Lot of 10 Amprobe 34XR starting at $10
  • retiredcaps
    • Apr 2010
    • 9271
    http://www.ebay.com/itm/160801768039
    I wrote about this multimeter below
    https://www.badcaps.net/forum/showpo...02&postcount=8
    A great deal if you can get 34XRs for $1 each. $22 for shipping to USA.
    Unfortunately, I cannot bid since I'm in Canada.
    --- begin sig file ---
    --- end sig file ---
  • 999999999
    • Sep 2006
    • 774
    Re: Lot of 10 Amprobe 34XR starting at $10
    Thanks for spotting this, but I get the feeling the winning bid could be well over $100.
    • retiredcaps
      • Apr 2010
      • 9271
      $54.77. A great deal for the winner.
      I was close in my prediction of $45 from another thread.
      https://www.badcaps.net/forum/showpo...72&postcount=7
      • 999999999
        • Sep 2006
        • 774
        Yes that was pretty good. I should've bid but having a couple Flukes already, I'd just leave them sit or then feel like I had to resell them.
        • retiredcaps
          • Apr 2010
          • 9271
          I could probably have sold all 10 for $50 to $60 each pretty easily. Of course, I would have kept one myself.
          • tranquility
            Onkyo TX-NR809 – no hdmi, DTS or NAND chip ? stuck at starting kernel
            by tranquility
            i want to repair an Onkyo TX-NR809 receiver.
            symptoms:
            on power on, display appears and i hear one click. enue functions is given.
            - no hdmi output
            - audio output not tested, but i think it is not there
            - usb sticks are not recognized
            if i read out the chips with display+standby button + tone+
            both dts show only ????
            chip is D830K013BZKB4
            things i have done:
            - reflow of the dts chip without taking off and reballing
            - changed the aluminium caps without the big one with 25v because i dont...
            08-25-2025, 01:04 AM
          • PeteH
            Dell Precision 5520 / LA-E331P r2.0 starting into CPU-failure
            by PeteH
            I have here a broken Dell Precision 5520 / LA-E331P r2.0 to play with
            I found the schematics for r1.0, but not for r2.0.
            The situation
            - the laptop turns on, but the screen stays black -> the dell diag-LED shows the blink pattern for "CPU failure"
            - the voltages close to the CPU stay at low
            - I don't see any hotspots on the PCB (thermal imaging camera)
            - some spots/areas on the PCB indicate some kind of liquid "damage"
            Before I start digging though 70+ pages of schematics, maybe somebody...
            Yesterday, 07:54 AM
          • Grasshopper2Ant
            ACF Remover G-450 Substitute in Canada
            by Grasshopper2Ant
            Hi All,
            Need help sourcing a substitute for ACT remover G-450 in Canada.
            Removing glue from Flex Cable on LED TV that I dislodged so I can resolder with ACF tape.
            Can someone confirm if acetone will work?
            They will not ship to Canada.
            Thanks for any help....
            08-15-2023, 02:00 PM
          • SuperAman
            HP 15 EPK50 LA-G07EP not starting up on battery?
            by SuperAman
            Hi guys, I got an HP 15 mobo # EPK50 LA-G07EP rev 2.0 not starting up on battery? Recently the battery completely died, wouldn't hold a charge, so I used it for like 3 or 4 days until I ordered a new battery. I ordered a new "OEM" battery and replaced it. It wouldn't start with new battery, figured it was dead and plugged it up and powered it on to see that new battery was like 60% charged. So it seems It won't start on battery if it is not plugged in. It charges fine and lets me use it while not plugged in. If I use it and shut it down and try to power it back on it'll start from power...
            12-17-2024, 07:03 PM
          • Braith
            iMac (2012 model) A1419, EMCNo: 2639 not starting up
            by Braith
            Hi, EMC 2639 .iMac not starting up. Single dim diagnostic LED (LE0301) flashes off briefly when power button pressed. Working through supply rails at present (PP5V_S5 appears shorted to ground but still early days)
            Using Boardview 820-4652 but not sure if that is correct one to use. Have searched Forum but only found bios found for 2639 so far.
            Have also tried 820-00134-08 and 820-3478 but have noticed discrepancies compared to my board.
            If anyone has correct BOARDVIEW and SCHEMATIC for a EMC 2639 I would really appreciate it before I get too far into this.
            11-08-2024, 01:12 PM
