Cheap vs expensive HDMI cables
  • cheapie
    null
    • Jul 2010
    • 849
    Re: Cheap vs expensive HDMI cables
    Originally posted by liloldunit
    But I'm not going to stand in a bucket of water, and stick a screwdriver in the wall socket!!! ;-)
    But that's how you're supposed to do it!
    • xplayerx
      • Oct 2014
      • 9
      We can say There is no Different betwen Cheap And expensive
      • Agent24
        I see dead caps
        • Oct 2007
        • 5008
        • New Zealand
        Yes there is, just not in the way you might expect.
        -David VanHorn
        • japlytic
          Certain DisplayPort-HDMI cables can disable HDMI CEC communication
          by japlytic
          With a setup including a TV and AV receiver where HDMI Consumer Electronics Control (CEC) and Audio Return Channel (ARC) functions were working, these two functions stopped working after changing some connections (not the one between the AV receiver and TV), so I believed it was a corrupt setting in the AV receiver or TV, but when I disconnected a passive DisplayPort-HDMI cable (which a Multimode DisplayPort connector supports HDMI with a low cost passive cable or adaptor) connected to a home theatre PC, HDMI CEC and ARC functionality was restored.
          An examination of the HDMI CEC wiring...
          07-10-2022, 09:48 PM
        • japlytic
          Certain "Class 2" HDMI cables can be marginal at 4K 60 Hz
          by japlytic
          For some time, a "Class 2" HDMI cable (part number BN39-01583B) supplied with a Samsung 4K 60 Hz display sometimes causes the display to overlay a few horizontal lines of flickering pixels of random colours and sometimes drops out, particularly on content requring HDCP.
          Since changing the cable to a thicker Class 2 unit, this problem has not occured again - do you know of other marginal "Class 2" HDMI cables supplied with displays?
          09-06-2023, 08:50 PM
        • aliougm
          Marantz SR4003 AVR HDMI board issue, seeking for help
          by aliougm
          I have problem with my AVR(Marantz SR4003) HDMI board issue. I connect to my TV but screen color distorted,see attached picture.
          Connection as below:
          Set-top box HDMI output >AVR 3 HDMI input/one HDMI output>HDTV HDMI port
          If I bypassed AVR then HDTV screen color be good.
          I take out HDMI board from AVR and check services manual the schematic shown the HDMI signals path:
          3 HDMI input port > SIL9185 chip(HDMI switch) > SIL9033 chip(HDMI receiver) > SIL9030 chip(HDMI transmitter) > HDMI output port
          I replaced all...
          04-30-2022, 12:21 PM
        • RossMoodley1967
          LG LCD TV HDMI PORT FAULTY
          by RossMoodley1967
          LG LCD TV picture comes on intermittenly using hdmi port.The sound is on permantly.The hdmi ports looks fine and soldered in securely.The 3.4v coming to the main board is not present(not sure if will affect the hdmi port or where that voltage goes.)The hdmi cable is fine because it works on another tv.The ceramic caps connected to the hdmi controller ic is reading 39 ohms.Could the hdmi controller ic be faulty(feels very warm to touch).The RCA jacks work normally .Thank you in advance for your assistance..
          02-28-2024, 08:38 AM
        • budwich
          ESD Diode on HDMI output of Yamaha a1050 RCVR
          by budwich
          I lost one of the two hdmi outputs on a yamaha rx-a1050 receiver. Of course, it is the hdmi1 which has the arc capability which was useful. The second output hdmi works OK.
          I got an hdmi breakout board which gave me access to the "little guys" in the hdmi. I did some gross DC voltage measurements to ground and found that the Data1 pair (4 and 6) had a lower voltage than the working hdmi.... 1.1v versus 2.9. All others pins seem to be OK. Further when plugged into a display, there is no video but a message on the screen which I assume is the display's status for the...
          09-11-2023, 12:21 PM
