack of any kind of specifications on that thing anywhere on the web still confuses me..
                                          • H34TO
                                            ITE IT8390 (IT8390E-256) programmer "ITE Download Board 4" user manual + firmware, flashing ITE ECs on the cheap
                                            by H34TO
                                            Recently I've gotten into EC flashing due to my broken laptop(s) and started frantically searching methods for flashing the IT5571E-128 chip on the cheap(due to me beaing a student and not having a job) and noticed that ITE newer chips can be flashed via ISP (In-System Programming) either via SMBus or the KBC (EPP - Enhanced Parallel Port) interface. While these can be achieved with programmers like SVOD4/3 or the RT809H/F those options are WAYYY out of my budget so I was horrified. But recently I stumbled uppon some programmers on aliexpress that claim they can program a variety of ITE chips...
                                            06-17-2025, 07:17 AM
                                          • evilkitty
                                            When your mom is complaining about her new cheap lights
                                            by evilkitty
                                            My Mom bought some cheap motion sensor lights on wish... then complains about about batteries and this thing chews though them, well it uses 4 AAA batteries and a pack of rechargeable ones is about 13 USD
                                            well since it uses 4 AAA and rechargeable are 1.2v and non-recharge at 1.5 this thing must work with 4.8-6v, I'll shove a USB cable on it, infant i will use a broken phone charge cable... dam this thing uses 430 mA and they made it battery powered...
                                            lets ignore the fact that i thought the board fit both ways... and the wire color is reversed going to the board...
                                            07-23-2024, 01:27 PM
                                          • aaronkatrini
                                            by aaronkatrini
                                            - Autorange
                                            - DC volts up to 30V
                                            - Accurate Resistance
                                            - Diode test (Beep mode)
                                            - Frequency up to 200MHz
                                            - Capacitanze up to 5000uF
                                            - as cheap as possible
                                            05-06-2024, 09:54 AM
                                          • CoppellTVRepair
                                            Sharp Aquos 80" TV ~ Model # LC-80LE844U ~ Not operational, Take 2
                                            by CoppellTVRepair
                                            There's a thread on the site titled "Sharp Aquos 80" TV ~ Model # LC-80LE844U ~ Not operational", detailing the process of the most common problem affecting power supply board PSD-0888D.
                                            For the sake of bringing something of value I'd also add (even though it probably belongs in the thread itself) that what's described there is one of the TWO possible variants of the failure - blown IC, blown fusable resistor 2.2 Ohm or 2 Ohm.
                                            The other is an internally failed, but not shorted IC, resulting in resistor that's still intact, but the board spontaneously losing power...
                                            12-02-2025, 06:25 PM
                                          • Dan81
                                            The Cheap Duo - Two SiS machines
                                            by Dan81
                                            Just as the title states. Two cheap SiS machines, surprisingly stable.
                                            What I will tackle in the near future (the build will be slightly postponed due to slight stomach issues - am still recovering and my physical power (sorry if it sounds weird,English isn't quite my primary language) isn't the best at the moment. Especially with the diet I have to take at the moment.) are two SiS based machines.
                                            The first one is a IPC rebranded Mitac 7521T. Why did I feel the need to tackle this machine? Well, just look at the specs:
                                            CPU - P3 1100MHz Coppermine...
                                            04-16-2022, 12:28 PM
